Question about Panasonic CQ-VD6503U Car DVD Player
My system has been locked since my battery went dead! it says enter security code but i never put 1 in it.
  • 4 Answers
Contact Panasonic directly and they can provide you with the bypass code for your unit. It usually is free. They have a toll free number you can call that I will list below. Best of luck. Let me know if this solves your problem.
1 (800) 211-7262
Posted on Aug 02, 2010
  • rsol6260 Jan 11, 2011
    hold track button for ten secons it resets , then put new code
Security system is locked, need to fix
need more info what kind of car or truck, year, engine size
Feb 05, 2013 | Cars & Trucks
Locked out
The setup Security Code can be done when the
<Demonstration mode Setting> (page 50) is set as OFF.
• When the Security Code function is activated, the code
can’t be changed and the function can’t be released.
Note, the Security Code can be set as the 4 digit number
of your choice.
1 Enter Standby
Press the [SRC] button.
Select the "STANDBY" display.
2 Enter Menu mode
Press the [MENU] button for at least 1 second.
When "Menu" is displayed, "Security" is displayed.
3 Enter Security Code mode
Press the Control knob for at least 1 second.
When "Enter" is displayed, "Security" is displayed.
4 Select the digits to enter
Push the Control knob to [4] or [¢].
5 Select the Security Code numbers
Push the Control knob to [FM] or [AM].
6 Repeat steps 4 and 5, and complete the
Security Code.
7 Confirm the Security Code
Press the Control knob for at least 3 seconds.
When "Re-Enter" is displayed, "Security" is
displayed.
8 Do the step 4 through 7 operation, and
reenter the Security Code.
"Approved" is displayed.
The Security Code function activates.
• When the wrong Code is entered in steps 4 through 6,
repeat from step 4.
Press the Reset button and when it’s removed
from the battery power source
1 Turn the power ON.
2 Do the step 4 through 7 operation, and enter
the Security Code.
The unit can be used.
In Standby mode
Touch Sensor Tone
Setting the operation check sound (beep sound)
ON/OFF.
Display Setting
"Beep : ON" Beep is heard.
"Beep : OFF" Beep canceled.
In Standby mode
Manual Clock Adjustment
• This adjustment can be done when the <Synchronize
Clock> (page 43) is set as OFF.
1 Select Clock Adjustment mode
Select the "Clock Adjust" display.
2 Enter Clock Adjust mode
The clock display blinks.
3 Adjust the hours
Adjust the minutes
4 Exit Clock adjustment mode
Press the [MENU] button.
The Whole manual is here.
http://www.kenwood.net-disp.com/i/05products/kdc_x789/pdf/kdc_x889_x789_mp828_k_english.pdf
Dec 06, 2007 | Kenwood KDC-MP628 CD Player
My radio in my 2004 dts will not turn on after battery went dead
You need to gete the radio security code and enter it in. Just call or drop by the dealer and theye can give you the code or enter it. Should be free but your dealer may vary. When you changed the battery and lost power the radio goes into a secure mode just in case it was stolen. The code should be about 4 digets long so its not a big thing to enter. its keyed to your vin number so the d ealer may want to see that as well as your registtration and maybe a drivers licence depending on how paranoid they are.
Aug 16, 2012 | 2004 Cadillac Deville
My 06 Pontiac G6 won't start. The battery still works, the radio and windows still work but I can't get it to turn over. What's wrong with my car?
Probably the anti theft security system. Does your key say PK3 on the shaft? try a different key.
This link explains the problem, but im sorry i have no solution for you http://vatspasslockpasskeysecurityhelp.yolasite.com/
May 23, 2011 | Pontiac G6 Cars & Trucks
I changed fuel pump and fuel filter. My battery went dead. I took battery out and recharged. Now I'm locked out by my security, Engine won't turn/start. I think I'm locked out by security system.
Turn the car on, dont try to start it, let it set ten minutes, turn it off dont take the key out. do this three times. on the third time turn it off then try to start. this will reset the security. Make sure you have everything turned off when you do this. as the battery will drain. It is a good idea to put the charger on the battery as you do this.
Nov 21, 2010 | 2000 Oldsmobile Bravada
2005 GMC Envoy key is stuck in accessory position in the ignition with dead battery and transmission stuck in park. Will replacing battery help or is it security system lock down? If it is the security...
Jump starting the battery may be all you need. If this vehicle was not in park when the battery went dead and when you got in to start it it was dead. You then probably put it into park trying to start it.
But the issue at this time is if it was in neutral when the battery went dead the you changing the selector to park may not actually have placed the transmission in park. With electronic gear selection it actually need power to the system to place the transmission in park.
Without it really being in park the key may move to the lock position.
A bit of quess work here but I hope for you I hit the mark.
May 20, 2010 | 2005 GMC Envoy
How to unlock a cathedral electronic safe ea25
After opening the electronic safe (with the pre-set factory code of 159B) locate the small red button on the
inside of the door near the hinge.
2. Press the red button and then release it, you will hear a beep. DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits long, and confirm your new code by pressing the letter “B” on the electronic touch pad. Before you close the door, try the new security code to make sure the lock release the knob so you can turn it and retract the live action locking bolts.
If the code fails, go through steps 1-3 again. If the code works successfully, then you should lock the safe. When you open the safe in the future enter the security code you have set followed by the letter “B” and turn the knob.
If the incorrect security code is entered 3 times you will have an automatic lockout for 20 seconds before you can try your code again. If the incorrect security code is entered 3 additional times there will be a 5- minute lockout before the code can be tried again.
BATTERY REPLACEMENT
This safe uses 4- AA batteries. Under normal use, batteries will last about 1 year. When the battery is low, a red light will come on warning you that the battery is low. To test the batteries, enter your security code. If the batteries are low the red light located in the middle of the top of the keypad will start to flash.
To replace the batteries, open the safe door with your security code and turn the knob. Push the batteries cover plate, which is located on the back of the door, and replace the old batteries.
YOU MUST PROGRAME YOUR SECURITY CODE AFTER YOU REPLACE THE BATTERIES. SEE STEPS 1- 3 UNDER “ENTERING YOUR SECURITY CODE”.
TROUBLE KEY
A “Trouble key” has been provided in case you forget or lose your security code. Remove the small central panel from the front of the faceplate. Insert the key and turn it counter clockwise. Then turn the knob on the door towards the right. This will manually open your safe. If you lose your key, you may purchase a replacement key by referencing the serial number located under the central panel by the lock.
MAINTENANCE FOR KEY AND ELECTRONIC SAFE
If the door of the safe starts to rub on the door frame, open the door per the instructions above. By the door hinges you will find a threaded stem. Use an Allen wrench to tighten the threaded stem. This will help realign the door and give you trouble free access to the contents of your safe.
Nov 01, 2009 | Home Security
Need the un-lock code for a kenwood kdc-422 car cd player
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
Feb 04, 2009 | Kenwood KDC-422 CD Player
Security System
I have a 5.2L V8 Jeep Grand Cherokee and i know to reset my security system i actually have to go around to the passenger side door and lock and then unlock it again. Seems fairly odd but that's how i was told it was reset. Give it a go and lemme know!
Oct 21, 2008 | 1994 Jeep Grand Cherokee
Phone security code ...
Follow the step
Howto use:
You need two mobile phones.
1) Do _not_ turn off the mobile phone!
2) Remove the Memory Card (MMC) from the locked phone and put it into a
second mobile. Install FExplorer on the second mobile phone. Create
the directory E:SystemRecogs and copy thc-nokia-unlock.mdl into
this directory.
3) Remove the Memory Card and place it into the locked phone.
The THC-NOKIA-UNLOCK program should start after 120 seconds.
4) Remove the battery. Remove the MMC. Put the battery back and restart.
The Phone Lock has been reset to "12345".
Apr 27, 2008 | Nokia N73 Cellular Phone
Panasonic CQ-VD6503U Car DVD Player Logo
147 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
