Question about Garden
Have broken the blade on a flymo qs46s!! cannot get the blade off!! have tried wd40 but will not shift!!
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 183 Answers
Try penertrating oil a good spray and leave it for at least 1 hour then spary again Then try and undo nutt if this does not work the only way then is to drill out the nutt but dont do this till u know you cabn buy another to replace it with
Posted on Jul 27, 2010
How to change blade on a flymo L470
there is a bolt that holds it on. just googled it
Jun 08, 2016 | Garden
Flymo problems
Try www.espares/uk
Dec 01, 2013 | Garden
My flymo 350 turbo compact isint cutting can i adjust the blade height ?
You can put spacers under the blade, a twin pack of spacers are available from Flymo part no. 513811081., from memory you are allowed to fit three spacers.
Aug 10, 2012 | Garden
The plate above the blade has broken. It still works but makes quite a row. Is it worth trying to repair an old flymo Compact 330? Martchard@aol.com
If the machine does a job for you and does it well it is. Most mowers have what is called the "blade adapter" piece which slides up onto the bottom of the crankshaft above the blade. If a "plate" is broken, parts may be available or you could have a welder fashion you one using the broken one as a guide.
Aug 23, 2010 | Garden
Model HTC24 Flymo Hedgetrimmer
Are both the blades still moving? Are the blades sharp?
Aug 01, 2010 | Husqvarna Garden
Flymo sabre hedge trimmer blades move but do not cut!
It sounds as if they have come off of the spindle inside and are not synchronised as they should be so the bottom blade is being pushed out of the way when trying to cut. You need to open up the head and unscrew the top to the small gearbox and make sure the bottom blade hasn't jumped up off of the catch point on the shaft.
Jul 23, 2010 | Garden
How to change impeller on flymo hover mower L38The plastic type
the small blades are just held on by push fit,,
grab hold of plastic blad and push it inwards to unclip them
fitting new ones pull them out before starting mower up
the inpeller is bolted to the motor shaft with a left hand thred on a kye way undo nut and just pull impeller off shaft,,, (there normaly stuck on tight with dirt or rust? a good drop of WD40 will help get the impeller to move down the shaft
Oct 30, 2009 | Garden
My Flymo microlite 28 lawnmower is very noisy...
You got it, replace the disc before you use it again.
Jul 09, 2009 | Garden
Flymo micro lite - cutting height of blade
you twist the plate holding the blades and it will lift off, then you turn the blade plate upside down and replace making sure you align the notches and then twist to lock into place. hope this helps
Oct 16, 2008 | Garden
Garden Logo
124 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
