Question about Panasonic Office Equipment & Supplies
Panasonic DP8020E Black and White Copier error message 13
Panasonic dp8020e copier / the wrench light and another light to the far left side that looks like lined paper are on and cannot print. I had some instruction but did not get them all. They start with;
press and hold the function key
original size and the #3 key
f1 self test 9 hit down arrow
f9 hit down arrow
hit down arrow to 06 hit set button r/paper code
func reset
set yes to see if paper prints, can you correct and complete the instructions for me. Thanks MShea
Posted on Jul 25, 2010
Setting IP address on Panasonic dp8020e
Press the function button while in the copier mode, scroll to general setting and press set or the green start button, scroll to key operator mode and press set or start, input 000 or 0000 in some cases and press start, scroll down till you find dhcp and switch off, press set or start scroll down to tcp/ ip and enter your new static ip, press set do the same with subnet mask and gateway. Remember to press set or start after each input. Press the red stop button until you are completely out of the menu. Switch machine of and after a few seconds back on again. Ping ip from pc to confirm communication.
Oct 21, 2013 | Panasonic DP-8020E Black and White Copier
Can't print to DP8020e from WinServ 2008 R2 with PCL6 nor PS drivers. Output goes from system queues right and then isn't priting without any errors comunicated from printer. Printing from 2003 with PCL5...
uninstall the driver and reinstall back the driver or make sure the pc is properly connected to the copier.one you can see the icon of the printer on the pc means it due to print
Feb 07, 2011 | Panasonic DP-8020E Black and White Copier
I have a Panasonic DP8020E black and white copier. This may be a dumb question but when I scan why doesn't it do so in colour?
Its not actually a dumb question but the DP8020e has a monochrome scanning abitlity the Dp 180 however has Colour scanning ability which it states clearly in the front cover
Aug 31, 2010 | Panasonic DP-8020E Black and White Copier
PANASONIC DP8020E COPIER MACHINE PROBLEM
it means that the developing unit connector is not connected. you can find it near the location of the toner waste container. there will find one screw lock for the cover of developer harness. possibly one of the wires of the developing unit is open. you can solve it by just twisting or untwisting that wire; not need to replace just twist it or untwist it. :)
Jan 26, 2010 | Panasonic DP-8020E Black and White Copier
I get an E140 error message when I turn on the copier
Hello sir; The error code you display it means optics fan not working you have to replace it.
Aug 28, 2009 | Panasonic FP-7735 Black and White Copier
Panasonic FP 7742 Copier
check drum and drum sensor. if the Drum cleaning blade (DCB) has failed and is smearing toner around the drum then the drum sensor can't see the drum. clean it with a brush. the sensor sits in the drum/ cleaning station.
Oct 14, 2008 | Panasonic FP-7735 Black and White Copier
111 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
