Question about Mitsubishi WD-52525 52" Rear Projection HDTV
TV does not turn on by pushing the power button on TV or using the remote.
  • 1 more comment
  • a b Jul 06, 2010
    Do any lights flash or light up?
  • mikemarget Jul 07, 2010
    TV does not turn on by pushing the power button on TV or using the remote. There are no flashing lights. Hitting the "reset" button as advised in the manual is nonresponsive as well.
  • Shahid Electronics
    Shahid Electronics Jul 10, 2010
    Did you got helpful info in chat session?
  • 58 Answers
A dead unit is commonly caused by a bad main fuse (right off the AC input). A bad fuse can be caused by something as simple as a power surge or some component on the power supply could be toast. Switch mode power supplies can be a pain to troubleshoot, specifically this one. If you find a bad fuse, replace it. If the new fuse goes out. Go find yourself a replacement board. They should be cheap enough. Goodluck.
Posted on Jul 07, 2010
I need remote control code for Dawin TV
If you do not know the code, you can use the code search function to program the remote control.
Using Code Search:
1. Turn on the device you want to program into the remote.
2. Point your remote control at the device
3. Press and hold the "Code Search" button for about 3 seconds until the light on the remote stays on.
4. Press the button on the remote for the device you want to program. Push the "TV" button to program the TV, press the "DVD" button to program the DVD player, etc. The light on the remote control will blink and stay on.
5. Slowly press and release the power button repeatedly until the device turns off. Each time you push the power button the light should blink once.
6. Press "Enter" to save the code into the remote and the light will turn off.
Apr 04, 2016 | Televison & Video
Bush lcd42f1080p100hz remote will not turn tv on
I had come home about a week ago and pushed the power button from my remote but my tv did not respond. So I just went to the front panel and pushed power but once the tv turned on, the volume was on full blast! I used the front panel volume decrease to get the volume down, but when I stopped pushing the button, the tv increased its volume to full blast again by itself! Naturally I just turned the tv off for a few moments. I tried the remote again, no response again, so I used the panel power button. The tv volume was still full blast when it turned on but after I decreased the volume it stayed this time. The picture is and has been perfectly fine and the tv was working fine. The next day the problem started all over and now once we turned it off from frustration of having to manually use the panel to change channels, it now will not turn on at all. I have changed batteries from my remote, reprogrammed my remote, pushed system reset several times, unplugged it for a while, bought a new surge charge, and even held the menu and device panel buttons for 10 sec and tried to turn the t.v. on again! What other options do I have or what may be the issue at hand and possible parts that may need to be replaced?? Thanks!!
Nov 02, 2012 | Televison & Video
How do i program my remote
Hello;
Without knowing the codes for the specific brand names and models of your devices, this is how you program the Zenith MBR3447 for your TV, VCR, DVD Player, CD Player or Audio Receiver:
TV
1. Push the "Power" button on the TV to turn it on.
2. Press and hold the "PRG" button in the upper left corner of the remote. Release when the indicator light, located in the top center of the remote control, comes on.
3. Push the "TV" mode key located at the top of the remote.
4. Enter 0 -- 0 -- 0 on the remote's number pad, then press the "Enter" button.
5. Aim the remote control in the direction of the TV's IR sensor and push the "Power" button. Pause a second. If the TV fails to shut off, push the "Power" button again. Repeat until the TV does shut off. Each time the "Power" button is pressed the Zenith MBR3447 tries using a different TV device code from its code library to turn the TV off. Therefore, when the TV finally does shut off it's an indication that the remote is temporarily programmed with the correct device code to control the brand of TV you're using.
6. Press "Enter" to save the current code.
VCR
1. Push the "Power" button on the VCR to turn it on.
3. Push the "VCR" mode key located at the top of the remote.
5. Aim the remote control in the direction of the VCR's IR sensor and push the "Power" button. Pause a second. If the VCR fails to shut off, push the "Power" button again. Repeat until the VCR does shut off. Then press "Enter."
1. Push the "Power" button on the device your programming the remote to control to manually turn it on.
3. Push the "AUX" mode key located at the top of the remote.
5. Aim the remote control in the direction of the device's IR sensor and push the "Power" button. Pause a second. If the device fails to shut off, push the "Power" button again. Repeat until the device does shut off. Then press "Enter."
Mar 11, 2011 | Zenith MBR3447 Remote Control
I have a remote that i have had for a while and it stopped working. I changed the batteries but it still doesn't work. I have the codes for it but i missed placed the instructions on how to set the code....
turn on manually your set (tv), push the code button on your remote control until led light, release the button, the led still ligth. push the tv button one pulse, push the power button several times until tv turn off. when this happen push enter button... try turn on the tv with remote control.
Mar 20, 2010 | RCA Universal Remote Control
Programming problem
a universal remote control is programmable without codes using this general process:
  • push and hold 3 sec the button set up
  • select the device to control (TV DVD etc)
The tv has to be ON at this step (use the power button in the tv front panel
  • use the remote control power button and try to get your tv pushing the button again and again and again
  • Caution! Go slow because when finally the tv turns on you have to push enter in the remote control to save this code that actually is the one the tv needs,
Apr 14, 2009 | Radio Shack 15-2142 Remote Control
Dish network remote code for Disney 13" TV
On your dish remote, press and hold the tv button until all 4 buttons light up, then release. push either of the power buttons once. Now start pushing the down channel button, It's the one right below select, continue pushing it until tv turns off. When tv goes off push down button one more time then push up button, when tv turns back on stop and press # key, tv light will flash 3 times and should be set. Note....if u press down button and tv does not turn off after going through all codes( tv light will start flashing) press cancel and try again only channel up this time. hope this helps.
Dec 31, 2008 | Disney 13" TV
RCA universal 3 digit remote code for diamond vision TV
turn on your tv.Then push the code search button until the led still ,when the led keeps on let go the button now push and release the tv button then push and release the power button until the tv goes off,when the tv turn off stop to push the off button now push the set button the code are already set on the remote control( you might got to push the off button almost 100 times or more until you get the right code for your tv.Good luck
Aug 09, 2008 | Televison & Video
Philips universal remote codes
For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
Feb 07, 2008 | Panasonic PT-47WX53 47" Rear Projection...
How to use Toshiba 32D46 32" TV with Comcast 3 in 1 Universal Remote Control
Most univ. remotes have a search mode if code entry won't work-
Do you have the comcast instructions ? Something like.....
1) Tv power on
2) Push set-up or program on remote
3)Touch tv button on remote
4) Point remote at TV and push power off. Repeat until TV turns off.............then
5)Push enter to save....
Hope I helped you........T.
Nov 07, 2007 | Toshiba 32D46 32" TV
Hughes Remote works the satellite but not the TV
You have to push and hold down TV and Mute button (for 2 seconds at the same time), then release them at the same time, then push channel up until the TV turns off.  Be patient and continue channel up until the TV turns off.  When it turns off, then push TV again to lock the code.
You were doing fine, but missed to push channel up to fine the code.
Oct 25, 2007 | Hughes HRMC11 Remote Control
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
304 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
