Question about Code-Alarm Code Alarm Transponder
Ford transit on 06 plate alarm just goes off when it feels like, check doors all sound can u help.
See if it has a glass breakage sensor.
If it has it may need to be adjusted. Arm your alarm and tape on your windows or put your mobile phone in the cab and call it. see if your alarm goes off
Posted on Jul 18, 2010
I have a ford transit 08 plate and have a problem with the central locking it has been playing up for a while every time I lock the doors the horn sounds
Hi
The wiring loom to the rear right hand side door are common to fail on this shape transit which causes this issue quite a lot if your happy that all your doors are closed and locked which this is what the horn is supposed to sound for as a fail safe I would have the loom checked
Hope this helps Nick
Aug 17, 2017 | Ford Cars & Trucks
Ford transit central locking
Sounds like you will be spending quite a while at your garage repairing a damaged loom and then sorting the alarm system out. Was it a stolen vehicle that has been recovered I wonder. Check the DVLA records.
Jul 14, 2017 | Cars & Trucks
Opean a dead lock door on a transit
You will need to remove the door door panel with the door closed to unlatch the door mechanism, sorry but no way around that.
Sep 05, 2012 | Ford Cars & Trucks
My bottons on my keys dont work so how can i turn of my alarm on my ford focus
  • If it is a stock alarm the you can put the key into the ignition and turn the vehicle over and the alarm will shut off. Often time just sticking the key into the drivers door is sufficient but the ignition will surely kill the alarm. It has to be the transponder key though not just a quick cut key.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 13, 2011 | 2007 Ford Focus (3 Door) Hatchback
How do i disarm my ford transit alarm because sometimes when i open it then start it up the alarm goes off?
Look in your fuses under the hood and under the dashboard. Hope this helps?!
Please rate and comment - Thank You
Sep 23, 2010 | Ford Econoline Cargo Cars & Trucks
When i lock the doors on a 2002 ford explorer about thirty minutes or so the alarm sounds. even if not activated. the only way it doesnt is when i leave it unlocked. any suggestions?
Check to see if when the alarm goes off if the interior lights are lit. Ford's have a problem at times with the door pinswitch in the door latch leaving the interior lights on, or coming on unexpectedly. Is this a factory installed alarm? WD40 sprayed into the latch will sometimes fix this problem.
Jun 12, 2009 | Code-Alarm Code Alarm Transponder
Transit doors not locking
james i have had the same problem on a transit an trace the problem in the wiring to the rear right door where the wirin goes through the plastic slider between the door and the vehcle i had to cut out the damaged wiring and run new and solder up make sure the wires you put in are long enough too so you can open the door all the way , failing this think logically which is the door opened and closed the most ,ther might be your prob in the wiring between the door and vehcle
May 10, 2009 | Code-Alarm Code Alarm Transponder
Ford transit lock problem
i, i get this all the time, had lots of old transits. get as many ford keys as you can borrow friends from escort mondeo transit, these locks are **** some 1s key will open it, when doors are open u have to remove locks and soak them in oil leave under engine oil all night, fixes ur prob.
Feb 08, 2009 | Code-Alarm Code Alarm Transponder
Keyless entry stopped working on 05 cobalt now i have to unlock door with the key and when i do that the alarm goes off. Help
Lock all the doors from the inside (with all the doors closed), unlock your driver's door by manually lifting the lock, then press it back down after you are out - this will prevent the alarm from sounding when you use the key to unlock the door.
Aug 02, 2008 | 2007 Chevrolet Cobalt Coupe
Code-Alarm Code Alarm  Transponder Logo
212 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
