Question about Pentair Minimax NT Heater
What is E02 CODE - Pentair Minimax NT Heater
    Top Expert:
  • Pentair Master
  • 5,075 Answers
High temp sensor check gas pressure or burner tubes
Posted on Oct 07, 2017
Hi im ishaq I bought a washing machine of hover on display shoing a code e02 and the drum will full of water plz how can I salvage
An E02 code indicates a trapped, blocked, or pinched fill hose or a problem with the water supply or fill valve.
Mar 02, 2015 | Washing Machines
How can I delete E02?
Depends on the make and model but an Error code E02 on most washing machines is slow water flow probably caused by a blocked filter! Remove panel on front bottom left or right side and clean filter! Should then clear error itself!
Oct 21, 2014 | Washing Machines
How the error e02 on fit king treadmill be repaired
Dear sir,
I am having a treadmill of Fitking model no. W590 it is showing error code e02.
Kindly suggest what to do. I am eagerly waiting for ur response
Rgds
Yash Pal
Jul 15, 2013 | Exercise & Fitness
How to solve Error Code E02 always appear
Error Code E02 means paper jam.
Solution
1. Unplug the power cord and USB cable.
2. Lift the printer upside down, then shake the printer.
3. This is done, to remove foreign objects, which get into the roller.
Causes of damage
Solution
Oct 27, 2011 | Office Equipment & Supplies
Lay z spa pump has E02 code which is water flow problem,have changed filter.flushed through ,set reset button but fault code still appears.
If this is an outdoor spa near trees, its almost a guarantee that the impeller is blocked with debris (pine needles can cause this in a hurry)
If the impeller is clean of debris and this is still happening, replace you pressure/flow switch.
Apr 27, 2011 | Pool & Spa
Risograph GR 1700 E02
check the Paper Feed Tray.. is there something in the way? does it go up and down? if it is all the way up or down maybe it got pushed off the rail?
Mar 11, 2009 | Riso Office Equipment & Supplies
DP-1820E - Contact Your Dealer - Printer Error E02-01
E02-01 refers to the tray 1 lift motor either you have a bad motor or there's a problem with your main board. good luck
Apr 23, 2008 | Panasonic Workio DP-1820E Copier
ERROR CODES
In the case the encoder position is not shifted
to the next point though the loading motor has
rotated in the unloading direction for 4 seconds
or more. This error is defined as [E02].
Oct 14, 2007 | JVC GR-AXM17U Camcorder
E02 Code
Faulty heating element, or main eprom is faulty
Jun 30, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Pentair Minimax NT Heater Logo
215 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
