Question about LaCie 500GB FireWire-400 Porsche - 7.2K 500 GB FireWire 400 (1394a) Hard Drive
Drive not working/ not showing on desktop/ green light showing on powerpack but light blinking amber / yellow on the hard drive
    President:
  • 2,923 Answers
Do you hear a clicking sound while the HD (hard drive) is ON? If not, here's what you need to do:
1. Try to connect the HD into different USB ports of your computer. Or might as well, try different computer.
2. If you're using USB cable to connect the HD to the computer, try different cable. If it has a FireWire connection, then try FireWire.
3. If same problem occur, check the Disk Management of your computer while the HD is connected. To check the Disk Management, here's how:
- Right click "My Computer" (for XP) or right-click the "Computer" icon (for Vista or Win 7).
- Go to"Manage", then select "Disk Management".
- List down all the drive letters that you will see. Include the "Unallocated" disk space on the list(if there is), then unplug the HD from the computer.
* If there's a drive letter that disappears, then it's your HD. You may reconnect the HD to the computer > right-click on the HD's drive letter > change drive letter. Try to set the drive letter of the HD in drive X: or V:.
* If the drive letters remained the same, though you disconnect your HD, then, it means that the HD is no longer detected by the computer.
* If the HD appears to be "unallocated", then you need to reformat it.
*** However, if you're hearing a clicking sound, I'm sorry to inform you that the HD is no longer working. That clicking sound is also called the "click of death".
Thank you and good luck!
Posted on Jul 04, 2010
Dell Precision T3500 wont boot 1-3 lights blinking
An amber light means your computer isn't reading the hard drive or CD right, Take it to a professional to get this corrected
Dec 16, 2013 | Dell Precision Computers & Internet
Optiplex 755 blinking amber light, simple solution, I'm no IT professional.
If the power light is blinking amber, the computer is receiving electrical power, but an internal power problem might exist.A power supply or system board failure has occurred. Try to isolate the problem by removing or disconnecting all cards, i.e. video, sound cards and disconnecting CD/DVD and hard drives.
Oct 20, 2012 | Dell Optiplex 755 Desktop Desktop Computer...
Aux power led light is amber on dimension E521
I think your problem is your memory or video card.
Below are some steps that I recommend.
When you plug in the power cord is there any lights whatsoever on the computer?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the computer and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button.
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Maybe your power supply is bad. Sometimes there is enough power to make the power light or some other lights come on but not enough power to make the fan turn on or hard drive spin.
Below are links and info I found from Dell's Website based on your model.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/specs.htm
Controls and Lights Front of computer:
Power button - push button
Power light
green light - Blinking green in sleep state; solid green for power-on state.
amber light - Blinking amber indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this indicates a problem with the system board (see "Power Problems" in your Owner's Manual).
Diagnostic lights
four lights on the front panel (see Diagnostic Lights.)
Standby power light
AUX_PWR_LED on the system board
Hard-drive activity light
green light - When the computer is reading data from or writing data to the hard drive.
LAN indicator light
green light - Solid green indicates that a LAN (local area network) connection is established.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/adtshoot.htm#wp1056411
Jun 03, 2012 | Dell Dimension E521 (D10E16) PC Desktop
Yellow light shows in hdd of server
This means that HDD is faulty . You can confirm it by re fixing the hard drive .
Shutdown computer > Remove HDD > wait 1 min and Insert it > Start computer .
If you get any of the below status
Steady Amber (Orange Led) = Drive is Faulty
Amber Blinking = Hdd rebuilding
If orange led blinks , it means hdd is in rebuilding state. Wait for sometime and check if it come online . On the other hand (Steady Amber) its time to replace HDD
Good Luck
Apr 26, 2012 | IBM x3400 Server
Screen will not come on hard drive light no light checked power supply is ok
Things to check:
  1. Power led on the front of the tower, it should be solid green when on. Flashing Amber is generally an indication of a bad power supply inside the tower
  2. Power LED Solid AMBER indicates system is not finishing the power on self test (POST) and you remove all connections from the tower except power and try turning on again. If no change, remove all PCI and PCI-E cards from system, try again, no change replace motherboard.
  3. On the back of the tower are 4 diagnostic LEDs near the ps2 ports marked ABCD, after the POST, during a normal boot the will flash in several sequences and with boot is finished all 4 should be green. If they stop an a different pattern, then that indicates a failure Yellow Yellow Green Green indicate bad RAM for example
  4. If the LEDs on front and back are Green then the system appears to be booting but the monitor display is not functional
Feb 05, 2010 | Dell Dimension 4600 PC Desktop
Can't boot up Dell 5100 Dimension, amber light flashes
When you mean the amber light, is that the blinking hard drive access light or the power light? Different cases have different colors on it. Mine has blue and green lights.
If you see the boot screen (bios) and then after it goes to boot, does it blink and hang?
This could be a simple operating system issue, hard drive or hardware/motherboard issue. If you could provide more information, that would help.
Jun 28, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Blinking amber light with green 4 light
Try, unplugging the power cable from the pc, and reinsert it, if this does not help try a differnt power outlet, if this dont help, open the computer, take the power Molex conector out of the mother board and try turning it on, if this dont help, take out the Memory modules and reseat them, if this dont work you may want to ring up dell support.
Hope this helps!
Jun 15, 2009 | Dell Dimension 9100 PC Desktop
Computer will not turn on
  • Blinking Amber/yellow: Initial state of LED at power up.
    Indicates system has power, but the POWER_GOOD signal is not yet active.
    If the hard drive LED is off, it is probable that the power supply needs to be replaced.
    If the hard drive LED is on, it is probable that an onboard regulator or VRM has failed.
Apr 28, 2009 | Dell Dimension 4600 PC Desktop
Amber light on power button
Check to see if there are any loose connections to the memory cards on the memory board. Make sure the data cable to the drives are connected properly. Is the fan in the power supply on?
Jul 27, 2008 | Dell Dimension 8300 PC Desktop
Computer problem
If you are referring the green or amber light on the front of the case, it could either be the power led or the hard drive activity led. If its the hard drive activity light, it usually just blinks when a program accesses the hard drive.
Thanks
May 13, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
LaCie 500GB FireWire-400 Porsche - 7.2K 500 GB FireWire 400 (1394a) Hard Drive Logo
376 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
