Question about Weedeater 2 Speed Gas Blower FL1500LE ()
Not getting any spark. what should I check first
  • 7 Answers
Check the obvious first.
  • Is the spark plug in good condition? No cracks
  • Try a new plug
  • Are you sure no wire is shorting?
  • Have you done any recent repairs?
  • Does a new plug get spark??
Try to change the plug with correct gap new plug.
Posted on Jul 11, 2010
No fuel in one cylinder 1998 ford ranger
Either has a bad injector or the wiring to that particular injector has been pinched or skinned and grounded somewhere.
Feb 20, 2015 | 1998 Ford Ranger
What do u do when spark is weak on Yamaha blaster
Check battery voltage, remove spark plug suppressor cap from HT lead and see if spark is good by holding lead in a gloved hand and placing the lead end near the engine. If spark good get a new suppressor cap. Check the plug shows a good spark in the new cap by holding the screw thread to the engine. Poor spark change spark plug. If you get a poor spark from the HT lead then get the ignition coil checked.
Oct 06, 2014 | Yamaha Motorcycles
1985 kawasaki gpz 1100 has no spark and wont start ?
Perhaps a few things to check would be
start switch, spark plug, spark plug cap, ignition coil, ignition lead
Apr 30, 2014 | kawasaki Motorcycles
WINDS OVER BUT WONT START
check for spark from your coil first.then check your ignition leads .use a spark plug tester.if test ok check your spark plugs are getting a spark.and smell them .are they getting fuel .if getting fuel then change your plugs.
Dec 06, 2013 | Holden Cruze Cars & Trucks
The Check Engine light is on, and Auto Zone checked it and said the 3rd cylinder has a misfire. New spark plugs have already been installed. How do you fix this? I need to have the car e-checked soon. ...
Some testing needs to be done to find the problem. May be spark related (ignition)-check if cylinder 3 has spark. You should see a blue, snapping spark when checking at the end of the spark plug wire-you can buy a cheap calibrated spark tester to check for spark. If spark is good, need to check that injector for #3 is pulsing, so the cylinder is getting gas.
If you find it has spark and getting gas, have a compression test done to see if any mechanical problem with cylinder 3, something like a valve not seating can cause misfires.
Aug 20, 2013 | 1999 Dodge Stratus
Car problems
DO YOU GET SPARK FROM DISTRIBUTOR CAR THROUGH HT LEADS TO SPARK? IF YES CHECK YOUR SPARK PLUGS.Also check whether fuel gets in ,
Aug 29, 2012 | Honda Accord Cars & Trucks
Cant get a spark from spark plug
if you have checked or replaced your ignition timing and have power there
trace it back check it from the coil
if no power could be a faulty coil
check for power at the connection to your spark plug lead if its getting power then check it at the spark plug if no power faulty spark plug lead
hope this helps you
Nov 25, 2011 | MBK Skyliner 125 Motorcycles
I checked battery,alternator,and fuel pump,still wont start.?
is the engine getting any spark, disconnect 1 of the spark plug wires and ground it, and have someone crank the engine over to see if it is getting spark, if so, i would check the fuel pump relay in the fuse box under the hood on drivers side. if you didnt get any spark from the plug wire, then i would check the coil, it could be bad since you weren't getting any spark.
Mar 06, 2011 | 1997 GMC Jimmy
Hi, Honda HRG465C Petrol Mower running problem
The first thing to check is the spark plug, is it clean and properly "Gapped" next is are we actually getting spark, does the spark plug actually "Spark". Check. Check Spark Plug lead., Check connections. Do we have Fuel, Check .and Is the fuel getting to the Carburettor? Check. Check the battery. alternator, generator, is providing power. Check the Mixture.
Mar 23, 2010 | THQ The Lawnmower Man
Truck will npt start
check to see if your getting spark, if you are make sure your getting fuel. if no spark check coil primary resistance it should be from 1 to 3 ohms. if your not getting spark it can only be a primary ignition problem not a secondary one, example plugs,plug wires. if you are getting spark but no fuel. pull fuel pump relay and jumper wire together #30 and #87 teminals diagnally across from each other under the relay you just pulled out good luck!!!
Jul 19, 2009 | 2000 Chevrolet Tahoe
Weedeater 2 Speed Gas Blower FL1500LE () Logo
223 people viewed this question
Top Weedeater Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
Darrell
Are you a Weedeater Garden Expert? Answer questions, earn points and help others
