Need updated driver for HP All In One C6180 - Computers & Internet
    President:
  • 2,712 Answers
Looks like these MAY be the ones...
http://h10025.www1.hp.com/ewfrf/wc/s...49 4&lang=en&
Posted on Apr 17, 2008
  • 1 more comment
  • Swilin Sampson
    Swilin Sampson May 03, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    If you find that the solution/answer I provided led you
    to, or resulted in a fix, please take a moment to close the ticket with a FixYa!
    rating under my solution.
    I would be very grateful for your show of appreciation.
    Should you have any further questions, please feel free to
    post them here.
    Thank you for using FIXYA!
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    assign a rating just yet. Please post back as to what steps you took, results,
    etc, and I will try to assist you further as best I can.
    IrishDruid
  • Swilin Sampson
    Swilin Sampson Jun 28, 2008
    Kindly close this thread with a “Fixya” rating if you have been able to
    fix the problem, so that I can remove it from my work queue.
    If the issue is not resolved, please post back with latest developments, what
    steps you took, etc. and I will assist you further as best I can.
    Thank you for understanding,
    IrishDruid
I have an HP Photosmart C6180 All-in-One and when I updated my browser to 9 the printer started shutting off and on but it doesn't come up completely then shuts off and cycles again. I restored my...
@msat538,
I believe your printer problems are unrelated to your browser update. You likely have a few failed capacitors on your printer's logic board. I have a HP C6180 all in one printer that started displaying an ink system failure message. Eventually it powered off then on by iteslf every 15 seconds or so, making the printer unusable. Take the logic board cover off (on the C6180 is is on the right end of the printer), remove the logic board and look for failed capacitors (they will be puffed on the top (see image). If this is the case, you will have to have them replaced (easily done with a soldering pen). The replacement parts are inexpensive (less than $1.00) I hope this helps.
Aug 22, 2011 | HP Photosmart C6180 All-In-One InkJet...
I can't get my HP potosmart C6180 ALL IN ONE PRINTER TO SCAN/COPY OR FAX WITHOUT GETTING A SCANNER FAILURE MESSAGE SAYING UNABLE TO SCAN,COPY OR SEND A FAX
Solved! I now can scan wirelessly throughout my network. I downloaded the drivers for a friends newer HP all-in-one scanner and I can scan. Look for the driver for the 309a series of printers and install it. Complete the install and set up your existing printer. You can now scan, print, fax wirelessly. It includes updated HP apps for these functions that work with OS 10.5. I didn't upgrade to the HP 1.1 drivers through Apple. The file name is: PS_AIO_05_C309a_Net_Full_Mac_WW_102.dmg
May 24, 2011 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180....I have a print job stuck in the print queue that I can't delete despite trying multiple times
Try using the HP Print Diagnostic Utility in Windows - HP Customer Care (United States - English).
After that if nothing fixed click on help.Usually the prompt is to uninstall it,do so.Get the update driver from HP and do a clean installation.
Post / thumbs / testimonial are welcome!
Nov 12, 2010 | HP Photosmart C6180 All-In-One InkJet...
I'm can't load the software for my HP AIO Photosmart C6180. Get a MSI error that I can not repair. Need some help here.
Hi Try downloading the software from the HP website http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=ph〈=en&product=1153494& then run the setup on the downloaded file, if you have vista or windows 7 then right click on the setup file and select run as administrator. Hopefully this will solve the msi error, if it does not, please tell me exactly what error you receive.
Dec 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
Trying to get hp c6180 all-in-one printer to work with windows vista
Go too www.hp.com enter your printers details of have HP do a scan, will come up with latest drivers and if they have there will be a prog for your Vista. Good luck.
Nov 12, 2009 | HP Photosmart C6180 All-In-One InkJet...
Cannot get Printer reinstalled after having Hard Drive replaced.
first you need to installed the sytem driver like mothrboard driver and the display driver then start installing the printer driver if you dont have printer driver you can download from this link,
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=1153494&
Nov 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP C6180 will only print a partial document
Hi Rbluhm,
I need somre more information regarding this issue. Like are you able to print fine from other applications without any issue, connectivity and foremost thing operating system you are using...
However, as a work around, I would suggest to select the "Print directly to the printer" option in the properties of Hp Photosmart C6100 series icon.
That is:
1. Go to printer folder.
2. Right click on the printer icon.
3. Click on the Advance tab
4. Select "Print directly to the printer" option.
5. Click apply and click ok.
Then just close all the windows opened on your computer and then re-open the Microsoft Word document and try printing....
I am sure this will resolve the issue. However, if the issue persist, do reply me soonnnnnnnnnnn.......
With Regards.
Mike.....
Feb 05, 2009 | HP Photosmart C6180 All-In-One InkJet...
Lost cd for HP Photosmart C6180 All-in-One
I have lost my HP photosmart C6180 installation software. Is there somewhere I can download?
Jan 22, 2009 | HP Photosmart C6180 All-In-One InkJet...
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
