Question about HP PSC 1315 All-In-One InkJet Printer
Encoder strip Hey Guys! My 1 year old made it to the printer & pulled out what I have finally figured out is the encoder strip. It is in fine shape, but there is a small hairline tear in it on the far right tab. I don't even know where this goes. Can it be fixed easily & quickly by me, or is it better to take it to a shop? Would that be a costly repair? THank you, I desperately need this up and running ASAP.
  • 20 Answers
If you can access to the encoder strip, try to clean it by damp cloth or detergent liquid. Wipe it with holding the stripe along the way.
Posted on Apr 18, 2008
Hardware error 0502 from A dell 940
Here is how to fix error 502.
Rick
» Reposition the Encoder Strip on the A940 All-In-One Printer
To reposition the encoder strip, perform the following steps:
  1. Remove the power cord from the unit.
  2. Lift the lid of the unit, just below the scanner portion of the All-In-One, to expose the inside of the unit where the printer cartridges are located.
  3. Gently slide the ink cartridge carrier to the middle of the printer.
Figure 1: Out-of-position encoder strip
  1. Gently move the top part of the printer belt to the right.
  2. Using your index finger, gently push encoder strip down and then back up to get it back into the slot located on the back of the ink cartridge carrier.
new_note.jpg Note: There is a small slot that the encoder strip fits into, which is located on the back of the ink cartridge carrier.
While working with the encoder strip, check it for dust or any unclean spots. If any detected, try to clean the strip by wiping it gently with clean cloth.
  1. Gently press the strip first to the rear and then forward to ensure that it is seated correctly.
  2. Manually move the ink cartridge carrier to the left, then to the right to check the positioning of the encoder strip.
Figure 2: Correctly seated encoder strip
new_note.jpg Note: If the encoder strip moves at all, it has NOT been repositioned correctly.
  1. Once the encoder strip has been re-seated, close the lid to the unit.
  2. Re-connect the power supply to the All-In-One.
  3. Press the Power button. If the encoder strip was re-seated correctly, the Hardware Error: 502 code will not appear.
Jun 14, 2011 | Dell A940 All-In-One InkJet Printer
My printer shows "Hardware Error
Feb 18, 2011 | Dell A940 All-In-One InkJet Printer
"Print carrier stall"?
Error 0502-Carrier Stall indicates a physically blocked carrier. This condition can occur for many possible reasons. Most often, the carrier is blocked because the ink cartridge lids are open while the printer is on (Figure 1).
Figure 1: Open Ink Cartridge Lids
Reseat the Ink Cartridges and Make Sure the Lids Are in Place
  1. Make sure the printer is turned on.
  2. Lift the printer's front cover.
    new_note.jpg Note: The ink cartridge should be in the up/loading position unless the printer is busy.
  1. Squeeze the tabs on the cartridge lids and lift the cartridge lids up. The cartridge pops up when the lid is fully lifted.
  2. Remove the cartridges.
  3. Make sure that all of the protective tape has been removed from the contacts on the ink cartridge.
  4. Replace the cartridges.
  5. Snap the lids closed.
  6. Close the printer's front cover.
  7. When prompted on the printer's LCD to choose New or Old, choose Old.
  8. Press Select.
new_note.jpg Note: For more information about reseating ink cartridges, refer to the Maintenance or Ink Cartridge Maintenance section in the Online User's Guide.
Back to Top
  1. Remove the power cord from the printer.
  2. Lift the scanner unit to expose the inside, where the printer cartridges are located.
  4. Gently move the top part of the printer belt to the right.
  5. Using an index finger, gently push encoder strip (Figure 1) down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
    Figure 1: Inkjet Printer Encoder Strip
  6. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
  7. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
  8. Once the encoder strip has been re-seated, close the scanner lid.
  9. Re-connect the power cord to the printer.
Jul 18, 2009 | Dell 922 All-In-One InkJet Printer
Dell Printer A940 Hardware error
Back to Top
» Reseat the Ink Cartridges and Make Sure the Lids Are in Place
  8. Press Select.
Back to Top
Jul 03, 2009 | Lexmark X5150 All-In-One InkJet Printer
Printer 964
  8. Press Select.
Back to Top
If this information has not solved your issue, then you have to contact Dell. They may need to replace the printer.
Jul 02, 2009 | Dell Photo 964 All-In-One InkJet Printer
Dell AIO 924 Carrier Jam Problem
To clean the encoder strip, perform the following steps:
  1. Power down the printer and unplug the power.
  2. Lift the cover on the printer.
  3. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer99d8177.jpg
Figure 1: The Encoder Strip to the right of the cartridge carrier. The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting.
  1. Plug in the printer and power it on.
  2. Open the cover to allow the cartridge carriage to center itself.
  3. Using a dry, lint free cloth, pinch the encoder strip on the left-hand side of the cartridge carriage and pull your fingers across it towards the left-hand side of the printer. 43e0b19.jpg
Figure 2: The encoder strip to the left of the cartridge carrier.
Nov 16, 2008 | Dell 924 All-in-One InkJet Printer
Clear carrier jamed
There could be 4 possibilities.
1. Ink cartridges lids are open which is not allowing cartridges to move freely.
2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
3. Encoder strip is Dirty.
4. Encoder strip is Out of position.
Solution:
1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
4. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Oct 20, 2008 | Dell 924 All-in-One InkJet Printer
Paper Jam wont clear and there is no paper in it
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} When printer does not have visible paper jam and printer is showing error paper jam
Check if the Encoder Strip is Broken or Missing
1.Power down the printer and unplug the power.
2.Slide the cartridge carrier inside the printer a couple of inches to the left.
3.Locate the encoder strip (Figure 1) on the right-side of the cartridge carrier encoder strip
Note:
The encoder strip is a plastic strip with small markings over its entire length. The strip may appear to be translucent.
Ensure the Paper Tray is Not Overfilled
Each printer tray has a maximum capacity rating, and this rating is based on a specific paper weight and or thickness. Consequently, situations might arise in which the tray will not be able to accommodate the maximum number of sheets listed in the printer specifications. Verify that the paper is not packed too tightly in the paper tray.
Aug 17, 2008 | Dell 924 All-in-One InkJet Printer
Hardware error:0502
Solution:
Apr 05, 2008 | Dell A940 All-In-One InkJet Printer
Encoder strip
I tried for hours to reattach my encoder strip, and finally figured out the way to do it after reading many web postings, and my own trial and error.
The key is to use a "dental mirror" that you can pick up at a pharmacy or hardware store for about $5. (Perhaps a small compact mirror may also work.) And you need to focus light back there. (I used a head lamp.)
The problem is you just can not see the small slot through which the encoder strip must be threaded from the front of the printer. It sits in back of the ink cartridges. This thin slot "tunnel" goes though a rectangular piece of plastic. You can feel the rectangular piece of plastic in back of the ink cartridges, and looking with the dental mirror you can see how small the slots are on the right and left side, through which the encoder strip must be threaded. After "seeing" these small slots using the dental mirror, you then can feel them with the tip of a fingernail, and know exactly what you are aiming for as you then feed the encoder strip through. (It doesn't make any difference of you feed the strip from the left or the right, but the down arrow end of the encoder stip must end up on the right when you later attach it to the wire tab.) I fed the strip "blind" after I had formed a strong mental image of exacly what I was trying to do, and now being able to feel the small slot I was aiming for with the tip of a fingernail. (It is tough working in the small space in back of the ink cartridges, and if you have really big hands and fingers it may be impossible. I did not want to use forceps or tweezers because of a fear of damaging the encoder strip.)
The encoder strip then must be attached with the down arrow end on the right attaching to a flimsy looking wire on the right side of the printer. The left end of the encoder strip must be attached to a metal tab on the left side of the printer. You will need to hold tension on the encoder strip, and manually push the sliding ink cartridge back and forth out of the way as you attatch both ends.
(It's probably a good idea to gently clean the encoder stip of all your fingerprints and any smudged ink with a tissue after you get it back in place. Also be sure to clean the metal bar the ink cartridges slide back and forth on, so you don't get error message 0502.)
Be prepared for this to be a very frustating experience!
You will be maddened by how many times it will take to thread the encoder strip though the slot, how difficult it will be to catch the end of the encoder strip on the wire and metal tabs, and how you will have to figure out how to hold tension on the encoder strip so one end won't fall off as you attach the other end.
But once you use the dental mirror to see where you have to thread the encoder strip, and once you see the wire and metal tabs to which the ends of the encoder strip must be attached, then YOU CAN DO IT! It just takes persistance.
Nov 05, 2007 | Dell A940 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
101 people viewed this question
Seeker5211
Seeker5211
