Question about Pool & Spa
Have an Old Circa 1990 Versa in-ground pool heater. Worked fine until this weekend. Haeter wouldn't start so I replaced pressure switch. After replacement still wouldn't start so I shook unit and it started shut down tried again 10 minutes later and it started. Today tried everything and won't start. What else can I check?
  • 366 Answers
Check all the electrical connections for corrosion. The older millivolt heater run on less than one volt and it's critical that all connections are making good contact. Clean as many of them as you can. You can also try replacing the pilot generator/assy as they lose power over time. Test to make sure output is more than 500mv.
Posted on Jul 04, 2010
Rapak above ground pool heater is leaking from the bottom
leak is prolly from pressure switch connection or heat exchanger...... if from heat exchanger buy a new heater
Aug 20, 2010 | Raypak Versa 130,000 Btu Above Ground...
Heater not coming on
if voltage to unit then check transformer if voltage see if voltage to gas valve when igniting also check pressure switch
May 22, 2010 | Raypak Versa 130,000 Btu Above Ground...
Pool heater works intermittently. have replaced thermostat kit
Depending on model you will need to ck ethier millavoltes (1/2 to 3/4 of a volt)or 24 volts. but this sounds like a pressure problem. Start by cleaning your basketsand your filter. If this dosn't help you should pull the presure switch from the manifold on the heater and see if their is any corrosen or rust on the sw or in the manifold. One of these should fix your problem. Good luck.
Nov 24, 2009 | Raypak Versa 130,000 Btu Above Ground...
Heater is new, installed at grade on above ground pool that is 48" deep so pressure switch is 3' below the water line. With pressure switch adjustment turned fully clockwise the heater will run without the...
Adjust the switch fully in the opposite direction. If you are at 1.5 you are at the light end of the adjustment range of that switch, which can be adjusted up to 5psi. Then let it back off until it works reliably. Rarely do you need to adjust a pressure switch on an above ground pool so it should end up about in the middle of the adjustment scale.
Jul 09, 2009 | Hayward H250FDN Low NOx Natural Gas Pool...
Pool heater will not ignite
check pressure switch,if it is faulty or out of adjustment it wont allow it to go tomain burner
Jun 17, 2009 | Hayward 100,000 BTU Pool Heater H100ID1 -...
Have a Triton Millivolt pool heater pilot is lit and nothing!!
Low out put voltage from the pilot generator and/or an open circuit in the control circuit...the most common is a bad pressure switch (dirty filters can hamper pressure switch operation).
Jun 08, 2009 | Pentair PUREX MINIMAX HEATER; THERMOSTAT,...
Low pressure reading on Pool Heater
I had this problem with ours last year. I replaced the water pressure switch and it began working fine. We later had a symptom that the blower would start but it would not ignite. The ignitor rod was corroded so I took it out and sanded it with some sandpaper---worked fine...until I dropped it trying to reinstall and it broke. Bought a new one and it works fine now.
Today's problem is related to the blower now.... it is always something, isn't it?!?
May 10, 2009 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Pool & Spa Logo
54 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
