Question about HP Photosmart C5280 InkJet Printer
How do I scan an item and send a copy to a friendI am using a Photosmart C5280 printer
    Guru:
  • 366 Answers
Please follow the steps below to do a clean installation of your scanner.
The first thing we need to do is remove any files that have been installed and start with a fresh installation.
1) RIGHT-CLICK on the MY COMPUTER icon and click on PROPERTIES.
2) Select the HARDWARE tab, then the DEVICE MANAGER button.
3) Remove the Epson Scanner from under IMAGING DEVICE and/or UNKNOWN and/or OTHER DEVICES by RIGHT-CLICKING on it and clicking UNINSTALL.
4) Disconnect the USB cable and close all open windows.
5) Click on START, and CONTROL PANELS.
6) Double-click on ADD/REMOVE PROGRAMS. Highlight EPSON SCAN and click on CHANGE/REMOVE.
7) Restart your computer.
DOWNLOAD
Please follow the steps below to download and install your scanner in XP:
1. Go to the website http://support.epson.com
2. Under the SCANNERS heading select PERFECTION SERIES and then your scanner model.
3. Under the Drivers & Downloads section select Windows.(Make sure it is the Epson Scan utility. Download the most current version of the Scanner Driver for your Windows operating system to your DESKTOP.
Reinstall
1) Double Click on the Epson1**.exe file that you downloaded to your DESKTOP.
2) Click OK, Unzip, and then OK again.
3) The installer will copy the files to the system. Click on FINISH when prompted.
4) Connect the USB cable. Windows will tell you new hardware is found and complete the install.
5) If a message appears indicating THE SCANNER HAS NOT PASSED WINDOWS LOGO TESTING, click CONTINUE ANYWAY. Then click FINISH.
6) Your scanner is now ready to use.
Use the following steps to scan with the Epson Scan utility:
1. Open Epson Scan by going into START, PROGRAMS, and EPSON SCAN.
2. If prompted, select your scanner from the list of models and click OK.
3. In the FILE SAVE SETTINGS window, you can designate the location, name and type of file the scans will be saved as.
-LOCATION defaults to MY DOCUMENTS. Click BROWSE if you wish to change this.
-PREFIX determines how the scan will be named. Type any name you like. You can also designate a start number.
-FILE TYPE dictates what format the scans will be saved in. ie. .JPG, .TIFF, .PDF, or .PICT)
-For example: if the prefix is "img", the start number is "1", and the format is "JPG", the name of the file saved in
PICTURES will be "IMG001.JPG". More settings for file format are found under OPTIONS.
  1. Click OK once settings are changed as desired.
  2. The EPSON SCAN window will open and begin scanning in FULL AUTO MODE. In FULL AUTO MODE the software makes all the decisions for you (as to what is being scanned, where it is on the flatbed, etc). This is the easiest way to scan.
  3. If you want full control over the scanning process click PAUSE and change FULL AUTO MODE to HOME MODE or PROFESSIONAL MODE. In the latter two modes you can change your scan settings as desired. Click SCAN after you have selected your settings. Click CLOSE once the EPSON SCAN is finished scanning.
  4. When scanning is complete, your images will be saved in the location specified on FILE SAVE SETTINGS, with the prefix and in the format you set.
  5. Now you can use them in mail and send to your friend.
Posted on Jul 04, 2010
C5280 quit scanning on mac
Please check if you are able to make a standalone COPY using you C5280. If it does, then uninstall and re-install the printer software on your MAC.
Mar 31, 2014 | HEWLETT-PACKARD PhotoSmart C5280 Printer...
HP C5280 not scanning
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=46909&tmp_task=solveCategory&cc=us&dlc=en&lc=en&product=3204464
here are HPs tips on scanning issues. If no resolve and under warranty contact HP. If out of warranty, it will likely be less expensive to replace the unit than to repair it.
Nov 04, 2011 | HP Photosmart C5280 InkJet Printer
I have pluged the laptop into ny HP Photosmart C5280 All in one printer scanned the document but wher do I find it on my laptop thanks
Hi
It will store all the scanned files in My PICTURES under MY DOCUMENTS. You will find a folder with name Scanned.
Aug 01, 2011 | HP Photosmart C5280 Printer
My HP Photosmart C5240 will print from computer but will not scan or make copies.
Is there any error message displayed on the control panel of the printer just like one of the following:
Scanner failure, power off and on
Scanner System Failure
Scanner failed, cannot make copies or fax
Scanner failure. Unable to scan, copy, or send a fax
Scanner failure, cycle power
You may want to try following these steps:
1. Check if the scanner light does turn on when you initiated the scanning process, if not you need to reset the product.
2. Try using your other electrical outlet because your AVR or Surge Extension may not be providing enough voltage for the printer.
3. Try using dirty cycle, meaning you need to directly cut the power of your printer by pulling of the power cord from the rear side of your printer and wait for about 30 seconds before inserting again and turn it on.
If all these steps do not improve your printer functionality, you may want to call the HP online help and ask for replacement.
Job Espinosa
Feb 15, 2011 | HP Photosmart C5280 Printer
How to use my hp photosmart C5280 All in One scanner unsing mac leopard
When you install the Full Feature software for your printer, you receive the HP Photosmart Studio imaging software and the HP Utility printer management software. You can use either of these programs to scan, and can create custom settings in both.
In general, use HP Photosmart Studio to scan pictures if you want to edit them to adjust color, crop, remove red eye, etc. Use HP Utility to set up scan tasks you use often, such as scanning to a certain folder or software application, or attaching the scanned item to an email. If your printer has a display, you also use HP Utility to designate which scan tasks should appear on the printer display menu when you start a scan from the controls on the printer.
Make sure that the printer is connected to the computer. Turn it on. Place the item with the print side down on the scanner glass.
Use HP Photosmart Studio to start a scan: Click the HP Photosmart Studio icon in the Dock. Click the Scan button. Select your HP product in the Device Name list, if necessary, and then click Continue. From the Scan Profiles screen, click either Pictures or Documents. Click Profile Settings , and then adjust any settings in the Capture , Adjust , and Page Options (for documents) or Enhance (for pictures) tabs as appropriate. Click Scan. When prompted, select Yes or No to add another page to the scan. The scan preview opens then click Return to close the preview and save the scan. Type a name for the scan in the Save As box. Click the Format drop-down list, select the file format you want, and then click Save.
Dec 10, 2010 | HP Photosmart C5280 Printer
I can send a document to the printer and print,
check the settings on the driver software, next check the configuration on the printer
Mar 19, 2010 | HP Photosmart C5280 Printer
Where to plug in phone port for the HP c5280
I'm sorry but the C5200 series printers do not have a phone port. It is not a Fax capable printer. It scans, copies, prints and does photo prints.
The only ports you have are for the USB cable and power cord.
Here is a manual link for reference.
HP C5200 Manual
Thanks for using Fixya.
Sep 26, 2009 | HP Photosmart C5280 InkJet Printer
Hp photosmart c5280 won't scan to my computer
hi,
may be due to proper driver or scanning software problem. use following link to get proper driver for scanner and for scanning software.
Aug 17, 2009 | HP Photosmart C5280 Printer
Scanning to my PC from my HP Photosmart C5280 Printer
hi!!!!
try to check the port of your printer or replaced the usb port
Sep 20, 2008 | HP Photosmart C5280 Printer
HP Photosmart C5280 InkJet Printer Logo
116 people viewed this question
Seeker5211
Seeker5211
