Question about Craftsman Garden
Craftsman leaf blower pull string will not recoil. Have taken apart and recoiled the string but will pull maybe twice and then not recoil.
    President:
  • Craftsman Master
  • 1,545 Answers
The recoil units on these are engineered very poorly and are not very heavy duty. The plastic part that holds the end of the recoil spring is subject to wear and does...causing this problem. I have fixed one by using JB Weld and epoxying a doubled in two piece of metal (which was a very small picture hangar bracket) on the area with limited results because the bracket was the same height as the plastic piece that wasn't holding.....so far so good..short of just buying the same old cheaply made parts over and over for this...I would try to just improve on the existing one....see if you can get in there and do what I did..its not that hard and once in there, you will see the problem.
Posted on Jul 18, 2010
How to replace starter Rope
William, could not find your exact model, the links below should help as a lot of blowers and string trimmers pull ropes are changed using similar method.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Quick and Easy Homelite Weed Wha cker Starter Pull Cord Replacement
How to fix string starter recoil on small outdoor power equipment like...
How to Install Pull Start Recoil for Backpack Blower
Apr 10, 2016 | Troy-Bilt Tb4bp 32cc 4-stroke Gas Powered...
Pull Cord has stripped and won't recoil. Can this be repaired?
Stripped? Maybe the recoil Spring just broke. Easy repair, sometimes you can just re-bend the 'Stop' on the old Spring
Nov 09, 2014 | Garden
Reinstalling the starter on the PB 620 so that the string recoils properly
Hi, I'll assume that the recoil itself is working properly, so all that you need to do is align the housing with the attachment points and give the cord a slow pull to seat the locking cam -it should drop into place. Tighten the housing down and test. Hope this helps.
Nov 17, 2010 | Echo Garden
I have a craftsman blower 358.797130 and the pull core broke .i have taken everything apart but can not get the pully off the seal o ring seems to be stoping it help the manual is no help
Yes, owner operator manuals cover very little in the way of repairs. If you have the unit taken apart down to the starter/recoil unit and you want to replace or rewind the rope on the pulley...it shouldn't have to be removed, unless the starter spring has broken. These units have a cheap starter system that wears easily and causes the problem you have. If you can, preload the spring (before installing the rope ) by turning it several times in the tension direction and then hold it in place and install the rope, Observe how the old rope is looped around the inner core of the starter if you install new rope.
Aug 06, 2010 | Craftsman Garden
Starter rope pulley will not pull the rope back into the leaf blower.
Most commonly, the recoil rope rewind spring is broken. However, inspect the recoil housing assembly first to make sure no debris or rope fragments have prevented the rope rotor from rewinding. Always remove the spring 'AS A LAST RESORT'. Many rewind problems can be solved by inspection of the rotor and not have to remove the spring. In case you do, I will include instructions on how to re-install.
1) remove the recoil housing
**NOTE: normally you DO NOT need to remove the rotor pulley or spring to replace the rope. This is the area that causes so many guys a lot of extra trouble
2) locate the string that is left and the hole it is threaded thru
3) determine how much string has broken off of the rope that came out
Note: if more than 1 inch is left, then the rope needs to be replaced
4) after rope is obtained, make sure both ends are melted to a point for easier threading thru handle and rope rotor
5) install the rope (with the handle installed on one end) thru the recoil housing and towards the rope rotor.
6) with the rotor free of tension, route the rope from the groove toward center and up thru the hole. Tie a knot in the end of the rope, leaving a 3/8" tail free.
7) wind the rotor in the direction of what the rope would pull (this will tighten the spring) until the spring is completely wound. remove 1/2 to 1 revolution, and then allow rope to wind onto the rotor until all rope is wound.
8) Pull the rope several times to position rope properly into rotor.
*note : there should be NO droop in the handle after released
If droop is evident, wind the rotor and rope 1 revolution tighter so there is no droop of handle when released
9) when unit is functioning proplerly, re-install housing onto unit
Nov 21, 2009 | Craftsman Garden
Where to get a new pull string for blower?
Any lawn & garden outdoor power equipment dealer
Lowes, Home Depot, Menards: get a recoil rope and handle for a Briggs push mower
Nov 13, 2009 | Homelite 'Yard Broom' Leaf Blower
I have a craftsman leaf blower model 335879770. The pull start doesn't engage. You can pull the cord and it recoils back but doesn't crank the engine. I have it apart but how do I get to the starter pulley...
you shouldn't have to there are little ears on the flywheel that the starter recoil hits when pulling the handle they might be stuck or not moving when pulling handle
Nov 09, 2009 | Garden
Gas leaks from air filter. sears craftsman leaf blower,chipper.
engine is flooded,
spark plug fouled,
choke has been on too much while pulling recoil rope
ignition coil or switch is malfuncitoning
Nov 07, 2009 | Craftsman Garden
How do i untangle the pull cord on my leaf blower, it is jammed inside (210MPH/450CFM Craftsman)
just tack the recoil off they are usually easy to remove do to the nature of the part then you should be able to unwind and untangle. in the future dont let go of the cord until it is wound back up that will elininate the back lash and tangling
Oct 31, 2009 | Craftsman 4 Cycle Blower/Vac
When I pull out the coil to start my gas blower, it doesnt "recoil" on its own??
The recoil spring is broken, jammed, or has come lose from either end of it's attachment points. This will require disassembly and most likely replacement of the spring.
Good Luck
Dec 27, 2008 | Craftsman 4 Cycle Blower/Vac
Garden Logo
151 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
