Question about Toshiba HD-A2 HD-DVD
DVD player no signal
Hd-a2ku Toshiba dvd player, hooked up to Onkyo TXSR805 with hdmi - all of a sudden the reciever won't recognize the player, switched hdmi slots still says "no signal" - even tried a new hdmi cable?
John
deputydoig@aol.com
3 Suggested Answers
SOURCE: HD-A2KU
Yes, the firmware up to v 2.5 will correct your problem
Posted on Dec 08, 2007
andygoacher2
  • 17 Answers
SOURCE: My Toshiba remote control se-r0077 sometimes works to control the DVD player and other times it doesn't. I've tried new batteries and the problem still persist s
One of the best ways to check if an infra-red remote controller is working properly is to look at it using a camera. (a webcam or phone camera will work) The camera will see the infra red radiation as visible light. If the LED lights up (on camera) consistently when buttons are pressed, then it may not be the remote at fault, but rather the receiver in the DVD player. Most of the time though, it IS the remote control at fault, and these are usually easy to get working again.
Couple of things to check are:
1) the battery terminals...
Batteries can leak and corrode the terminals in the battery compartments. Signs of this include rust, green coloured contacts, or a crystalline deposit. If you see any of this then clean the contacts using metal cleaner or some methylated spirit and cue-tips.
2) Broken wires connecting battery terminals to the circuit board...
The soldering in some remotes can be rather poor, and wires can sometimes come loose, especially if a remote has been dropped or bashed about a bit. Unscrew the remote and check everything is connected properly
3) Dirt under the buttons...
This can prevent a button from making contact with the circuit board properly. Unscrew the controller and separate the rubber button pads from the circuit board check for dirt both underneath the pads AND on the metal contacts on the circuit board. Clean as required with methylated spirit and cue-tips and then reassemble.
Hope that helps!
Posted on Jan 08, 2017
TV to Reciever Sound Problems
MAke sure your channel selection is correct.
Sep 17, 2007 | Onkyo HT-SR800 System
I have a TX SR 606. I have the unit connected with a HDMI cable to my TV. At times it will take several minutes to get a signal to the TV when I turn on HD format. I am also using HDMI from the DVD player...
This is one of many reasons I recommend against routing ANY video through a receiver if the TV/ monitor has enough connections for all of the video sources.
Bypass the receiver andsee what happens, then isolate a cause.
Dec 28, 2010 | Onkyo TX-SR606 Receiver
Receiver taking a long time to transmit reciever
I assume that the HDMI works fine if you go directly from the dish receiver to the TV with either HDMI cable. And try it with a different source (DVD or x-box) in the same input port.
Take it to a Radio Shack there service centers can repair Onkyo in warranty. Most Onkyo receivers carry a two year warranty.
Nov 18, 2009 | Audio Players & Recorders
HDMI SOUND
True HD can only work with HDMI interface and is only available on some newer HD DVDs. Check the DVD to see if the True HD encoding is available.
Feb 11, 2008 | Onkyo TX-SR605 Receiver
Toshiba HD A2Ku
It will take almost a minuted for the player to boot up and appear on screen, providing I am assuming you have your TV set to DVD setting.
Your DVD then when booted up will say "No Disc" if you dont have a DVD in it, course with one in it, your movie should appear.
Jan 16, 2008 | Televison & Video
HD-A2KU
Nov 21, 2007 | Toshiba HD-A20
TOSHIBA HDDVD PLAYER A20
I have a problem like this but mine will play regular dvd's
and just stop playing hd dvd's . exact same message
gene
mrjazz1959@gmail.com
Nov 03, 2007 | Toshiba HD-A20
Toshiba hd dvd A20 remote codes
i am having the same problem with the HD-A2KU hd dvd player not recognizing any of the codes. it seems that the dvd player does recognize the codes but will not control the player. when i click the on off button the dvd player changes to a word but does not turn it off or control it.
Oct 30, 2007 | Toshiba HD-A20
I just purchased a Toshiba HD A20 from Best Buy but the unit didn't have a user manual
Go into the menu options for the player, and switch to Bitstream! Not PCM
Oct 11, 2007 | Toshiba HD-A20
Toshiba HD-A2 HD-DVD Logo
51 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
