I have a denon avr-485 surround sound receiver i had got from a friend with no manual and i can not seem to figure out how to connect it to my new t.v. i had purched a 32' jvc lt32p679. Can someone please give me some advice.
    Brigadier General:
  • 8,546 Answers
Find the manual at retrevo.com.
As far as connecting the TV goes. Consider that the TV is primarily a visual output device so resist the temptation to use it as a sound INput. The TV always gets its programming from somewhere else unless it uses its own antenna, so grab the audio from the source, not the TV.
You WILL need a Monitor Out feed to the TV so you can see what the receiver is doing during setup. It's in the manual.
I personally recommend against routing all video sources' video through an AVR because they add little in the way of improvement and introduce anomalies along the way. If your TV has enough video inputs I'd attach each one directly to the DVD/BD/Cable/Games, etc and run all audio directly to the AVR.
Posted on Jul 04, 2010
How do I connect a turntable to a Denon AVR 485.
If there is not a PHONO input, you may be out of luck.
Dec 21, 2014 | Denon AVR-485 Receiver
How do i connect my television to my receiver
go here to get the manual Denon and then the docs tab
Mar 07, 2014 | Denon AVR-485 Receiver
RE: Denon AVR 3300 - I cannot get the system setup menu to display on Phillips P50PFP5332D tv screen? All connected components work and sound great, but I cannot see Denon's Setup menu on tv to a
I understand, it's something I've misunderstood on my denon avr-790 as well when connected to a samsung 8000 series led tv.
The answer isn't in the receiver's settings (you can be on whatever source you want on the receiver end when toggling the menu). You need to toggle through the tv's sources to find the menu (usually found on hdmi 1). I've spent towards an hour recently troubleshooting only to find that it was the tv's source that wasn't set properly and I was trying to change the receiver's settings instead of the tv's source.
Hope that helps!
Jan 16, 2012 | Denon AVR-485 Receiver
My Denon AVR-75 seems to stay in standby (red standby light is on) and I don'd get surround sound through it. How do I get it out of standby?
if the receiver does not power on from standby there is a problem like bad power supply or even bad macroprocessor. You need to bring it to a service center for diagnosing. 10-years old receiver, maybe better to buy new one.
Nov 23, 2011 | Denon AVR-75
Power light blinks off and on Red
* The speaker terminals are shorted -- Disconnect speakers one at a time and try again.
* Ventilation of the unit is inadequate
* Has been running at too high a volume with inadequate cooling
Go here, register and get the manual for free....
http://www.fixya.com
Search for Denon-AVR-485S
May 04, 2009 | Denon AVR-485 Receiver
No surround on Denon AVR-485
Hi you must put the amp into prolgic mode this is fed by a stereo siganal the rears will sound vague and hollow that's all you will get this willnot work with 5.1 or 7.1 good luck
Feb 22, 2009 | Denon AVR-485 Receiver
No sound on the Denon receiver
If you are set up for 5.1 surround you may need to buy a digital coaxil of optical cable to receive the signal to the amp!
Jan 03, 2009 | Denon AVR-485 Receiver
Denon AVR-588 Sound Delay
FIRST, IF YOUR USING HDMI CONNECTIONS IN THE DENON HDMI SETUP YOU HAVE TO TURN THE AUDIO DELAY ADJ. ON
SECOND, THE DELAY TIME ADJ, FOR OTHER SOURCES IS LOCATED ON PG 27 IN THE MANUAL, HERE IS THE LINK TO DENON SITE WITH MANUAL
http://www.ca.denon.com/AVR-588-OM-E_102.pdf
Jul 12, 2008 | Denon AVR588 Receiver
Loss of sound on the Denon AVR 2807 a/v surround receiver when I turn on and off lights in my house
Finally the problem was with the HDMI cable. When I pushed it in on the TV set the problem disappeared. It seems the connections must be quite firm on the HDMI cables otherwise anything may interfere to the sound.
Jan 06, 2008 | Denon AVR-2807 Receiver
 Grubhead
Grubhead
