Question about Tappan TGF320 Gas Kitchen Range
Oven wont light
Oven ignitor comes on but the flame wont light
    President:
  • 1,015 Answers
This can be caused by a weak/inop hot surface igniter or a defective gas control valve.
One thing that you can try(be very careful doing this) is to give the gas control valve a light tap with something hard like a wrench when the oven is turned on and the igniter is glowing but the burner is not on. You will need to remove the broiler/storage drawer at the bottom of the oven. Once you pull the drawer out you should see the gas control valve at the back of the range. Try turning on the oven and lightly tapping the valve housing after the igniter is fully on. This may loosen up any debris inside the control valve housing that might be causing the problem. If the oven burner comes on then try completely turning the oven on and back of several times. And when I say completely I mean turn it on after the igniter is not glowing and burner has shut off. This works about 30% of the time. If the burner control valve sticks again after trying this procedure(burner does not come on) then it could be the control valve and/or the hot surface igniter defective. The hot surface igniter would need to be disconnected from it's harness and tested with an OHM meter. Most igniters should have a 500 to 700 OHM reading. If you get a reading that is way off then the igniter is defective and replace it. If the igniter tests good then the gas control valve is suspect and replace it. Most appliance parts retailers will test your igniter for free. When the igniter is on it should glow very brightly. If it is dim then that is a sure sign it is bad. You can also verify that the oven run-away valve is not closed. This valve will be located at the back bottom of the range at the gas regulator. There will be a tab on the regulator housing where the gas pipe goes to the oven. This tab will lift up to close gas flow to the oven. Sometimes these valves can stick causing the oven to stop working. You can try moving this tab back and forth to see if it loosens any debris in the valve. Move the valve while the oven is on and you will be able to hear the burner come on after moving the valve if that was the problem.
Remember be very careful doing any of these procedures. Good luck and have a safe holiday.
Posted on Jul 04, 2010
4 Suggested Answers
Kgt1962
  • 59 Answers
SOURCE: Whirlpool gas oven-Super Capacity 465
When you turned the oven off, if the ignitor went off and the gas kept flowing then the thermal valve is defective. Maybe that was the problem all along.
Posted on Mar 20, 2009
shinn8
  • 85 Answers
SOURCE: oven ignitor will not light flame
When ignitor gets worn it will come on but not get hot enough to open the gas valve. You will need a new ignitor
Posted on May 19, 2009
EllaWatson25
  • 725 Answers
SOURCE: Whirlpool super capacity 465 - Oven won't light
This is your gas valve that is bad on this unit. Please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
with your complete model number and we will get the correct part out to you asap.
We are available from 7 AM until 9 PM CST Monday through Saturday.
Posted on Nov 10, 2009
The main oven flame wont stay on when lighting
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Sep 06, 2010 | Belling FarmHouse 931 Gas Kitchen Range
I have a magic chef oven that will not iginite, the electric ignitor will not come on for the oven but the one for the broiler will, what causes this??
Most likely a bad ignitor. Turn off the gas to the oven. Remove the racks,remove the bottom oven pan. Remove the flame spreader to access the ignitor. Use a volt meter. Inse the probes into the ignitor connector and turn the oven on to bake. No voltage reading is a bad ERC control. If you read voltage you have a bad ignitor.
Nov 25, 2009 | Magic Chef 31000 Gas Kitchen Range
The oven wont light. Panel light comes on and
Attach a amp meter to the ignitor wire. If you read 3 amps or less,replace the ignitor. 3 amps or more replace the gas valve.
Sep 06, 2009 | Ovens
Bottom oven will not heat up.
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Jun 11, 2009 | Maytag MGR6772 Gemini Gas Kitchen Range
Oven ignitor will not light flame
May 18, 2009 | Tappan TGF336F Range
Gas oven wont stay on
If this is electronic ignition, then chances are the burner or ignitor nub has residue on them, preventing the flame detection system from keeping the gas on.
Use warm soapy water and a plastic scrub brush to thoroughly clean the burner cap, burner base, and ignitor nub.
Jan 25, 2009 | Whirlpool GS475LEKS Gas Kitchen Range
Lighting an old Frigidaire gas oven
Sounds as though the pilot light in your oven went out. On the inside of the oven there should be a small hole about the size of a 50cent piece on the floor of the oven. Turn on the gas for the oven, light a matchstick or rolled up piece of paper, stick it into that hole and it should light, monitor the oven for 30 seconds to see if it starts to heat. SAFETY 1st!
Dec 23, 2008 | Ovens
Amana gas range bake burner does not heat
Pull the bottom of the oven off. You will see 2 to 4 screws that hold the panel on. The ignitor is under there. Look at the ignitor carefully for breaks. I say carefully as the ignitor is very easy to break.
Feb 03, 2008 | Ovens
Tappan TGF320 Gas Kitchen Range Logo
568 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
