Question about Brewmatic LA3 Coffee Maker
Brewmatic M90 automatic coffee maker heas water but does not deliver. Any ideas?
  • 131 Answers
SOURCE: Bunn coffee maker leaks water
There are 3 seals in your unit that could cause your problem. there is a silicon seal right under the pour-in tray, and two on the top of the tank. one of those is for the thermostat, the other is for the sprayhead tube. any of these could leak, causing water to come out the bottom of the brewer. One other thing that can cause this is a scale buildup between the pour-in tray and the tank.
Posted on Feb 13, 2009
danforddan1
  • 192 Answers
SOURCE: water leaks out from underneath coffee maker
Well they don;t give these away for sure. Lets see if we can help you out. ? are you over filling it.This happened to me because I was reading the fill line wrong. {got new glasses} . If not may be you could try makeing less. But if only 1/2 cup comes out and no more, that wouldent indacate a leak in the tank, if there was it would all leak. Try backing off on the coffie and water, and see if it still leaks. if it does get back to me. DFD
Posted on Apr 13, 2009
  • 85 Answers
SOURCE: the coffee maker prematurely turns off at
Hello 1pro8vo2,
This is a common problem with Cuisinarts and is fixable.
I am most familiar with the DCC-1200, but you may be able to solve the problem. The may be an indication that something is plugged up. Open the top of the unit and in one of the corners you should find a water filter stick or column that is removable. Pull it out and open it up to clean out the clogged up carbon filter in there. (You can later buy a new filter on Amazon.) Clean out the debris from the bottom of the cavity. Replace the stick into the cavity once cleaned. Now it's time to run through a solution of 2 parts water and 1 part vinegar. Do this once or twice with fresh solutions, then with a pot of fresh water. When the filter stick is plugged up the sensor says its time to clean it or shuts the unit down, but most people don't know about this fix. I hope this is helpful to you, evc. Positive feedback is appreciated. Good luck. NormanZ
Posted on Jul 11, 2009
  • 10 Answers
SOURCE: my keurig coffee maker is making really watered
I have no idea what this is but perhaps the water spout is out of alignment with the filter and missing the coffee. Check for small blockages that could be misdirecting the flow of water.
Posted on Sep 06, 2009
  • 60 Answers
SOURCE: My Jura Capresso coffee maker is
The sieve in the brew unit is probably clogged, this means that it takes to long to push the water through the coffee. There is an automatic time-out on the pump that controls this. It also can be that your coffeeoutlet is clogged.
Try cleaning out any used coffeegrounds from the inside of the machine, use your finger up into the brew unit. If this doesn`t help, it needs service.
Posted on Oct 06, 2009
Water tank is full, water gets hot but no water comes up through coffee grinds, using as pour over, not connected to water line.
Remove the sprayhead and check that for blockage. Pour water into the reservoir with the sprayhead removed to see if it flows. If water flows then the problem is the sprayhead. If no water then it is the brew tube and you need a deliming spring to clear out debris. If the only time water does not get through grinds thne it is possible the grinds are too fine.
Nov 16, 2011 | Brewmatic LA3 Coffee Maker
We are attempting to use the LA3 by pouring water into the top of the machine as opposed to auto through a water line. The water heats up, the green ready light comes on, I push the start button and it...
If it is not connected to a water line then you cannot use the hot water faucet or the start/brew button, you will have to manually brew coffee by pouring the water into the reservoir.
Water not pumping out of coffee machine
It seems that the coffee solenoid valve is blocked or broken. Cofffe solenoid valve is the valve which open to deliver the water after the pump to the coffee shower.
Feb 17, 2010 | Saeco Talea Giro Espresso Machine
Water sound change in home plumbing
the Pipes heat and expand and become tighter in their mountings. less pipe movement.
and the expanded pipe has a different reverberation
Sep 22, 2008 | Brewmatic High Volume - Single Coffee...
Water Level
my first response would be to say that you need to put 8 oz. less water in - but that's the obvious and somewhat comical solution. But here's what you need to do:
Take the top cover off (1 std. screw on top) and pull the brown water tray out. turn the unit on its side and clean the heating elements! You most likely have huge calcium deposits in the water tank. Scrape the elements but be careful not to bend the thin wires leading out of the tank (they're paperclip thin and will break if bent back and forth.
After cleaning the elements and tank, remove the drip spout (turn counter clockwise to unscrew) and clean, then clean the red tube hose in the center by pushing a wire (coat hangar thick) down through the middle.
Reassemble and pour two, almost full, pots of water into the tank, this is the default level needed to start brewing. When you pour your third pot in, that is the amount of coffee you will get minus whatever your filter soaks up. Hope this helps - good luck!
F5Tornado
Jul 10, 2008 | Brewmatic Diplomat VI Coffee Maker
Water won't shut off
check the timer on the machine. it could be a mechanical or electronic timer. the timer's output goes to a water solenoid valve. could be the solenoid itself is faulty, but it all seems to point towards the timer - because you say it works fine normally. Is this a bunn coffee maker?
Sep 13, 2007 | Brewmatic 151 Coffee Maker
Brewmatic LA3 Coffee Maker Logo
181 people viewed this question
Top Brewmatic Coffee Makers & Espresso Machines Experts
ray gallant
Mark Cheong
Mark Cheong
Are you a Brewmatic Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
