Question about ParkerVision SIGNALMAX WR1500 (884181000031) Router
Disconecting from time to time wr1500 - ParkerVision SIGNALMAX WR1500 (884181000031) Router
Need the transformer specs for ParkerVision WR1500-WR3000
p/n 30-112-120602
model ad48-1201200du
here you go
input 120vac 60hz 250mA
output 12vdc 1200mA
Apr 26, 2010 | ParkerVision SIGNALMAX WR1500...
What is the parkervision wr1500 defaul password?
By default your password for this router is 1234, but if it doesn't work it means that it was change already so better try your commonly use password and if still wont work reset the router to bring it back to its default settings with default password.
Mar 23, 2010 | ParkerVision SIGNALMAX WR1500...
Specifications for AC Power Adapter
In is 110-120 vac and 12.0 vdc.
Hope this helps!
Visit us at http://www.nipycom.com for more help.
Dec 19, 2008 | ParkerVision SIGNALMAX WR1500...
Voltage/Ma of AC adapter for WR1500??
The power supply on my ParkerVision WR1500 router is 12 vdc, 1.2a, center pin positive. http://straylightsoftware.com/downloads/parker2.html
Oct 29, 2008 | ParkerVision SIGNALMAX WR1500...
ParkerVision Signalmax WR1500
from the original docs:
Reset Button
The WR1500 Wireless Router reset button is built into the rear panel. Use this button to restore the factory default password to 1234; IP address to 192.168.1.1, subnet mask to 255.255.255.0 and DHCP sever enabled with a pool of 8 IP addresses starting at 192.168.1.33.
note my unit resets to ip 192.168.150.1
Sep 29, 2008 | ParkerVision SIGNALMAX WR1500...
How to get to the DMZ
it seems that the wr1500 doesn't have a DMZ feature. im not sure if it has a latest firmware that will provide DMZ but what you can do is use the port forwarding feature. you just need to know the ports of the applications that you want to pass the router's firewall
hope this'll help you and just ask me if you have other concern
ciao!
Jul 09, 2008 | ParkerVision SIGNALMAX WR1500...
Inquiry
Type ghttp://192.168.1.1h as the URL Address
May 25, 2008 | ParkerVision SIGNALMAX WR1500...
ParkerVision SIGNALMAX WR1500 (884181000031) Router Logo
35 people viewed this question
Top ParkerVision Computers & Internet Experts
Aris C.
Aris C.
Larry Maranto
Are you a ParkerVision Computer and Internet Expert? Answer questions, earn points and help others
