I have a samsung WFA338AW front loading washing machine which has worked great for the last year but since i left some towels in there that got mildewy i now can't get the mildew smell out of the chamber. i have tried the silvercare with hot water and bleach no good. Used vinegar. No good. Used borax. No good. Help! what will get the smell out? it's not the rubber stripping
    President:
  • 1,015 Answers
Now I don't know if this will work for you but you can give it a try. I have had good luck with those Cascade packets that you can use in your dishwasher. Try throwing one packet in the washer on the clean washer cycle. Also another step is to leave the door open completely on the washer for at least a week and not to use it so all the water will completely dry out. The bacteria will no longer have a place to grow if you let all the water dry up in the machine. Good luck and have a nice holiday.
Posted on Jul 04, 2010
I have a LG front loading direct drive washing machine (WM1812CW) that is 5 years old that is making a loud knocking noise during the spin cycle and is emitting a burnt smell after the cycle ends. ...
It seems you need to have a new sealing rubber fitted. IN THE MEANTIME, if the knocking happens again when the spin starts, stop the machine, let the washing drop to rest, and then start it again, the re-positioning of the fabric inside the drum should even out. Also, do not load with say.. only towels, that way the weight is one sided and will make the drum spin in an uneven way.
Oct 07, 2017 | LG WM1812C Front Load Washer
Samsung washing machine b1245s makes a grinding noise but wont spin...any ideas why and how to fix the problem?
i would grab a towel and check the pump for grit
and things that dont belong
may not be the actual problem but thats whered id start
have a great day
Oct 09, 2009 | Samsung B1245 Front Load Washer
Smell of mildew on our towel and sheets
This is probably happening because the clothing is being left damp in the washer. When it is warm during the summertime mildew will grow very quickly in the towels. On front load washers you need to leave the door open when not in use to keep mildew from growing. You should wipe out behind the inner seal any moisture when you are done doing laundry. This is an issue for most front loaders. Some front loaders have a clean washer cycle that uses bleach to sanitize the drum. Other washers like the Samsung have a block of silver and release silver ions in the wash to sanitze the clothes.
Sep 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washed load of towels wont work
try cleaning the drainage filter located under the front bottom panel.
Aug 14, 2009 | GE WSXH208A Front Load Washer
The washer does not spin during washing cycle or drain & spin cyc
I can a very simple part called the motor coupler...you can find the part at www.repairclinic.com. It costs 13.95. I am fixing my washing machine today, as this happened before and was the answer. Goodluck
Apr 11, 2009 | Kenmore 46462 Front Load Washer
My new washer did not spin out the water
if its a new washer call and have them trade it out for another one.
Dec 31, 2008 | Samsung WF337AA Front Load Washer
Musty smell on towels
I had this problem last year. I was not using HE detergent. The other detergent was causing soap scum to build up in the drain hoses. After they were cleaned (it took more than one time taking it apart and cleaning), and we started using HE detergent, it worked fien with no odor.
Jul 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Samsung, rossby washing machine
There is a capacitor linked to your motor by wiring.. That capacitor is most likely the fault... It is normally a 400vac 12UF(J) capacitor
Jul 10, 2008 | Samsung Washing Machines
GE Front Loader Washer
Towels are heavy so it likely became unbalanced and triggered a shutdown.
press the signal button for 10 sec
Feb 26, 2008 | GE WSXH208A Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
