Question about Abernook Pasquini Livia 90 Semi Automatic
Pasquini service in washington dc
Are there any pasquini technicians in the dc area? i have a livia 90 auto that has a problem when starting. i get three blinking lights
  • 1,089 Answers
Hi
If they are blinking slowly check this. Check the wire on the water reservoir to make sure that it is connected. You can try grounding this wire and see if the machine responds.
Water level may be low in the reservoir. Are you using distilled water or reverse osmosis water. Don’t. The computer can’t tell if have water in the reservoir, because it need’s minerals to conduct the small current for the computer. If they are blinking fast you may need a new computer.
Posted on Jul 04, 2010
How do i replace a touch pad
See user's manual, if any hint. Actually, didn't know that asquini Livia 90 Espresso Machine has a touchpad. Looks a really interesing device!
https://www.seattlecoffeegear.com/assets/user-manuals/pasquini/pasquini-moka-grinder-user-manual.pdf
May 13, 2015 | Pasquini Livia 90 Espresso Machine
I need the parts diagram for the pasquini livia 90
I found something on amazon, click here and take a look: Amazon com pasquini livia 90 parts. I hope this was helpful. Cheers
Nov 18, 2010 | Pasquini Livia 90 Espresso Machine
Pasquini Livia 90: heats up for about 5 minutes, then shuts off
Sounds like the pressure switch is not working properly and the safety is turning the machine off. Try checking the tube from the boiler to the pressure switch that might be blocked, if not then the pressure switch needs to be replaced.
Jul 21, 2010 | Pasquini Livia 90 Espresso Machine
Descaling the livia 90
The proper and only way to descale the boiler should only be done by a trained technician. As far removing the water tank goes, you simply lift it up from the left and right hand sides - this may be difficult if you have never removed it since calcium may have built up on the seal at the bottom of the reservoir - simply wiggle it side to side to remove. To clean the reservoir, you can use a green scour pad with water. If it is heavy build up you can use a product called CLR, and let sit overnight. You can save the CLR and reuse. Rinse well to remove all clr.
My experience is working over 10 years at Pasquini as a master technician running the home repair sales and service center.
I stock all Pasquini parts for any service of your Pasquini espresso machines and grinders. Contact us for any of your Pasquini sales and service needs.
Apr 06, 2010 | Abernook Pasquini Livia 90 Automatic
I have a six plus year old Livia 90 Semi Automatic. It builds up pressure and then releases through the release valve, sometimes every 10 minutes, sometimes not for a couple of hours. Always quite a...
This is a simple fix. This has been fixed on newer units with a rewire kit. This rewire kit is for Pasquini Livia 90’s with serial numbers PRIOR to #49000. We have them listed on our website Part# 90000 for $30.00.
You can contact me for this part - If you are local we could install it for you. If you do not fix this problem soon, you will need a new pressure release valve. It would also be advised you get a microswitch #7633905 for $13 at same time as the rewire kit. If you still require a manual we could provide you with a digital version.
Jan 16, 2010 | Pasquini Livia 90 Espresso Machine
Pasquini Livia 90 cutting out
Sounds like your transformer inside the CPU is overheating and putting your machine into safety mode/shutting down. Or, the reservoir is not making its proper connection - please be sure it is seated properly and making its connection. Contact me, I can walk you thru removing the CPU if that is the problem. I can repair and return the CPU to you within a couple days.
Jan 02, 2010 | Pasquini Livia 90 Espresso Machine
Our Livia 90 would need a service + the pressure steam valve is leaking. Thanks in advance ! Thilo
If you are local to us perhaps in Orange County, CA we can provide service. If not you may contact Pasquini to get a local certified repair location near you.
As far as the pressure steam valve goes, you most likely simply need a new o-ring kit... we offer kits for new and older units. Older machines would use Part# KSWV-2 for $5.40, newer units would use Part# KSWV-2 for $4.30. I could explain how you could do this service yourself.
Oct 03, 2009 | Pasquini Livia 90 Espresso Machine
Need a manual for Pasquini Livia 90
Hi I have one that I wrote if you want it. Send me your e-mail and I'll sent to you.
May 30, 2009 | Pasquini Livia 90 Espresso Machine
Pasquini. Livia 90 intermittently building up too much pressure
The part that will solve your problem is an upgraded heating rewire kit which will control pressure electronically, not manually. The rewire kit is Part #90000, $28
You may also need a new micro switch which is connected to your PStat with the rewire kit. The micro switch part #7633905, $13
These parts are in stock. I can send you these parts and instructions to install these parts in your machine.
May 21, 2009 | Pasquini Livia 90 Espresso Machine
Leaking from the grouphead
The fix to this problem is replacing the group head replacement done every 8 months to a year. The part number is #90907 $4.50+shipping and I have this in stock.
Feb 18, 2009 | Pasquini Livia 90 Espresso Machine
Abernook Pasquini Livia 90 Semi Automatic Logo
167 people viewed this question
Top Abernook Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you an Abernook Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
