Hp laserjet m2727nf mfp - fax errors - sending and receiving. comm error 350, and comm error 232. Dedicated fax line. Any advice?
  • 3 more comments
  • Anonymous Jul 21, 2008
    Using the HP Laserjet M2727, weget the error on incoming faxes on faxes that contain several sheets. Typically the incoming sheets are full of text.
    Is this a line problem or and HP problem.
  • Anonymous Aug 18, 2008
    I have the same issue. I can send fine, but consistently recieve "Comm Error 232" when trying to receive faxes. This is also with a M2727nf.
  • Raz4 Sep 09, 2008
    sending out from M2727nf mfp fax machine is fine within the office and outside the building. Incoming faxes received from outside the building have problem receiving but you can hear the machine communicating but after a minute or 2 it will show communication error 232. sounds familiar? anybody knows any fixes?
  • Emperor Jer Nov 20, 2008
    No sending or receiving on fax
  • nrsmoyo May 11, 2010
    i have an Hp Laserjet m2727nf giving scaner error 8>How do i solve this problem
Check if you have the latest firmware for this multifunctional on www.hp.com, installing newer firmware fixed communication problem for us.
Posted on Jan 30, 2009
    Problem Solver:
I SOLVED THE "NO FAX DETECTED" ON M2727 mfp:
I'm sure this is not everyone's issue, but for me I found it to be the STUPID mistake of just plugging the phone cord into the wrong phone port. I had it plugged into the handset port rather than the phone jack port. The system is No Fax Detected, but if you listen to what happens the fax machine picks up quickly and then disconnects causing the No Fax Detected error. I switched it to the correct port (top port on the M2727nf) and everything worked great!
Posted on Mar 11, 2010
I am having the same issue. Any other suggestions?
Posted on Oct 06, 2011
I was able to resolve the same issue with an HP M1522nf MFP (multifunction) unit by changing the "Fax Speed" option from V.34 down to V.17. Although this option is under the "Every Outbound Fax" menu, it appears to have resolved the problem with inbound faxes.
Outbound faxes were never a problem. However, "No Fax Detected" and Comm Errors of every sort were previously gotten on about two out of every three inbound faxes.
Tim Alberstein
Posted on Oct 26, 2008
Hp laser jet m1536dnf MFP won't send fax comm error 388
You can start by making sure that the photocopy is working, this is to ensure that the scanner is working. Next, try to isolate the issue if this is only happening to only one fax number? If all of these have negative results, I suggest for a hardware reset. Follow the steps for reset found here, How to Reset the HP LaserJet Pro M1536dnf Multifunction Printer. Goodluck :)
Aug 14, 2012 | HP PSC 2410 All-In-One InkJet Printer
HP Laserjet M2727nf Mfp Printer Scanner Error 8
The HP M2727 has a known issue with the scanner error 8 and bad formatters. HP has extended the warranties on this product. I suggest you contact them directly and they will most likely exchange the unit.
Nov 08, 2011 | HP Laserjet M2727nf Multifunction Printer
Sending fax for hp all in one indicate Comm Error 388
Error could be caused by the fax machine that you are sending to.
So you can receive faxes, but can't send them. Is it just the one number that causes the error, or is it all faxes sent that cause the error?
What I like to do on fax troubleshooting calls, is to call the phone company that the site is using. Tell them that you are having fax problems, and ask them to test the line.
Jun 12, 2011 | HP LaserJet 3050 All-In-One Printer
Not receiving any Fax, only can send out Fax.
Hi Mechanic.
The problem could be with your phone service if you are on digital lines, you would have to install a digital to analog filter. If you are analog the comm errors are typical of a line with a lot of static. You can change two settings on the printer which should solve the issue until you install a filter.
The two settings which are under the fax set up menu/ all faxes\
Error correction mode (ECM) set it to off
Fax Speed set it to medium.
Good luck
Al
Eliteprintersolutions@gmail.com
Jul 02, 2010 | HP LaserJet M1522nf Multifunction Printer...
Fax rec 2-3 pgs OK, then disconnects and gives Comm Error
These errors mean that the communications have failed, and can mean that the receiver at the other end has terminated the call prematurely.
If the problem occurs with the same destination, then the receiver fax may be the problem.
If the error persists try disabling ECM
Feb 04, 2010 | HP LaserJet 3055 All-In-One Printer
Error 79 hp laserjet m2727nf mfp; error 49 hp laserjet m2727nf mf
Recommended action 49 and 79 Errors, Turn off then on The product has experienced an internal embedded software error. Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the product to initialize.
If you have recently installed a memory DIMM in the product, turn off the product, remove the memory DIMM, reinstall the DIMM to verify that it is seated properly, and then turn on the product.
If the error persists, contact HP. See www.hp.com/support/LJM2727 or the support flyer that came in the product box.
Jul 02, 2009 | HP Laserjet M2727nf Multifunction Printer
Error codes 283 and 232 in received Faxes
basically error 232 indicates that a communication failure has occurred between the two machines
Following these steps may help resolving your issue
1. Make sure that the phone cord is plugged directly from the wall jack into the back port of the fax machine that is marked "Line" or "To Wall Jack", or that has a wall-jack symbol.
2. Verify that the line interface unit (LIU) (the box that the phone cord plugs into) is seated fully into the back of the fax.
3. Remove any other device from the line such as splitters, credit card machines, or telephone answering machines, and retry the fax communication.
4. Try sending and receiving faxes on a different fax line.
5.Try using a different telephone cord.
6. Have the phone company test your line for static or noise problems.
7. Disable Error Correction Mode (ECM) if the same error occurs repeatedly.
Hope this helps.
thx
Jun 02, 2009 | HP LaserJet M1522nf Multifunction Printer...
HP laserjet M1319f MFP "no fax detected" error
I had the same problem and just solved it by going into Setup - then Fax Setup - then All Faxes - Then Speed - and lowering the speed from fast to medium. Sure it's a couple seconds slower, but it finally works!!!
Dec 02, 2008 | HP LaserJet 3015 All-In-One Printer
Laserjet 3330 is resulting in fax Comm Errors 327, 232, 442, 356, 421 Comm Error 327 is always with fax # 780.467.6516. i can not fax to this number and when i receive from it, it always prints a Fax...
232-A communication failure has occurred between the two machines.
327-*Reattempt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
356-The remote user has pressed the Stop key, causing the session to be aborted.
442-An error occurred during transmission after one or more partial pages had been sent. The transmitting machine was unable to restart the control channel (handshaking) before sending more data. This error typically occurs when the receiving fax disconnects after receiving part of a page but can also occur if the receiving fax is using a fax format that is incompatible with the HP fax machine (usually during color faxing).
Aug 15, 2008 | HP Computers & Internet
5,118 people viewed this question
jasbo
jasbo
