Question about GE WSXH208A Front Load Washer
My GE Front Load Washer appears to have a broken belt as it stopped in the middle of a wash cycle but the motor was still running. I turned the power button off and unplugged it but the motor stays running and the door is locked and I can not get the clothes out. I have called an appliance repair man but they cant come until Tuesday and I need to open the door to get the clothes out.....any suggestions?
  • 259 Answers
According to your wiring diagram, if you remove power from the machine for approximately 5 minutes, the door should unlock.
If you find the tub is still full of water, you may have a blockage in your drain pump or pre-filter. To access the pump pre-filter and pump, un-plug the washer and slide it forward so that you can tilt it back and lean it against the wall behind it.
Next remove the three screws located at the very bottom of the front of the washer that hold the lower access panel on. Allow the access panel to drop down and set it off to the side.
In the front right corner you will see the drain pump.
The hose that comes from the outer tub to the pump is designed to trap coins/debris in the base of it, you can remove the hose from the pump by using pliers to squeeze the clamp and slide it backwards.
Be sure to get ready for some water to come out if there is still water left in the tub. Hopefully you will find a sock or some coins in the base of this hose trap that are causing your issues, if not be sure to check the pump inlet where the hose connects to the pump, it is just about the right size for a quarter to become lodged inside stopping the flow of water to the pump.
Good luck with this!!
Posted on Jul 04, 2010
The motor is running but it won't turn the belt on my front loader ge washer
It definitely sounds like the belt is stretched, worn-out, and in need of replacement.
Jul 30, 2014 | General Electric Gfwh2400lww 4.9 Cu. Ft....
GE Washer top-load WLDSR416FOWC
WHAT IS WRONG WITH YOUR WASHING MACHINE?
small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Jul 23, 2008 | GE WDSR2080D Top Load Washer
Noise during wash cycle & got even louder on spin cycle then washer stopped completely
Could be bad belt, or agitator sleeve cracked / or broken. Not catching.
Aug 08, 2012 | Maytag HAV3460AWW Top Load Washer
Washer does not agitate or spin after cycles but fills and empties water and motor is going
Belt is broken. Remove front cover of washer. If you look where top meets front in the seam there are two clips, using a flat head screwdriver push into seam and pop clip. Front will then remove. Check belt at bottom of unit. Replace with the same belt. Difficult to get new belt on! You have to start with belt on motor pulley then on drum pulley holding and turning drum pulley as you stretch belt around pulley. Replace front cover.
Jan 19, 2010 | GE WBSR3140DW Top Load Washer
Washer motor spins but not the belt in spin cycle only,
It doesn't spin If your washer won't spin, check these: It doesn't pump or spin It pumps, but doesn't spin It spins only with the lid closed It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Jan 03, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Motor starts and won't stop!
Its gear box might be worn out.. check for the bearing inside the roller if possible..
Jan 18, 2009 | GE Energy Star WCVH6260F Front Load Washer
GE WHDRR418G1WW Washing Machine will not agitate or spin/rinse cycle
coupling between motor and drive assy broken. take motor loose and you can get it out. Visual check first to see if motor is running when in agitate cycle.
Dec 03, 2008 | GE WBSE2090A Top Load Washer
Hoover 710 top loader washing machine
turn it to one side,look the bottom,the belt may broken,it look like a car fan belt.
Nov 09, 2008 | Hoover HTC243 Top Load Washer
GE Adora front load washer overloaded now won't start
Washers - Resetting Electronic Controls on a Washer
If there is a pause in the washer cycle, the controls will lock up. The pause can occur because of a power failure or it was put in the test mode at the factory.
Also, if the washer was stopped before the cycle was complete or the consumer has pushed the stop/pause button to temporarily stop the cycle and the cycle is not reset. Over a period of 24 hours, the washer will pump out and spin, but will stay in the final spin.
To correct the situation, shut off the circuit breaker for 30 seconds or unplug the washer, then turn the timer knob around and back to any position other than final spin. Verify the water is turned on and restore power. This should resolve the issue.
Apr 23, 2008 | GE WSXH208A Front Load Washer
GE WSXH208A Front Load Washer Logo
300 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
