Question about Maytag MSD2756G Side by Side Refrigerator
Hi Side by side refrigerator not cooling down. Freezer seems to be not freezing. refrigerator compressor is running. Freezer damper wide open on a setting, refrigerator turned up to 10, running but not cooling. I believe it might be the heater or heaters because the front of the refrigerator used to be hot, it's not even warm. In the freezer compartment has frost all over the back. I don't know if it's the heaters or something else? I opened the back where the cooling coils are, and it was solid ice. I defrosted it, it ran fine for two days then stopped. Still running but not cooling down as it did before. Also the front where the two doors meet use to be hot, their not even warm. This problem happen before, tech came out and replaced a heater. Said it had somethiung to do with keeping the refigerator from frosting. This is for model number rst2200f.
  • Maytag Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
jkkfj
Posted on Sep 29, 2010
2 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: Refigerator is warm, freezer works fine. There is
Your defrost system has failed. The ice buildup prevents the fridge side from cooling properly.
Posted on Jul 04, 2009
I have a Kenmore Side by Side with two problems that I think are related. I have the freezer on the warmest setting but the drain line continues to freeze resulting in ice accumulation in the bottom
You have two different problems. There is another drain pan and drain located under the evaporator (cooling coil). This assembly is not visible until some panels are removed. That drain pan opening is probably plugged. The refrigerator is cooled by air forced from the freezer and controlled by dampers. The dampers are too wide open and thus allow too much cold air into the refrigerator section.
Oct 08, 2014 | Kenmore Refrigerators
Refrigerator freezes
Sounds like might be the Temperature Control Thermostat or some sensor in the circuitry telling the compressor and cooling parts to keep running because it thinks it isn't cold enough. There is probably a circulation fan to blow the cold air through the damper and it may not shut off either, conveying too much cold thermal conduction through ducting and all frig parts, regardless of damper being closed or open. With the temperature set on low, do the compressor and fans ever shut off once cold temperatures are attained? Freezer should be 0 or lower, frig 35-40.
check this video at RepairClinic.comhttp://www.youtube.com/watch?v=5vA8Ksv5kVY&feature=player_embedded
Apr 07, 2013 | Electrolux Refrigerators
The meat and veg drawers freeze the meat and veggies no matter what setting the temp. is on.
Freezing meat,vegetables. Problem with damper.
For this problem, its indicating towards problem with damper assembly.----------
The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. ----------- The damper is operated by a motor.Its a complete damper assembly with motor included in it.--The damper has door.Which closes and open with the help of motor.In your case the damper door is remained open, its not closing.Due to this the cool air from freezer section is running in to fridge section non-stop.Due to this the vegetables and other food in the bottom drawer freezing.--------- In this problem the damper assembly needs to be replaced.---------------
You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.
----------- This should help. Thanks.Helpmech.
Jul 08, 2011 | Kenmore 56829 Side by Side Refrigerator
Kenmore sidebyside 106 is freezing wide open on freezer side and barely cooling on frig side. there is ice in venting on the frig side
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Jan 25, 2011 | Kenmore 53642 / 53644 Side by Side...
I have a kemore coldspot side by side maufacture date 04/07 that is not cooling properly. Freezer gets cold but won't freeze and fridge section gets cool. I have checked condenser fan runs and compressor...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 24, 2010 | Kenmore 53642 / 53644 Side by Side...
Refrig was clicking on and off now nothing not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Aug 02, 2010 | Frigidaire FRS26H7CS Side by Side...
Side by side Admiral freezer freezes but fridge
check the damper vent door between the refrige and freezer and make sure its opening up to let cold air from freezer into the refrige,sometimes they freeze up and cant open and close when called upon to do so,if so deice it with a hair dryer,the side being hot is good telling you the compressor is operating correctly
Jul 28, 2010 | Admiral 26 cu. ft. Side-By-Side...
Jenn Air JCD2389GTB side-by-side refrigerator freezing & cooling
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jul 13, 2010 | Jenn-Air JCD2389G Side by Side...
The refrigrator does not get cold or freeze
Check at the back of your freezer panel for excess icing / frosting this will affet proper cooling - if so, then you have a defrost problem - have it serviced - if no excess frosting and defrosting normally, and freezer is normal, then you might have a damper problem, not opening wide enough . have them check your control boards, defrost timer, and damper (if any)
Sep 18, 2009 | Kenmore 50522 / 50524 Side by Side...
Freezer not freezing
Jul 11, 2009 | GE Refrigerators
Maytag MSD2756G Side by Side Refrigerator Logo
188 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
