Question about HK (SHENZHEN) INDUSTRIES DEVELOPMENT Huakun 1/8 TV8025 TOYABI RC Monster Truck
Hi,i have a powered hk elias 112A speaker i have changed two fuses on the board it still powers up but still no sound form the speaker can you help thanks.
Hi, I have a plasma 42inches TC-p42gt25, I have
sounds like bad capacitors on the power supply board
Len..
Oct 13, 2014 | Televison & Video
HK AVR 125 display strobing and no sound, even in headphone jack
Hi...
Find someone that does TV or audio repair and have them open it up. A cable assembly may have loosened during the MOVE.
Cheers
Jan 30, 2014 | Harman Kardon AVR 125 Receiver
HK 3370 power button turns red when pressed device will not turn on
There may be a short on the output side. Try disconnecting all the speakers on the back of the amp. If the unit stays on after that, turn off the amp and carefully reconnect one speaker at a time. Try turning on the amp after each reconnection. This might isolate any shorts that might exist.
Nov 09, 2013 | Harman Kardon HK 3370 Receiver
Hi, I bought a new JBL SCS 140 system with amp HK
Fuses blow when something is shorted. In this case it will be a semi-conductor of some kind. If the device uses IC for the main amplification then you are right to be worried!
The 158 amp is totally unsuitable for the JBL.
This is the specification of the JBL:
  • Recommended Amplifier Power 10 Watt
  • they are also 4 Ohm speakers.
  • 158 is: Output Impedance / Channel
    8 Ohm.
May 31, 2017 | JBL PB10 Subwoofer
Connecting 4 ohm speakers
I don't think it has anything to do with the impedance. The amp and speakers are well in the allowed limits. The only time this is a problem is if you connect an amp with a greater impedance then the speakers.
This sounds like something to do with the HK 990. It could have a fault on it. You could try listening with headphones if the HK 990 has a socket for them. If they have low sound, there's an electrical fault in the power amp of the HK 990.
Jun 09, 2012 | Harman Kardon Harman HK 990 Amplifier
The volume is to low, i have turn it up to the max, but still it to low, plz help! /Elias
more than likely the power supply accociated with the speakers is either bad, or the speakers are dying.
Dec 11, 2009 | Logitech X-240 Computer Speakers
Humming sound(speakers)when HK AVR 3550 is powered up?
yea try use in a monster power strip it clears al of that up it is picking up noise from all the wires
Apr 02, 2009 | Harman Kardon HK 3550 Receiver
Humming sound (speakers)when HK AVR is powered up.
In my case the buzz was only on front speakers. There are 3 capasitors (100uF/25V) very close to the cooling ribs of 3 regulators in the power supply. In my case the C922 was bad.
Apr 02, 2009 | Harman Kardon AVR 500 Receiver
No speaker sound with hk 3480.
your fuses are blown by possible crossing speaker wire - and + together. I did this and kept turning it on but I ended up frying the unit. Check your wires and make sure that they are seperated properly. If problem continues then unscrew the shell and replace 1 or all 3 fuses (depending on what was blown) with GMA 8 amp fuses. good luck.
Nov 20, 2008 | Harman Kardon HK 3480 Receiver
Harmon kardon avr 125 shuts down
If you want to fix it:
It must be a contact problem arount the power switch, power cable, fuse or the condensator area.
Maybe you can se a black color on the board.
And checking the solderind points with a magnifyer can help too.
Thats all from that distence.
Nov 11, 2007 | Harman Kardon AVR 130 Receiver
HK (SHENZHEN) INDUSTRIES DEVELOPMENT Huakun 1/8 TV8025 TOYABI RC Monster Truck Logo
102 people viewed this question
Top HK (SHENZHEN) INDUSTRIES DEVELOPMENT Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a HK (SHENZHEN) INDUSTRIES DEVELOPMENT Toy Expert? Answer questions, earn points and help others
