Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Rattling in machine. How do you get the top up to
Rattling in machine. How do you get the top up to remove tube?
  • 259 Answers
Before you start the following, see if the noise seems to be coming from the lower rear of the washer and mostly during the drain out cycle. If so it may be something caught in your pump, that requires you to remove the rear panel of the washer to locate the pump (follow the drain hose straight to it). Also be advised there is a recirculating pump in your machine as well that could also possibly have something caught in it as well. This is located to the right of the drain pump.
There are two clips that hold the top down on this washer. One on the left and one on the right, about two or three inches in from the sides between the top assembly and the front. You will need a putty knife to depress them and lift the top, beware the top comes up very hard on these as they are intended to be a very tight fit.
When you get the top up you can remove the wash impeller by popping off the cap on the top of it and removing the bolt that holds it in place.
next you will want to remove your outer tub cover and then you should be able to pull the inner tub out of the machine to see if you can locate the source of your noise.
Good luck with this!!
Posted on Jul 04, 2010
What causes my frigidaire top load washer to vibrate and make rattling noise during spin cycle
There are springs and bumpers/shocks in the machine that hold the tub. When they break or come loose, the tub wobbles.
Jan 03, 2016 | Frigidaire FAHE4044MW Affinity High...
There's a bit of a rattling noise when the diswasher is running, as if something is in the pump. I've removed the strainer to see if anything is in there, but nothing. How do I remove the sprayer...
There are some GE dishwashers where the middle spray arm tube vibrates as it washes. This middle spray arm is attached to the top rack. The end of this spray arm tube where it goes into the back wall is loose. There is an after market rubber washer from GE that goes there to prevent vibration and make a tighter seal. Or you can put a tie wrap around the tube end and rack to prevent vibration.
Mar 03, 2014 | GE Dishwashers
Kitchenaid refrigerator making rattling noise
YOUR ARE GETTING ICE AROUND YOUR FREEZER FAN BLADE THAT IS THE NOISE YOU ARE HEARING IT COMES FOR THE ICE MAKER FILL TUBE THAT COMES IN FROM THE BACK WALL OF FREEZER TO THE ICE MAKE YOU CAN'T DO ANYTHING TO FIX IT JUST MAKE SURE YOU HAVE NO ICE BIULD UP IN THAT TUBE IT MAKES IT LEAK DOWN ON YOUR FAN
Oct 30, 2012 | Refrigerators
Haier hlp23e washer makes a rattling sound during spin that almost sounds like coins being slapped by an impeller. How do I fix?
Here's what I did that seemed to fix it. You know that plastic attachment you screwed onto the bottom? I'm pretty sure the noise is made by the bottom of the machine spinning against it. I thought the noise sounded sort of plastic-y, so I removed the bottom and sure enough, there were circular scratch marks on it. I haven't heard that annoying rattling yet.
May 05, 2012 | Haier HLP23E Top Load Washer
Nickels pennies and dimes are rattling inside the washing machine
put the washer on spin for a few seconds then turn it off, it will spin the coins to the outside, if that doesn't work u will need to remove the washer tube, the solutuion works well have used it many times in my own washer
Jul 02, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
There is a loose part in my Mini-Colossal that causes a slight rattling when playing a middle E. The rattling subsides when applying slight pressure to the power amp tube. I?ve since replaced the tubes,...
If this is a vacuum tube unit, SOME vacuum tubes will have spacers within them that can rattle. You cannot get into the tube of course to correct the problem. Replacing the tube MIGHT find one that does not have the loose parts in it.
Feb 19, 2010 | Peavey Jsx Mini Colossal Guitar Amplifier
Water leaking from deyergant compartment
Make sure these isn't any foreign objects in the tube that leads into the drum from the detergent tray.
Remove the top of the unit. 2 screws in the back. Top left and top right and slide the top off. Look under the tray and locate the tube and feel around. You may have to remove the tube to get a better look.
Dec 24, 2009 | Samsung WF218AN Front Load Washer
Electric Maytag Neptune Dryer - rattling noise
Your probably going to have to remove the rear panel and take a look to see what is causing the noise.
Disconnect the power cord and exhaust tube, remove the rear panel and check for anything loose.
You can also pop the lid and fold it back to inspect the top of the tub and belt. Roll the drum all the way around and inspect the belt for "chunks" missing.
If you include your model number, I can send you a web site that will show you an exploded view of the dryer.
Regards,
Aug 14, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Whirlpool Ultimate Care II Washer Model#LSQ9665JQ4
NO. the motor is problably good, you need to replace hte motor coupling, behind the motor, part number 285753. its the machine equivelint to a belt.easy repair, if needed you can search you tube as how to remove and replace
Mar 01, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Nec nw452 washing machine water level does not stop. It overflows even when I put it on low level load. I keep having to turn the machine off and bail the water out into the sink.
I have just fixed this issue on my machine. Empty the machine by using the program options to spin only. Turn off power. Remove the plastic back plate then the silver back plate. Looking at the rear of the machine bowl, right hand side is a plastic tube which runs to the top right hand side of the machine. This is the water level sensor tube. Check if it is broken or blocked. Mine was broken near the top of the machine. I removed the lid (becareful to take note how the spring fits in with the leid for when you replace it. Remove the control panel cover. I saw the water level sensor (looking from the rear of the machine) to the right. It is brown and has one connector which needs to be disconnected (red and white connectors). Then the water level sensor is removed from its housing by unclipping the two clips. Once removed I replaced the tube and then put it all back together.
Jul 07, 2008 | Washing Machines
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
298 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
