FixYa.com
Tags:
Intel D845GVSR Motherboard
Problem with "Intel D845GVSR" mother board with 1GB... (by 5 users)
By Phoebe - usenet poster
I have recently bought computer with following
configuration
Mother board :Intel D845GVSR
Processor    : pentium 2.8c
RAM          : 512 * 2
Os           : xp ,Professional 2002
The Problem is that my computer crashes too often, 10-15
times a day. But if I run with any one of  the ram
installed it works fine .
I have tried running windows mtinst.exe utility. It gives
me no error on separate run but if I run with both ram
installed I am getting error in
RAND test case. Please help me to resolve this problem.
Right now I am running in just one ram.
Thanks,
Awaiting your reply.
Sriram
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
4 Other Users Have The Same Problem
Comment by Guest, posted on Mar 25, 2008
need drivers 845 G urgente Intel D845GVSR Motherboard
Comment by Guest, posted on Feb 15, 2008
 mm
Comment by intelprobs, posted on Dec 28, 2007
my usb and audio aint configured, what must I do to correct that
Comment by Guest, posted on Dec 20, 2007
Waiting for advice from experienced
Clarification Request
by diginet, posted on Feb 12, 2008
please suggest me compitable VGA Driver for VISTA of Intel 82845GVSR mainboard
manoj kulkarni
Best Solution
posted on Aug 10, 2005
Helpful (85)
Gary10
Gary10 - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Sounds like one of the RAM modules is damaged.  Have you tried running on
one module, each one, one at a time?  IOW, is the problem *only* occurring
because you use one module, OR, when you specifically use only one of the
modules (either one)?
I would recommend downloading and running memtest-86 (
http://www.memtest86.com ) too, as a cross-check against mtinst.exe.  It's
FREE, easy to use, and just requires creation of a bootable floppy.  Boot
the floppy and let it run through several passes, preferrably overnight.  If
the memory is damaged (or overclocked beyond spec and not capable of
sustaining itself), memtest will often find it (i.e., report errors).  If
you're not overclocking, then it's probably a bad RAM module.  I recommend
testing each module individually, then together.
It's also possible the SPD (Serial Presence Detect) feature is reporting
incorrect information, OR, your motherboard is not interpreting it
correctly.  SPD is how the RAM and motherboard "negotiate" the DRAM timings,
so that each configures the other properly.  If this information is conveyed
incorrectly, your DRAM timings may be overspec'd, and thus not capable of
obtaining stability.  In that case, you might need to manually reduce the
demands on your memory by increasing DRAM timings (e.g., CAS latency).
Btw, are these a "matched" pair of DIMMs?  IOW, are they identical in terms
of brand, spec, timings, etc.?  Obviously if NOT, you'll have to run them at
the lower of the two specs.  Again, SPD has been known to be fooled by this
type of situation.
One other possibility is a poor or failing power supply.  Especially w/
today's high-performance memory, and GOBS of it, you want a strong,
dependable power supply (prefer Antec and Enermax myself).  A cheap power,
particularly on the 3.3v rail, sometimes cannot deliver enough power to
support the RAM, or do it without fluctuations.  You want a strong, steady
power delivered to the RAM, or it can lead to instability.
HTH
Jim
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Sep 02, 2008
Not Rated (0)
jibon701
Rating: 0%, 0 votes
I find a very good site for Intel Motherboard Solution. Try the site click here.
Please Rate me if this information helpful for u.
Solution #3
posted on Aug 23, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
how to download vedio graphics drivers
Solution #4
Not Rated (0)
Kim1
Kim1 - usenet poster
Rating: 0%, 0 votes
It sounds to me like one of your mem slots on the mainboard itself is
damaged. You did say that you tried the RAM modules individual one at at a
time in your system, right?
Solution #5
Not Rated (0)
Rogers
Rogers - usenet poster
Rating: 0%, 0 votes
either your motherboard won't support that much ram or
you have a defective module.
try switching the modules to see if one is bad
don
Can you Help with these Motherboards problems?
Motherboards
about hardware and motherboard
HI Sandrew, I have some problem... Answer This...
Motherboards
mother board jumpers setting
sis mother board jumper setting... Answer This...
Motherboards
problem with the caracteres
hi please help be to have a... Answer This...
motherbord driver needed
i have intel 845gvsr mother... Answer This...
Motherboards
disque cod?
Bonjour,j'ai un probl?me avec... Answer This...
Repair Service
Find Motherboard Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
