Question about Keurig B50 Coffee Maker
Keurig: How to take Housing off top?
I stuck a toothpick into the metal needle spout and it got stuck up in the housing. Can anyone tell me how to take this part off the machine? there are 2 metal screws, but not sure what tool to use.. They seem foreign. thanks
Don't stick things into the coffee pot then. why a toothpick?
Use a small phillips and turn them with enough force but not to break the plastic housing.
Posted on Apr 29, 2008
Keurig Elite B40 Won't Close
Pour a 1/2 vinegar 1/2 water solution into keurig and run a few cycles...its clogged
Feb 22, 2015 | Keurig Coffee Makers & Espresso Machines
Keurig B31 one cupcoffee maker users mannual
Keurig calls the B31 the Mini Plus Brewer. The manual is available from the Keurig Customer Service site: http://www.keurig.com/customer-service/brewer-registration-and-support/user-guides-and-help . The direct link to the English version of the Use and Care Manual is http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/Files/Keurig%20Brewer%20Manuals/B31%20UCG%20ENG_FRE.ashx .
I hope this helps.
Nov 08, 2011 | Keurig B60 Coffee Maker
My Keurig rarely brews a full cup. When I got it in October 2009 it was fine but now it often will start brewing then drain 90%+ of the water back into the tank -- I can watch the hot water go back in if...
There is a pin that punctures the k-cups. Take a pin, paperclip or toothpick, and stick it through the hole at the top of the pin. Apparently, grinds get stuck in there, and the water can't flow through, so it drains back into the reservoir. Helped me!
Feb 22, 2010 | Keurig B60 Coffee Maker
Thermostat
Just follow the top radiator hose to engine it is attached to a metal tube and inside the metal tube is the thermostat there should be two bolts holding the housing on.
Sep 10, 2009 | 1999 Chevrolet Malibu
My machine only brews 1/2 cup of coffee. I have de-scaled twice within the last week and I get a full cup of vinegar/water, but as soon as I put in a K-cup I only get 1/2 cup of coffee out. The first cup...
I had some coffee grounds stuck up in the cone shaped hole that the water comes from at the top. I had to use a very long toothpick but it broke up some of the grounds that happened to get caught up inside. Before doing this, I went through 24 oz of vinager ;) .. the toothpick worked!
Aug 15, 2009 | Keurig B60 Coffee Maker
Husquarvana Viking model 630 needle doesn't move when powered up
if the balance wheel is moving round okay manualy it could be but it could be thread lock or just a tiny bit of fabric stuck in the workings
Jun 12, 2009 | Husqvarna Viking 1
MY KEURIG IS BLOCKED AND THE WATER WILL NOT COME OUT
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage.
Apr 04, 2009 | Keurig Elite B40 Coffee Maker
Need to no know how to take apart!!!!
I hope this reaches you, as I had the same problem. You start with the metal screws attaching the handle. The screws are strange, but you can use a small phillips... you need enough force to turn them, but don't break the plastic. Get the handle off, then look under the housing on top of the needlle... if you look in there, you will see 2 screws... then when housing is removed, you'll see 2 more screws... in other words - carefully keep turning screws until you have the part open that you want. I started with the screws near the needle that is the spout. just remember the steps, so you can reverse and close the thing up. Any problems, you can email me at: bdubois@maharam.com, and thank you for serving our country! If you need a new machine, maybe I can get you one. Barbara
Mar 01, 2008 | Keurig B50 Coffee Maker
Keurig B50 Coffee Maker Logo
198 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
