Question about Dell Dimension 2400 PC Desktop
I need to upgrade my usb port 1.1 to 2.0
  • Shahid Electronics
    Shahid Electronics Aug 23, 2010
    hey muebe, I need your help to fix my notebook problem, shoot a message on welcomejee at yahoo dot com to send you out details if you got this clarification request. thanks.
    President:
  • 1,015 Answers
The easiest way for you to do this is to get a USB 2.0 pci card and install it into the computer. Here is one that is available for $10
http://www.newegg.com/Product/Product.aspx?Item=N82E16815124008&cm_re=usb_2.0_pci_card-_-15-124-008-_-Product
These are fairly easy to install. It does require you to open the computer case. Remember to unplug the computer from the electricity before starting and properly ground yourself before touching any components in the case(static electricity can damage them). You should use a grounding strap that hooks to your wrist and attatches to the case or touch the case each time before touching any components. Once the case is open you will need to locate an empty PCI slot. Then use a screwdriver to remove the metal "Blank" that is covering the opening at the back of the computer. Then you can insert the new card with the USB ports facing the back of the computer and use firm but gentle pressure to insert the card into the port. Once the card is fully seated secure it with the screw you removed from the blank. Then plug the computer back in and run any installation software that came with the card if required and that is it.
Posted on Jul 04, 2010
  • Dell Master
  • 4,806 Answers
It would be a good idea to as because of most devices being USB 2 you will get a message saying "this device can perform faster" each time you plug a USB2 device into the computer.
What you need to do is go to Dell's support website (link below) and download the latest bios update and chipset driver for your computer.
Make sure you follow the instructions for the bios update carefully. After its done you should have the USB2 upgrade.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WW1&osl=en&SystemID=DIM_PNT_P4_CEL_2400&catid=-1&impid=-1
Regards.
My pc does not recoginze it any more. Power do not come when plucked but only flash once
1 have you change OS (operating system0 that is have you upgraded to Windows 7
2. Have you upgrade or changed anti virus software.
3. check the " Device manager" for corrupted USB ports.
4. make sure the contact for the male end of the USB are making contact to the female input of the USB port.
Sep 08, 2011 | Alesis IO/2 Portable 2-Channel/ 24-bit/96k...
Can my designer 1 be updated to use a cd and a usb port.
In one word: No. Sorry. It can be updated to a USB port, but the port will only accept Husqvarna formatted USB sticks, not an external CD drive. This is not to say you have to purchase Husqvarna USB sticks as well as pay for the USB upgrade - it will take any USB sticks, they just have to be formatted with the Husqvarna software which comes with the upgrade.
Nov 13, 2010 | Husqvarna Designer I
I have an ACER ASPIRE X1700, and I don't know where the printer UBS port is. Could someone please help me?
You can place the Printer USB Cable in any USB port.
If you are not familiar with how the USB port please refer this link.. USB PORTS
Hope this will helps you.
Thanks & regards
Nandu :)
Dec 31, 2009 | Microsoft Windows? Vista Home Premium...
When i plug in my memorycard adapter into the usb ports .the baloon says i need a hispeed usb host controller.
The memory card you have is for a USB2 configuration and the USB port configuration or port you are using is USB1 configuration.
Try a different port or check the manual for port layout or description.
Sep 26, 2009 | DFI WB72-SC Motherboard
Upgrading two USB ports on front panel
Hi..
there is no such converter..
those pins should connected to ur mother board only...
once check ur bios settings..
or
use external usb hub..so u can get multiple usb ports that u need...
Jan 01, 2009 | HP Pavilion 761n PC Desktop
UPGRADING USB 1.1 TO USB 2
I searched and found a 1/2 height PCI card with 2 USB ports, plus a internal connector for two more ports. My little NetVista will not hold a full-height PCI card. Get out your tin snips.
Works like a charm !
FYI: I disabled the BIOS USB support for the old ports, and plugged the old MB cable into the new PCI card. I now have two 2.0 ports on the front, and two 2.0 ports on the back. However, I lost the ability to boot from USB
Aug 31, 2008 | IBM NetVista X41 PC Desktop
Missing USB controller driver
When posting driver issues, you need to specify what kind of equip you are dealing with, not just the issue. Most liekly you need to go to the manufacturs website of your motherboard or laptop and find vista drivers for it.
Jul 29, 2008 | Acer Aspire 5100 Notebook
Can some 1 help me with my fta
Loading Viewsat Ultra Via USB Flash Drive
1. Load File(s) to your USB Flash Drive. (eg.. PFTAUSW-070911U.PGM)
2. Take USB Flash Drive and insert it into Viewsat Ultra USB Port (behind right
side door flap)
3. Using remote Hit Menu. Then Go to System Information -> Receiver Upgrade
and Hit OK
4. Go to USB and Hit OK.
5. You will now see a list of all the files located on your USB Flash Drive. Find the
file you need to load. (eg. PFTAUSW-070911U.PGM) and select it and hit OK.
6. Your Receiver is now being upgraded.
7. It will come up showing you not to power off the unit.
8. Once it has finished the receiver will reboot and you have upgraded your Viewsat
Ultra.
Dec 28, 2007 | Computers & Internet
Can't upgrade the USB ports to Version 2.0
Hi cogilbert,
I had a similar problem with my PC which had older version 1 USB. I purchased a USB 2 PCI card with USB Hub, installed and problem solved. It really not a very expensive proposition. The card comes with the necessary software and drivers. It works great.
--RoadHawk
Nov 29, 2007 | IBM NetVista PC Desktop
Dell Dimension 2400 PC Desktop Logo
83 people viewed this question
Alun Cox
