Question about Canon PIXMA MP160 All-In-One InkJet Printer
Canon printer error 5100 - Canon PIXMA MP160 All-In-One InkJet Printer
  • 23 Answers
5100 seems to be a Carriage Home Position Error. Clean the plastic strip that runs the length of the carriage, it may be contaminated. Then load the tray with the blank papers.
Then reset the Printer: Following are the steps:
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal.
This should work. If not, install the Driver and Software from the Installation CD provided with the Printer.
You can also download the Driver from the following link:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=116&modelid=13368#DownloadDetailAct
Select the Operating System installed to download the compatible Driver.
Posted on Jul 04, 2010
Testimonial: "thanks for help its very kind of you gbs."
    Guru:
  • 366 Answers
Press a button 2 times and then the green light will flash then press resume 3times and the press once more press the start button and your printer will be normal
SOURCE: CANON IP 1300 SERVICE ERROR 5100
ERROR 5100 means that there is some foreign object blocking your ink cartridge carriage that disables it from moving. It may be a piece of paper or a scotch tape or a staple wire. You may try cleaning also the encoder strip with a moist tissue paper. Furthermore, you may also try cleaning CAREFULLY the contact points of the cartridge holder and the cartridge itself (those shiny bronze pins) with a moist lint-free cloth.
Posted on Oct 29, 2009
SOURCE: Service error 5100 on my canon Pixma mp110
Had the same problem, i just replaced the black ink cartridge which was finishing at that time and resetted the counters. No problems after that. Not sure whether this will help though.
Posted on Aug 31, 2008
  • 412 Answers
SOURCE: Canon Pixma MP830 error 5100
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Posted on Mar 09, 2009
  • 1126 Answers
SOURCE: Canon mx330 Error 5100 Error 5100
Cancel printing, turn off the machine. Then clear the jammed paper or protective material that is preventing the FINE cartridge holder from moving, and turn the machine on again. If not remedied, turn off machine, unplug the power cord of the machine from power supply. Plug machine back in and turn power back on. If problem is not resolved, please contact service center. This info is from Advanced Guide Troubleshooting Section under An Error Message is Displayed on the LCD....error code 5100. This is a link to Canon to download Guides.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=18120
Posted on Nov 04, 2009
  • 2427 Answers
SOURCE: Canon PIXMA iP1000 - Service Error 5100
It means that the waste ink absorbers are filled and you will need to replace them and take the machine to a service center.. Well thats what Canon says,, then when you get there they say buy a new one..
Any way forget them try this..
1.) unplug machine (power cable from back of printer.
2.) hold the power button down and plug cable back in.the printer light will stay on ,,
3.) still holding power,, press the paper feed button.. light will change to orange
4.) press paper feed button again.. It will turn to green
5.) release power button and enjoy..
Depend on the the firmware skip step 4...
That will bypass canons firmware and reset the counters.. Print as you will now..
Posted on Mar 23, 2010
Gives me a code 5100
Canon i550 Service Error 5100 ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/25975
Oct 6, 2006 - I recently dropped my printer out of my car by accident, and now everytime I try to print something, it gives me a Service Error 5100.
Canon Pixma MX420 Printer 5100 Error and Loading Ink ...
? 5:57
https://www.youtube.com/watch?v=tmTJdJTAhYU
Mar 13, 2012 - Uploaded by Dustie Meads
please help me,i have problem in my printer,wifi on printer can't search .... I too was given the generic "5100" error message just tonight.
Jan 05, 2016 | Canon PIXMA MX340 Wireless Office...
What does 5100 code mean?
What is error code 5100 on the MP460? - Canon Community
community.usa.canon.com/t5/Personal.../What...code-5100.../103212
Jul 7, 2014 - Please remove foreign objects so that the print head holder can move: ... closet and hooked it up this morning, I was getting the 5100 message.
How to resolve error 5100 on an MX452 / MX459 - Canon
https://support.usa.canon.com/kb/index?page=content&id...
There are several reasons for error 5100 to appear. ... If the above recommendations donot help you resolve the error, the printer will need to be repaired.
How To Fix Canon Printer Error 5100 - YouTube
? 2:23
https://www.youtube.com/watch?v=rJQVwwRxPv4
Mar 14, 2013 - Uploaded by ITJungles
Learn how to fix the Canon printer error 5100, and have your printer running again. ... Reset error Canon ...
There's an error 5100 appear on my printer canon mp770. I need some help,please.
Problem You are unable to print and receive the message Error 5100 on the computer or printer display screen.
Cause Error 5100 is a carriage error that can usually be fixed by using service mode and flushing the printer heads when it has a blockage.
Solution Try the following:
If this doesn't work then the printer may need repair.
Oct 19, 2012 | Canon LASER SHOT LBP-2900 Printer
Error 5100 cannon mp460
The root cause of Error 5100 in Canon inkjet printers can be so varied and so the solutions. If you want to read a best and well researched article on this topic, read it here:
Canon Error 5100
Oct 30, 2011 | Canon PIXMA MP460 All-In-One InkJet...
Canon mp198 service error 5100 came out. i can't print. Try solve this problem
[5100] or E,2,2 is CARRIAGE ERROR. Maybe is the faulty of CARRIAGE UNIT, LOGIC BOARD, CARRIAGE MOTOR or TIMING **** STRIP FILM.
May 20, 2010 | Canon PIXMA MP190 All-In-One InkJet...
Error 5100
error 5100 in all Canon printers is almost always something simply blocking the carriage.
Jul 24, 2009 | Canon PIXMA MP150 All-In-One InkJet...
5100 error with canon i255 printer
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.
Dec 24, 2008 | Canon MultiPASS F60 All-In-One InkJet...
Canon ip2000 service error 5100
I have been facing same error and this was the solution.
Canon Error 5100
Sep 08, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
2,816 people viewed this question
old marine
old marine
