Question about Rainbow Rainmate Air Purifier
Do you know where to get diteclear solution for cloudy water?
There are 2 holes on underside of filter housing & when turn on filter water , out both holes, why I hate running it as you don't know if you are getting filtered water from both holes.Help
The main problems I'm seeing on these posts for this filter are design and operater issues. 1. I never run hot water through the unit in filter mode. 2. I never run cold water through the filter turned on high (pressure issues arise), it doesn't filter the water any faster. You just want enough flow to run through the filter. 3. The steel sleeve was a good solution (again pressure) but came up alittle short (ie my epoxy fix). 4. The light is powered by a chip batterey that is unreplaceable and may be bad. Try reinstalling the cartridge. I personally pay no attention to the lights other than a clue. I change my filter when the taste changes or there becomes a flow issue. 5.There are filter screens prior the filter that can become clogged if you live in a poor water area. 6. The filtered water only comes out of the spigot and no other leaks (something loose or pressure issue).
Sep 30, 2013 | PUR (FM-9500) Air Purifier
It doesn't turn back on when I put the water catcher in it and I found this piece for it and I don't know where it goes.
I don't know the final solution but do want to brainstorm with you so you are not alone in the fixing process....
White Westinghouse Dehumidifier - Model Number >>> ????
http://www.searspartsdirect.com/partsdirect/brands-products/White-westinghouse-Parts/Dehumidifier-Parts
Sears is your friend here. They often have blow-up diagrams of how these units work. Just find your model number and look at the parts diagram if you can find it. 9/10 Sears has given me the answer through their online manuals.
Post your answer if you've figured it out.
Feb 10, 2013 | Air Purifiers
I have a Eqoquest fresh air air purifier, I had a flood and water was inside unit, insurance company wants to know cost to repair or if needs to be replaced, where do i go to get it deemed...
The simplest way is to do a Google Search for you make and model air purifier. You'll be able to see what they sell for now. I can tell you this though, if that unit was under water, it can't be repaired. It's been contaminated.
Feb 11, 2011 | Ecoquest Fresh Air Air Purifier
I cannot locate my manual and I am trying to figure out how to remove limescale/calcium carbonate from the unit. My humidifier is not part of the vacuum cleaner it is the smaller one that you sit on the...
with a wet or dry old tooth brush. use a firm one though. you can also dip in a solution of CLR mixed with water,then wip it dry. dont forget to clean the spicket by turning it counter clockwise and using a q-tip or baby bottle nipple brush . do this under running water. good luck
Dec 22, 2010 | Rainbow Rainmate Air Purifier
How much water should i use
I run mine day and night while home and clean and re-fill it every morning. I also use one of the room odor eliminators in my Rainmate. Fill the water one inch above the line about an inch off the bottom of the water container.
Aug 20, 2009 | Rainbow Rainmate Air Purifier
Condensation forms on the top inner ceiling of the refrigerator
Very common problem I have repaired many times , The drain is frozen or plugged.
remove the back panel in the freezer section to get to the evap./cooling coil , then check the pan under it , there is a small 1" drain hole at the bottom that may have ice in it or its clogged with something else.
Use hair dryer or similar to remove ice then get a wire or something similar that is firm to use to snake out and clear that drain hole you want to get about 10 inches down into it.
Pour bleach into evap pan and let it sit for a bit. [10 minutes]
Then to know its cleared well pour a cup of water into the evap pan then check the pan under the unit at bottom behind kickplate to ensure the bleach and water has made it to this pan.
If unit is now draining here , wipe remaining water off top of ref. compartment and by the next day it will usually stop.
Let me know if you have any other questions.
Phil
Apr 14, 2009 | Sharper Image Ionic Breeze GP (SI730) Air...
I just set up my new rainmate in my son's room with the eucalyptus scent (he has a cold/cough), and I needed to know how safe is it to leave the unit running overnight, and how long does it take for the...
Hey im a dealer for Rainbow. RockyNR1 is correct but let me just add that you can fill it to over the line if you want as long as the 'misting' still happens, be careful that the bowl is not near the edge of the surface as the spinning water might make it fall off the side. How long the water lasts is also very dependent on how large the room is that its in. Lastly you should be able to leave it run for 24/7
Jan 27, 2009 | Rainbow Rainmate Air Purifier
Cloudy looking water
Does it do this when you DON'T add any of the fragrance oils???? If so, it's yuck from the air. BUT, the fragrance oils are OIL and they don't mix with water, so as it swirls it tries to emulsify the oils into the water and that causes it to become cloudy.
I would still clean it at least every other day....every day would be preferable....especially if you live somewhere that mold flourishes like I do (Central Texas)
-D
Oct 10, 2008 | Rainbow Rainmate Air Purifier
Got Rainmate yesterday and either my house is REALLY clean or it isn't working
i had the same problem. The goo pulled from the air gums up the small orifice atthe bottom of the stem that sticks down into the water. If the water cannot be pulled up into the stem and expelled out towards the bowl at high speed, it cannot work. Take the upper, motor half off, unplug it hold the plate with one hand and twist the stem 1/4 turn and it comes right off. Clean the crud (yes, its your own skin cells) and the hole with warm water and soap. put it back together and refill with water and it works like new. this is now monthly maintenance for me
HTH
May 16, 2008 | Rainbow Rainmate Air Purifier
Water doesn't evaporate
the problem is with the pump
try opening the humidifier and removing the hose clear the hose out...check all connections to the pump and see if the pad becomes wet.... the humidifier should still evap even if the room is humid.... let me know if i can do anything else.... feel free to e-mail me at fixya@whypayforhelp.org
Feb 12, 2008 | Venta - Airwasher LW44 Air Purifier
Air Purifiers Logo
307 people viewed this question
Top Rainbow Air Purifiers Experts
OBHighflyer
jdthefixer
misskolika
Level 1 Expert
Are you a Rainbow Air Purifier Expert? Answer questions, earn points and help others
