Question about Garden
Got a Ingersoll 4021. Started not turning over intermittently. I started it by shorting the starter selenoid. Next time it started fine. then it wouldn't start with the key. Soon the power clutch was engaged and would not shut off. I replaced the starter selenoid and power take off switch to no avail. Power clutch still stuck in the engage mode.
    President:
  • 1,561 Answers
This is a mechanical fault that will require the knowledge of a mechanic, because the started solenoid and the take off switch you replace are not the problem, the problem seems to me that the power clutch is defective and will need to be work on.
I advice you get a mechanic to help check and fix the problem in other not to complicate issues.
Take care.
Posted on Jul 04, 2010
2011 ford focus 1.8 clicking noise when start engine
Could be several problems - check the battery terminals to make sure they are clean. Next check the battery to see if it is fully charged. If both those items checked are OK then the next step is to check the starter.
Now the starter has a selenoid which engages and provides power to the starter motor when you turn the key to the start position.
If you only get a clicking noise then it could be the selenoid valve itself or the starter motor.. Some fords have the selenoid mounted on the firewall others are mounted on the starter motor itself.
So what you need to do next is bypass the selenoid valve and provide power directly to the starter - if the starter turns the engine over then the selenoid valve is the problem. If the starter motor doesn't turn the engine over then it's the starter motor and a replacement is necessary.
Hope this info helps.
Feb 22, 2015 | 2011 Ford Focus
What should i do when i replaced my alternator and got a new battery, and the truck still needs to be jumped started after two days. what could be the problem??
Sounds like you need a new starter. Did you check it out before you replaced the alternator and battery?
Some vehicles have a seperate selenoid on the firewall that engages when you turn to switch to start the engine. Others have the selenoid mounted to the starter. I
I would first bypass the selenoid valve and provide power directly to the starter motor. If it starts then it's the selenoid. If it doesn't then it's the starter motor - may have a flat spot in the windings or possibly burned but not shorted windings in the motor.
Jul 06, 2014 | 1998 GMC Yukon
Starter problem 1997 FLSTS
see the diagram attached, and by pass it . GOD BLESS YOU07b0a924-114d-4fdb-a9c3-005a442421f7.gif4c66c703-1a35-40c8-931c-f38f83eeeeca.jpgHowever if the problem persist you must replace the starter unit.to out tolerance parts.
God bless you
Jul 11, 2013 | Motorcycles
Sterter problem
your safer bet is a new starter because if you are having those kind of problems its not long before more starts to happen, bad bushings etc. buy a new starter
Jul 11, 2013 | 1993 Harley Davidson FLSTF Fat boy
EXPEDITION WOULDN'T START, JUST CLICKED. REPLACED BATTERY AND IT STARTED. NEXT DAY SAME THING. REPLACED THE SELENOID. STILL JUST CLICKING. WHAT NEXT?
I would have to say it's the starter itself. When you replaced the battery it most likely had enough power to turn the starter which is probably dragging. If that is in fact the case, I'll bet that it starts fine when jumped.
Apr 23, 2011 | 1998 Ford Expedition
Intermittent starting
the starter selenoid is most like bad or you could have a short in the wire to your starter causing heat to build. Heat causes battery to not be able to turn the cars engine. waiting lets the resistance to disapear. and the cycle continues
Jun 20, 2010 | 2005 Jeep Grand Cherokee
Intermittent starting problem. Turning key does nothing.
Sounds like you could have a faulty switch, but I would check the starter selenoid first. Sometimes when the selenoid goes bad it will behave in the way you describe. If, with your key in the on position, (not on start), you can jump power from the hot wire, (positive), post on your selenoid to the hot wire that goes from the selenoid to the starter and the starter then engages, but doesn't otherwise, it is a selenoid problem. Good Luck! I hope you find this very helpful!
Dec 16, 2009 | 2003 Subaru Legacy
2005 2500HD Duramax starter won't engage when cold (intermittent)
check operation of the ignition switch spray some lockease w/graphite into actual cylinder where key is inserted.
Nov 22, 2008 | 2005 Chevrolet Silverado 2500HD 2WD
Starter won't turn over,I shorted selenoid with screwdriver and it kicked in selenoid and started,,ok bad selonoid,,I just replaced with new starter and selonoid,,still won't kick seloniod in,,shorting...
That wire may be coming from a relay so you may need a service manual to find which one it is.
BTW, to save frying all of your screwdrivers, applying 12 volts for a moment to the terminal with the smaller gauge wire will cause the solenoid to operate as it was designed. Shorting across the main solenoid terminals lets ~ 100-200 amps flow through your screwdriver which isn't even a very good conductor.
Even a light clip lead to the coil terminal of the solenoid could handle the lower current that flows there.
For purposes of doing several different engine tasks, I made up a momentary pushbutton switch contraption housed in a plastic film canister, put 6' wires and heavy clips on it so I could 'jiggle' an engine into the next cycle.
Oct 12, 2008 | Buick Skylark Cars & Trucks
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
