Question about Husqvarna 165HP 42" Lawn Tractor
Engine backfires when the engine is turned off ??
  • 394 Answers
I was wondering if you slow the engine to idle before you
turn it off.
Wayne
Posted on Jul 04, 2010
I have a ford cvh 1600 what backfire through carborator only when it is hot and then lose its power
Ford Escort carb backfire Questions & Answers - Fixya
www.fixya.com > Forum > Tags > carb backfire > Cars & Trucks > Ford
Ford Escort cars & trucks carb backfire questions and answers. ... Backfire throughcarborator and engine stopped upon returning from store. ... Turbo conversion from 1995 on a CVH engine - engine cuts out ... I have a xr3 ford escort 1600 with a weber carb,itbackfires and spits fuel up Clean the Carburator completely.
I have a xr3 ford escort 1600 with a weber carb,it backfires ...
www.fixya.com/cars/t10838117-xr3_ford_escort_1600_weber_carb
Nov 17, 2011 - I have a xr3 ford escort 1600 with a weber carb,it backfires and spits fuel up ... Turbo conversion from 1995 on a CVH engine - engine cuts out.
All comments on Ford Escort CVH Straight-through exhaust ...
https://www.youtube.com/all_comments?v=1yA5blCpTLM
Jan 05, 2016 | Ford Cars & Trucks
Why does my 318 lawn mower back fires
Charlene: According to https://www.briggsandstratton.com/us/en/support/faqs/engine-backfire-afterfire " What causes a small engine backfire & how do I fix it? Backfire typically occurs when the engine is decelerated rapidly.
Common Causes of Backfire:
  • Lowering engine speed too fast
  • Gasoline, which contains higher blends of alcohol
  • Carburetor adjustment set too lean
  • Muffler construction can induce backfire
  • Higher than normal engine temperatures
  • Some carburetors can induce backfire due to the sensitivity of internal transitional passages
    (This condition cannot be corrected).
Possible Fixes for Backfiring:
  • Lower engine speed slowly
  • Follow small engine fuel recommendations and/or switch to brands with low or no alcohol
  • Adjust carburetor for optimum performance
  • Inquire with equipment manufacturer about increasing air volume to decrease engine temperature"
Charlene: I hope that helps! :)
Charlen
May 28, 2015 | John Deere Garden
2003 mazda 6......2.3 L engine will not start and backfires
CAR NO START PROBLEMS:-----
It can be the issue with weak battery or faulty battery or if battery is ok,then its faulty starter causing the issue.
From start to end troubleshooting these problem i suggest you to click the link below and follow its procedure:-----
What to Do When Car Turns Over But Won't Start?
http://technoanswers.blogspot.com/2012/11/what-to-do-when-car-turns-over-but-wont.html
Feels like backfire from engine when decelerating?
http://schematicsdiagram.blogspot.in/2012/02/feels-like-backfire-from-engine-when.html
Jeep Backfires?
http://technoanswers.blogspot.in/2012/02/jeep-backfires.html
Nissan Pathfinder Backfires?
http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-backfires.html
Car starting issues?
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
Car Starting Problems
http://whoisbyme.blogspot.in/2012/06/car-starting-problems.html
1991 Toyota Trecel: Engine Starts fine but dies when gets Warm?
http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
1994 Toyota Pickup: Starts fine but dies in few seconds?
http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
1999 Chrysler Cirrus: 8 IGN Fuel Starter Fuse Blows?
http://whatisbyme.blogspot.in/2012/06/1999-chrysler-cirrus-8-ign-fuel-starter.html
2001 Toyota Camry: No start After replacing Battery?
http://whatisbyme.blogspot.in/2012/05/2001-toyota-camry-no-start-after.html
1989 Toyota Pickup Truck: Turns over but not start?
http://whatisbyme.blogspot.in/2012/05/1989-toyota-pickup-truck-turns-over-but.html
Car dead and will not Start?
http://whatisbyme.blogspot.in/2012/05/car-dead-and-will-not-start.html
1995 Lexus LS400: Running Hot?
http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html
2001 Toyota Prius will not start?
http://whatisbyme.blogspot.in/2012/05/2001-toyota-prius-will-not-start.html
1996 Jeep Grand Cherokee: Engine will not start?
http://repairhelpcenter.blogspot.in/2012/06/1996-jeep-grand-cherokee-engine-will.html
Mitsubishi will not start
http://www.howtorepairguide.com
These will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
2002 neon revs up to 4000rpms at start and idles up an ddown 1500rpms-2000rpms after. and begins to backfire near engine .
Engine system needs inspection on case of backfire:-----
Check out related help links to troubleshoot the vehicle backfire issues:-----
Jeep Backfires?
Nissan Pathfinder stalls and bucks on Acceleration?
http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-stalls-and-bucks-on.html
These will help.
Thanks.
Nov 28, 2012 | 1995 Honda Accord
What causes the 2002 nissan se r to backfire
Sounds like an ignition or timing problem.
Is the check engine light on ?
This engine uses a direct ignition system which means each cylinder has a coil on top of the spark plug. It could be as simple as worn out spark plugs.
If you had said the engine backfired and was hard to start, but no flooding, I would also look at low fuel pressure. But too much fuel causes flooding.
A faulty throttle position sensor could cause all of your symptoms, but it should set a trouble code and turn on the check engine light.
Jul 06, 2012 | 2002 Nissan Sentra
My lt1000 turns over and while turning over backfires. does not start. Started backfiring a couple weeks ago while in operation. would backfire, engine would die, wait a few and started again. finally,...
The engine should be an OHV type. You could try adjusting the valves under the OHV cover. Kinda like the valve lash on cars. When the valves are at rest you can set each one to about .004 with a feeler guage. You can look on youtube for a video one adjusting lawnmower engine valves. Seeing it is easier to understand then reading it.
I hope that this helps you get it fixed.
Jul 17, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Rough idle, sputtering, and backfiring.
try turning ur idle up its the pin on the throtle body just make sure u tuen the engine off and on again fter each adjustment to reset ur computer on ur engine
Apr 04, 2010 | 1994 Oldsmobile Eighty Eight
Backfire - Husqvarna YTH20K46
I find my 2148 runs much happier on the medium grade shell than on the cheaper gas. I did have a nasty POW, which resulted in bent pushrods, or perhaps the bent pushrods caused the POW. After replacing the pushrods, and adjusting same, the backfiring stopped altogether. knock on wood. The 21 is a B&S engine which has a propensity to the bent pushrods. Fortunately for me, my neighbor is a wiz at those fine adjustments.
Mar 22, 2010 | Husqvarna 23 Hp 48" Deck Yard Tractor
No idle &bacfires on deceleration
hi mate on the carb you will find 2 screw 1 is for the idle and the over is for mixture the idle one will be the furthest out screw it in 1/4of a turns will the engine is running this will take the idle up on the engine and the backfiring is fuel in the exhaust not being burnt so on the over screw on the carb screw that in 1/4 of turns this will decrease the amount of fuel going into the engine if it still backfires screw it in 1/4 of turns again and see what difference it makes good luck
Jul 10, 2009 | 2004 kawasaki KX 250 F
Husqvarna 165HP 42" Lawn Tractor Logo
156 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
