Verbatim 8 gb won't format says it is write protected and have lost my invoice and can't return it.
    Sergeant:
    Champion:
  • 293 Answers
Goto control panel select performane and maintenance then administrative tools then computer management and then disk management then choose the 8gb right click and format it using ntfs partition
Posted on Apr 17, 2008
How to remove the write protection from a 8 gb verbatim
If you mean a Verbatim SDHC card, it has a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 08, 2012 | Cameras
Verbatim usb drive 8 gb help
I would like to give you some solution steps. However you haven't indicate your Operating System. So please let me know the operating system (XP, Vista etc)
Feb 04, 2008 | Verbatim STORE-N-GO (95312) 8 GB Hard...
I accidently formatted my Verbatim STORE-N-GO (95312) 8GB. I can now get only 2GB. Is there a way to fix this?
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select
check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
click start click on computer then right click on your kingston usb drive select format
hope this helps you
Nov 09, 2011 | Verbatim STORE-N-GO (95312) 8 GB Hard...
I have just bought a Verbatim 4GB PinStripe USB Drive. My Windows 7 computer at home will not recognise it, and nor will most computers at work (Windows xP Professional). The shop replaceed it, but the...
Hello John,
The Store 'n' Go PinStripe USB Drive from Verbatim has a push and pull sliding feature which protects the USB connection when it is not in use without the need for a separate cap which is easily lost.
Aug 16, 2011 | Verbatim STORE-N-GO (95312) 8 GB Hard...
VERBATIM 8GB FLASH DRIVE CANNOT FORMAT. FILE SYTEM UNKNOWN.CANNOT DELETE FILES ON DRIVE
Hi, try going into 'Control Panel' -> 'Administrative Tools' -> 'Computer Management'
Then, under 'Storage', choose 'Disk Management' and try formatting from there. If necessary, give your usb key a drive letter.
Mar 07, 2011 | Verbatim STORE-N-GO (95312) 8 GB Hard...
My Verbatim 4gig store and go usb stick in stuck in RAW Format
right click my computer, manage. go to disk management and delete any volumes on the flash and set back to basic disk if it's dynamic. format fat 32
Mar 14, 2010 | Verbatim STORE-N-GO (95312) 8 GB Hard...
I need to remove the write protection so I can use the device
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Feb 02, 2010 | Verbatim STORE-N-GO (95312) 8 GB Hard...
I can't format verbatim flash drive. it say write protected.
Click > Start > RUN > type "CMD" > type "CHKDSK" and the letter of the stick and "/F". Ex. chkdsk Q: /F > Enter
Nov 26, 2009 | Verbatim STORE-N-GO (95312) 8 GB Hard...
Verbatim USB 8GB file copy problem
ITS virus problem which is playing with the inf file of the usb drive.
also another possibility is 1) the usb port ihas loose connections and disconnects i between drive sensing
2) certain 8 gb drives go back to a capacity of 2 gb drive if one formats it accidentally .
Sep 18, 2009 | Verbatim STORE-N-GO (95312) 8 GB Hard...
Pendrive is not formatting
You need to change your pendrive as there is a manufacturing defect which generally arises after some time of using pendrive
Jun 09, 2009 | Verbatim 500GB USB Desktop 500 GB Hard...
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
