Question about SanDisk Sansa Fuze MP3 Player
The screen is stuck, it won't move. What do I do?
    President:
  • 2,923 Answers
If the screen is stuck and won't move, then it's a program issue. The only thing that you could try is to disconnect the battery (if the player is OUT of WARRANTY). You might need to de-solder the battery and re-solder it.
However, if the player is under the warranty period, there's nothing that could do but to send the player to the manufacturer. They need to re-program the player, re-load the software and firmware if necessary.
These are the things that will solve your problem.
Thank you and good luck!
Posted on Jul 04, 2010
  • noahjosephs Nov 17, 2010
    Had the same problem. First try holding the the side REC and Power Buttons at the same time for 15 secs. The system should restart and refresh the database. After I did this - had no problems at all.
  • Melvin Ramos
    Melvin Ramos Nov 18, 2010
    Are you saying that it's working fine now? If yes, then that's a good new. But if the same problem happens, then contact the manufacturer.
Rgx4634kq2
make sure push start switch is not stuck pushed in.Also sounds like the switch mounted on the motor could be stuck, which means new motor. Does motor start and stop with timer being moved to the off position ?.If so then not the motor.
Jul 01, 2013 | Dryers
Washer hums but will not fill or start/ spin has water pressure and tub seems to move freely the model #on tag LTF2140ES0
If it doesn't fill it won't start any other cycle unless you move it ahead yourself. If it hums I am thinking it is trying to fill. Sounds like the valve is turning on to let water in but it is not getting through. My washer has a screen where the hoses go on and sometimes the screen becomes plugging with scale. If that is ok then the solenoid must be coming on but the valve is stuck. Does neither hot or cold settings work? Please rate my answer so I am rewarded points for it.
Jan 27, 2012 | Frigidaire Washing Machines
It's stuck in place and won't move either left or right. When I hit a key it types that letter, but the paper doesn't move to the next space
If it is stuck in the middle of the page it probably has a carriage lock usually just below the carriage on the R. or L. side.
DickyO
Oct 12, 2011 | Olivetti Lettera 35 L Typewriter
GEAR SHIFT STUCK IN PARK HAVE NO BRAKE LIGHTS
check the fuses as if the brake light fuse is blown it won`t allow the shifter to move out of park.it has a shift interlock system so the gear shift won`t accidentally be moved out of park by mistake.
Jul 17, 2011 | 2000 Lincoln Continental
Kid trackball
A lot of trackball controlls made by Microsoft and Logitech use a optical system. Once the control on the screen doesn't move anymore, you simply remove the ball and clean the optics out of it.
If there is a way that you can remove the ball out of the control, all you have to do is clean the rollers underneath the wheel. After some time they do build up just like a friction mouse does. All it takes is some Qtips and a water alchohol solution.
I would hope for a kid trackball they made that a feature.
Oct 31, 2008 | Microspeed KidTRAC Trackball
SanDisk Sansa Fuze MP3 Player Logo
96 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
