Question about Sub-Zero 695/O Side by Side Refrigerator
Refrigerator is too warm
I can't read the dial direction for what is colder due to its (not mine) age
  • 4,793 Answers
Turn right up (hence the saying)
turn left down
Posted on Jul 05, 2010
My freezer isn't cold enough. Are the higher numbers on the thermostat dial colder or are the low numbers colder? See full question below.
Hi, If I remember correctly, make sure the freezer control is set to on, otherwise neither will cool.
You need to give it 24hr for temp to settle, then check to see if freezer temperature is 0? to 2? F (-17? to -16? C).
Turn control to next highest number if too warm.
Turn control to next lowest number if too cold.
Allow 5 to 8 hours for adjustments to take effect.
Check to see that fresh food section is 38? to 40? F (3? to 4? C).
Hope this helps
David
Mar 02, 2018 | Amana Refrigerators
The dial on my water c ooler has a +and -which is colder?
My guess is that moving the setting in the + direction makes it colder. My refrigerator uses numbers; the higher the number, the colder it gets
Apr 22, 2013 | Refrigerators
Refrigerator freezing food
Fridge thermostat dials are often problematical due to the ones that are numbered 1 to 10, is 1 the warmest or the coldest as the number is lower? Some companies put 'warmer' and 'colder' which avoids confusion. My advice, put it in the middle '5', and leave overnight, check the temperature in the morning with a fridge thermometer. Then change the thermostat dial to 8, and check it the next morning with a thermometer. The next day put it on 1, and leave overnight, check the temperature in the morning. If the thermostat has gone, all three morning temperatures will be the same.
You mention 'or as your website suggests', you know we are not Frigidaire or anything to do with the retailer? We are Fixya, people just like you, helping others. I am a caterer, and just happen to know about fridges. I get them repaired professionally, but always ask for a full explanation of what went wrong. We recently had a sandwich storage fridge that was freezing food, and it was the thermostat that needed replacing.
The things you did, cleaning the coils, will actually make the fridge run colder. The Defrost Thermostat is unlikely to be the problem, as when they don't work, the evaporator, the part that is where the chilled air comes from turns into a block of ice. When that happens, air can't pass through it and the fridge warms considerably.
Due to the damage this freezing is causing with your water and filter, I would suggest you call a service engineer and get it fixed professionally as you will be swapping out parts that are fine. Correct diagnosis is the key, and they will also check the gas pressure at the same time. Consumers can't work with refrigerant gas, it is *******.
Mar 14, 2017 | Frigidaire Refrigerators
Refrigerator less than two months old. Freezer side fine refrigerator side stopped working altogether. All food ruined. Who should I contact. purchased from Home Depot.
This is a very common issue, If the freezer compartment is cold and making ice the
problem is simply airflow from the freezer into the refrigerated section.
Typically when one senses the refrigerator is warm they max out the settings
on both dials the thermostat with its 1-10 settings as well as off for the compressor.
This controls the compressor and temperature.
The additional setting or dial is for colder freezer or refrigerator as well , However
it simply opens or closes a flapper door between the freezer and refrigerator boxes.
When that dial or setting is maxed , it closes and makes the freezer colder, yet leaves the refrigerated section starved for sufficient airflow to maintain a cold box in the refrigerated section.
Just set the dial that does not turn the compressor off to the middle setting.
One can leave the thermostat that does control the compressor in the max setting , just not the colder freezer setting, If you notice colder isnt colder refrigerator, Its actually colder freezer, A common issue found on 25% of all refrigerator calls a simple setting adjustment.
Its easy to think that maxing out the settings makes for a colder refrigerator, it doesnt, it makes a colder freezer and warm rerigeration section.
If a freezer is making ice, theres nothing wrong with the unit other than airflow setting.
Add a comment
Dec 24, 2010 | Maytag Refrigerators
My GE TFX30PP is constantly running and doesn't turn off. The freezer is very cold but the frig side isn't cold enough. A repair guy put in a new "cold contol" sensor but it didn't help.
I would also clesan the condenser coils off.
Add a comment
Dec 24, 2010 | GE Profile Performance 29.8 cu. ft....
My Roper refrigerator stopped getting cold, although the refrigerator lights and the fan in the freezer works. What is the problem?
If the freezers warm, possible defrost timer bad, if freezers cold, set to middle setttings on both dials, the 1-10 OFF dial operates the compressor, the COLDER/WARMER dial operates the flapper door that regulates freezer air into the reefer box, if set to max cold that makes cold freezer, not reefer.
Nov 01, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Please help fix my fridge
mine did that and it was due to a frozen water line that blew out the thermostat. See if the water line is frozen first. It was located on my refrigerator behind the crisper drawers. the tech had me use a hair dryer to thaw out the line
Dec 10, 2008 | Samsung RS2630SH Side by Side Refrigerator
Sub-Zero 695/O Side by Side Refrigerator Logo
115 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
