Question about Copystar CS-1815 Printer
Copystar CS-1815 waste toner
I've got the waste toner error c7980 and am trying to fix the problem. No service techs in the area and need to figure out the problem asap. any solutions out there?
  • Anonymous May 12, 2008
    Have the Code 7980 on CS1815. Not sure how to fix this error.
There are two screws on the drum unit. They are on the left hand side and one on the right hand side. Remove the screw from one side and take off plastic small side cover. Dump the waste toner. Do the same for the other side and then put it back together. Turn machine off then on and the error code should be gone......
Posted on Aug 06, 2009
CHECK PROCESS UNIT- DRUM
Posted on Jul 18, 2008
C7980
waste toner is full,,emptying it will get rid of the code!
Jan 29, 2014 | Kyocera Mita KM-1815 All-In-One Laser...
Error code C7980
This code relate to the waste toner sensor, which means your waste toner tank is full, what you can do is, take out the imaging unit(is the unit where the toner sit) look at the lower sides, there is screw from each side, take off the screw and dump the waste toner out.(use plastic bag because it is going to be a mess if you do not use one. If you do not want to go through all this procedure just order the imaging unit and replace it.
Dec 13, 2011 | Kyocera Copystar CS-1820 Black and White...
Waste toner full and now message error occured C7980 call service person
remove the drum unit. on the part of the unit that goes first in machine is the is waste toner container. on each side of the container there is a screw, remove one screw and pull out the cover. slant the unit and the waste will come out
Oct 05, 2010 | Kyocera Copystar CS-1820 Black and White...
The printer shows "Call service person" C7980. What is the problem and how can it be corrected?
this a drum unit related problem. empty the waste toner and the error will reset automatically
Aug 27, 2010 | Kyocera Copystar CS-1820 Black and White...
What is error code c7980
this is drum related error. empty waste toner from the drum unit
Aug 20, 2010 | Kyocera Copystar CS-1820 Black and White...
My kyocera copystar CS-1815 shows in the message screen "Waste toner near full." How do I empty the waste toner?
Hi there just open it up and inside there will be a small plass bottle that hold the waste toner you can clean out and put back.
Mar 04, 2010 | Copystar CS-1815 Printer
What is code c7980 waste toner is full???
C7980, Defective waste toner sensor or engine board. Try this, shake the process unit from side to side and turn the power switch off and then on. If the problem cannot be soved, replace the process unit. After replacing the proces sunit, turn the power switch off then on. If the problem cannot be solved, replace the waste toner sensor or the engine board.
Aug 03, 2009 | Kyocera Copystar CS-1820 Black and White...
ERROR CODE "C7980". I HAVE ALREADY EMPTIED THE TONER WASTE. WHAT DOES IT MEAN AND HOW DO I FIX IT?
Hello sir; The code you display which means waste toner bottle full, just dump it .
May 12, 2009 | Copystar CS-1820 Copier
SERVICE ERROR c7980
The errorcode comes up when the waste toner is full.
Unfortunately the waste toner collection is in the process unit.
You will have to replace the whole cartidge.
Dec 05, 2008 | Copystar CS-1820 Copier
Copystar CS-1815 Printer Logo
485 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Adorjani Laszlo
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
