You Tube has no sound with anything I wanna watch. My speakers work and turned up when I tested it with I tunes.
    President:
  • 548 Answers
Check the Window Audio process. Right click on My Computer- Manage- Services and Applications- Services- scroll down until you find Windows Audio- restart the process and put the start up type to automatic.
If you need further assistance, leave a comment
Posted on Jul 04, 2010
The sound on my Magnavox CD130MW9 stopped working
If the problem is same with different input devices and you have ensured the are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 21, 2012 | Televison & Video
I turn the volume all the way up & it still sounds low,i even changed my speakers.
I have an acura legend 1994 and I'm having same problem, the volume will work correctly once in a while when it wants to, otherwise I have to turn the volume on high and not even get a good sound or can nearly hear anything. I wanna know why, is it a fuse? Or electrical?
Jul 12, 2011 | 1994 Acura Legend
I hooked up the boston speakers 4 plus wolfer and when I play music on You Tube, the rear speakers don't play. They work in the sound "test." They also work when I set the speakers...
the sound on utube is only stereophonic, hence you will get only stereo putput. If you play anything recorded as quadraphonic or above all your speakers will give sound output.
Jun 22, 2011 | Boston Acoustics MicroMedia Computer...
Distorted sound in channel
PLEASE :) wear saftey goggles, no jewelry or watches while troubleshooting a live amp. Tube amps have up to 600V dc on some points so rubber gloves will improve the saftey margin. My primary suggestion is to take it to a pro. Please be safe if you are inexperienced. I can't be liable for my fixya suggestions.
I think you meant "changed" Left speaker with Right Speaker and visa versa. Some receivers have speaker A and B selections from a switch on the front, which is why I ask. I think you tried each speaker on the bad channel to find if the speaker was blown. If the speakers are OK make sure that the speaker wiring is good too. Sometimes they can be compromised so use two short lengths of new wire for trouble shooting. Try the other functions like tape, cd, phono, aux, dvd, ect. and if there is no problem with them then it is your tuning system. Check your antenna first. Make sure you are tuned to the station with max power received. Sometimes you can lose Stereo with analog tuners or be tuned to a harmonic frequency close to the target frequency. Check all of the fuses. Sometimes slo-blo fuses can blow incompletely resulting in a high resistance that causes a voltage drop. If the problem is still there you have trouble in the RF receiving/pre-amplification circuit or blown components in the output transformer/tube/transistor circuit. This is verified by having the same problem with the other functions above. In either case, you will need to take the unit to a repair service or get a service manual and test your voltage points to determine which components are bad. Without a service manual, I would start with the Left output transistor. Check the AC and DC voltages with respect to ground (chassis or negative output/input) on the good channel at all nodes and compare them to the same ones on the bad channel. Again, start with the output circuit for the amplifier. There will be one or more transistors per channel. They will be screwed to a heat sink. Also look for brown, cracked or melted components. Keep in mind that replacing these does not necessarily fix your problem as there is usually a failure elsewhere which caused them to go bad. Work your way back to the actual input signal and you will have hopefully found the problem. Good luck, be careful, and seek some local advice from your friends or repair technician. Happy Shooting!
Jul 08, 2009 | Pioneer Audio Players & Recorders
Center and rear speakers not working
In regard to the rear speakers, my system is an LG and the rear speakers will only work if the format that i'm watching (TV, DVD) is in Dolby surround sound 5.1. Normal tv will not give you surround sound unless it says otherwise, usually it will flash up on the screen at the start of the show. So test the unit with something that you know is in 5.1
Jun 26, 2009 | Audio Players & Recorders
Cannot hear anything but speakers are fine. hooked up to directv box, LED tv and blue ray player.
It may be that your hdmi wires are damaged or plugs are loose. Try to tune it.
May 06, 2009 | Audio Players & Recorders
No sounds
Test one speakers at other amp to ensure its working. Amp is going into probable protection mode. Disconnected all speaker and av wires (only power) turn up volume and see if it stays on. If not sounboard or volume function faulty. If on, connect one speaker L or R. Go to tuner mode to tuned radio station an listen for sounds. If sound connect speakers and av cables one by one and test each one on its own until amp switches off, or no volume. Investigate from there were prolem is.
Feb 25, 2009 | Pioneer VSX-D710S Receiver
Radio plays sometimes, won't others. is getting power, fm stereo indicator lights up when tuned in to a station, but no sound from the speakers, not even static
maybe the amplifier inside is failing if you turn it all the way up for a second and it comes on then it is the amp but if you wiggle the vol and it comes on the its the vol switch
how did the speakers sound ?
Oct 11, 2008 | Emerson PD6810 CD Boombox
Speaker squeal
ok if you dont wanna replace the audio output ic in this set you can simply disconnect the speakers in the set but tape them up so they wont short out against anything and then you can run the sound into your sound system of choice if it has an audio outputjack
Apr 01, 2006 | Sharp 25R-S100 25" TV
Computers & Internet Logo
David Payne
David Payne
