Question about Tascam 2488 Portastudio Multitrack Recorder System
I've just got a tascam dp01cf recorder and i'm having trouble with it, its abit hard to understand what to plugs in were, i'm using a electric guitar,a yamaha magicstomp effect pedal and a amp. also i'm trying to put the cd backing track from a song into the tascam first ,then play over it with guitar. also i've tried to listen to a recorded track and not sure how to plug a aux to it etc, any help would be good regards mark
    Novelist:
  • 189 Answers
You have a couple of options with your guitar input. You can either plug your guitar directly into the right (Hi-Z) input and use the Tascam's onboard effects with it instead of your effect pedal.
You can put your pedal in the chain between your guitar and the (Hi-Z) input. So guitar into pedal is, pedal out into Tascam Hi-z in. (Still doesn't use the amp).
Or my preferred method for recording guitar would be to mic the amp. In that case you'd just input a microphone (placed about 8-12 inches from your amp) and record your guitar that way. The mic would be plugged into either one of the Tascams two mic inputs to record the amps speaker output while your guitar, pedal and amp would just be hooked up in the normal way.
Please note: Never plug the output from an amp into any of the Tascams inputs. Those inputs are line-level and the speaker output level which comes out of an amp out would damage your Tascam.
To get a backing song into a track in your Tascam, you'll have to first, using a PC, get the song into a 16 bit mono Wav file format. Then you'll have to use the USB import function to copy that wav file onto your Tascam onto the CF media cards fat partition. From the you'll be able to import it into the Tascam choosing which track it will import into.
Cheers,
BD
Posted on Apr 21, 2008
I have a tascam 488 mk II when its turned on the play record and pause lights all are blinking and dont know why?
check to see if any of the buttons on the play/record panel are pushed down or stuck if not go to the tascam website and submit a trouble iinquiry
Oct 08, 2014 | Tascam 488 MKII Portastudio
Tascam 2488 system error code 1
I had
System error code:01
on my Tascam 2488 neo
Turns out it was a hard drive error. I tried everything. I used the "Quick Routing/Shift/Send/ShutDown" trick where you press all four buttons at once and keep them pressed down throughout while you power on the unit util you see a message saying "System Reset Complete. Now Power Down". Numerous times it came on and said stuff like "creating partition," "creating song" and "now working" but it always ended with "System Error Code:01". That trick is upposed to reset system par?meters to default and erase everything from the hard drive and reset the hard drive. I even removed the hard drive, hooked it up to my Windows 10 PC and used Windows utils to reate and/or delete partitions and both "quick" and regular format. I also tried all the hard drive utils from the manufacturers like a formatting and a scrubbing util etc.,.nothing ?orked until I downloaded, inst?lled ?nd used a low level format utility called "Hard Disk Low Level Format Tool," its installation file is called "HDDLLFsetup.4.40.exe" which is available from mul?iple internet sites, just search for it. Here is how to repair your Tascam hard drive or prepare any new hard drive for installtion or upgrade that is giving endless problems and system error codes on the Tascam:
1. Open your recorder and remove the hard drive from the Tascam. If you're unsure about doing this there is a YouTube video av?iable about how to replace your Tascam 2488 hard drive.
2. Connect that drive by any means available to your laptop or PC. I used a USB to SATA ad?pter and connected it to my laptop, I also successfully did this using my desktop PC.
3. Run the "HDDLLFsetup.4.40.exe" application and install it.
4. Now use the newly installed "Hard Disk Low Level Format Tool" utility.
5. Select your hard drive then the low level format tab and don't sele?t the "quick" option, make sure it does a full low level format. It'll be slow and t?ke some time. Any hard dive prepared like this will ?ork in the Tasc?m except incompatible or damaged hard drives.
6. Reinstall hard drive into Tascam and simply power on the Tasc?m. Do not use any special boot up tricks with any key combinations, just turn it on.
7. Select "yes" when asked if you want to form?t the drive. W?it a few seconds until it completes cre?ting and working. It should boot up to normal use mode and be ready for recording within 3 minutes. If yours takes longer your hard drive may be damaged and need replacing. I tried other hard drive utilities from Hitachi, Seagate, S?msung and Western Digital but none worked. O?ly the "HDDLLFsetup.4.40.exe" was able to fix the problem.
Dec 15, 2012 | Tascam 2488 Portastudio Multitrack...
Cant hear audio on tascam 2488i brand new to using it but i do understand how to record a track on my display screen i can see the audio i recorded but no sound what so ever i have my headphones plugged up...
hi
Tascam Digital recording is an effective solution for broadcast-quality home recordings. The Tascam 2488 is a user-friendly tool and useful for home recording situations, especially when writing songs or cutting demos. It even has bus compression and processing for your final mix to give it that "mastered" feel. There are other recorders as well.
Instructions
  1. Learn your gear. The Tascam 2488 DAW offers 24 discrete channels that can be recorded at up to 24-bit resolution. 16 tracks can be recorded simultaneously, via eight XLR balanced inputs and eith 1/4-inch unbalanced inputs. There are several high-quality built-in effects, such as reverb, delay, modulation, compression and a great tool for guitarists: amp and effect modeling. So you can simply plug directly into the console and get live amp tones.
  2. Record or program the rhythm tracks. Most Tascam products offer a large library of built-in drum loops to construct rhythm tracks, so you don't even need live drums just to get a song down. You can designate the tempo of your song from the transport located on the right side of the console; this is where you would use a variety of buttons to make edits, undo or redo and automate punch-ins
  3. Record your base rhythm instrument. Let's say a rhythm guitar. There is a dedicated guitar input located on the front of the console, and once you're plugged in you can use the aforementioned amp modeling features to dial up a sound.
  4. Record the remaining track or tracks. This could include bass, vocals, keyboards, horns or any other instrument. The process is always the same. Arm the track you wish to record on, hold in record and hit play, and the machine begins to record whatever you are playing. When you're done, hit stop. If you want to undo what you recorded, simply hit the undo button.
  5. Repeat these steps on any other instrument you want to record. Plug a microphone into one of the first eight XLR inputs, the first 4 of which have phantom power for studio condenser microphones, arm a track and record.
  • If you need to punch-in a section, you can automate it by dialing up the time in the song you wish to replace using the auto punch function. When you enable this and choose the time in the song you wish to record over, once you hit record and play it'll start the track a few seconds before where it begins the punch-in and it will only go into record when it reaches the designated time stamp.
Do not rush. Proper recording takes time and patience.
hopefully this can help
regards
Jun 11, 2011 | Tascam 2488 Portastudio Multitrack...
Tascam 238 Syncaset 8 track Pro recording deck needs new sensor belt. Looking for a belt kit for this unit. Problem has been diagnosed but the tech I've found to service it wants me to get the...
If he wants you to get parts then I would suggest you get a different Technician. Why would any Technician want to go to the trouble and risk of the customer getting the wrong belt.
You can get a set of belts from Marrs Communications for that model.
http://marrscommunications.com/tascam-cassette-kits
Jun 02, 2011 | Tascam Audio Players & Recorders
Recording on cubase le4 using my tascam us122 mk2
You're probably not recording through your tascam interface. Go to control panel -> sound, and then select the us122 as your default sound device. Close cubase and open it again. Then go to devices -> device setup, and then under your asio drivers, select asio us122. That should solve it
Oct 25, 2009 | Tascam US-144 Sound Card
Im getting no sound when i used too get sound
Try new jacks,if you are always unplugging them,they can go bad,hope this works for you.
May 16, 2009 | Tascam CC-222mkIII CD Player / Recorder
2488 as an interface
yes if usb connection
yes if you can connect line in line out connection
yes pararlell port connecting
May 07, 2008 | Tascam 2488 Portastudio Multitrack...
Can't record in stereo
I have a tascam 144 that came with cubase. I am not able to figure out Cubase either. I am a beginner and am trying to record my yamaha electric drum set with it. so far no luck at all.
Feb 25, 2008 | Tascam US-122 USB Audio/MIDI Interface...
US-144 noise
Hi
Usually Noise comes from distortion such as Electricity (50-60Hz), Main reason audio input cables might have shielding problem. Make sure cable is connected well and shield is not destroyed. You can understand it when you unplug the input connection and use the Computer volume by playing a digital media. If distortion persists contact to TASCAM @+1-323-727-7617
Good Luck
Jan 11, 2008 | Tascam US-144 Sound Card
Tascam 2488 Portastudio Multitrack Recorder System Logo
164 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
