Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
End to end configuration errors appears constantly ? fix
I have windows Vista and constanly get end to end configuaration errors and cannnot open files.
  • 808 Answers
Its looking the registry error in ur system so do a registry repair scan with Intel software partner Reg In Out registry cleaner
Posted on Sep 08, 2010
  • 621 Answers
You could try doing all the updates to Service pack 2 but i would seriously consider buying an upgrade pack to Windows 7 you'll it compared to vista. Please vote...cheers from Scott
Posted on Jul 05, 2010
I open my new laptop (Toshiba) when i try to boot the system and instal windows XP this message was appear: A problem has been detected and windows has been shut down to prevent damage to your...
Hi. You need to try install other higher windows version like windows vista or windows 7.i already encounter that problem i fix it using windows 7 installation.try it's work.
Jun 03, 2011 | Computers & Internet
I cannnot get my dell optiplex 360 to have sound. It had sound before and now it doesn't. I download the drivers on dell website and it still is not installing correctly or something.
Hardware Troubleshooter If a device is either not detected during the operating the system setup program, or is detected but incorrectly configured, you can use the Hardware Troubleshooter to resolve the incompatibility. For more information on using the system setup program, see the Dell Technology Guide on your computer or at support.dell.com.
Windows® XP:
  1. Click Start® Help and Support.
  2. Type hardware troubleshooter in the search field and press <Enter> to start the search.
  3. In the Fix a Problem section, click Hardware Troubleshooter.
  4. In the Hardware Troubleshooter list, select the option that best describes the problem and click Next to follow the remaining troubleshooting steps.
Windows Vista®:
  1. Click the Windows Vista Start button troubl69.jpg , and click Help and Support.
  3. In the search results, select the option that best describes the problem and follow the remaining troubleshooting steps.
Oct 26, 2010 | Dell OptiPlex 360 Desktop Computer
Error in scanner. Turn off scanner and follow instructions in manual.Scanner driver will be closed. (code:201) Unable to open TWATN source Please check connection Then re-start Toolbox.
This error can be caused by many different issues. Try the following resolutions in order until your issue is fixed-
1. You should disconnect and reconnect the USB cable at both ends to ensure there is a secure connection on the device side as well as the computer side. It may also be necessary to try a different USB port on the computer. Additionally, you may need to disconnect other USB devices, temporarily, in order to determine if a conflict exists.
2. unistall and re-install drivers-
1. Place the CanoScan Setup CD-ROM into the CD-ROM drive.
2. When the CanoScan Setup Utility menu appears, click the option to 'Uninstall the Software' and then follow the prompts.
3. Disable Third-party Software
Software applications that are active during installation can cause errors, installation difficulties and even abort the installation.*1 Close all running applications, including anti-virus programs, before installing Canon Software. You can also prevent these applications from starting through 'System Configuration Utility' (also referred to as 'msconfig') in Windows 98/Me, Windows XP and Windows Vista.
If your computer is part of an office network: Network permissions, security software, etc. may be interfering with proper communication. Please contact your System or Network Administrator before attempting to disable software on your system.
a. See your applications' documentation for instructions on how to close it.
b. If you are unable to locate the documentation or the application appears to be running after it is closed, disable the startup items in the Windows 'System Configuration Utility'.
c. If disabling startup items in 'msconfig' does not correct the issue, disable non-Microsoft related services in 'Services' tab of 'System Configuration Utility' window.
d. Attempt to install the Canon software (drivers). If the drivers were already installed, uninstall them (keep the third-party software disabled) and then reinstall the drivers.
e. After installation is complete, set 'msconfig' back to 'Normal Startup'.
//javaftper
Jul 31, 2010 | Canon CanoScan 3000ex Flatbed Scanner
Error loading C:program~1Mywebs~1ar.binm3plugin.dll how to fix this?
Please click on Start, Click on Run and type the following in the open box and click OK
msconfig
Vista: In the Start Search field, type msconfig , and press Enter . The System Configuration window opens.
Or
Press and hold Windows logo key on keyboard and press R. It will open Run Window. Type the following in the open box and click OK
MSconfig
Please click on Startup tab
Remove the check mark from entries related to Mywebsearch OR M3PLUGIN.DLL
Then click on Apply, Close and Please click on Exit without restart.
When the system restarts, you will see a message about System Configuration Utility. Click in the box for "Do not Show this message" and then click on OK.
Courtesy en.kioskea.net
Nov 14, 2009 | Intel Motherboard
Error Code 1068 in Windows Vista 64
1. Click Start, and then click Help and Support. 2. Under Pick a Task, click Use Tools to view your computer information and diagnose problems. 3. In the Tools area, click System Configuration Utility. 4. In the right pane, click Open System Configuration Utility. This opens the System Configuration Utility. 5. Click the Services tab. 6. Make sure all the following services are turned on. To turn on a service, click to select the check box.
� Application Layer Gateway Service
� Network Connections
� Network Location Awareness (NLA)
� Plug and Play
� Remote Access Auto Connection Manager
� Remote Access Connection Manager
� Remote Procedure Call (RPC)
� Telephony
� LexBce Server (if you have it) 7. Click OK, and then click Restart.
If this doesnt work please reinstall the os or do a sfc/scannow it will check all system file.and will ask for the XP cd.
May 12, 2009 | Microsoft Windows Vista Home Premium...
WHEN I TURN MY COMPUTER ON I GET AN ERROR MESSAGE - HOW CAN I STO
msconfig
Or
MSconfig
When the system restarts, you will see a message about System Configuration Utility. Click in the box for “Do not Show this message” and then click on OK.
It may work!
REGARDS
RAHUL
Feb 22, 2009 | Microsoft Windows Vista Ultimate Edition
Error Code
Accidentally ended the session ?
Here's what you need to do - INSIST for assistance with the tech from tiscali with the windows mail client for configuration.
Don't mention the error code to them cause they don't do research.
15mins tops to do it.
As I said, there are some email server configuration that are off-limits to non-tiscali techs & non-subscribers.
Aug 25, 2008 | Computers & Internet
Error 5 error LU1812 live update error 18 Have downloaded new version of norton 360 on sony va10 computer with windows vista and each time I try to update it does not complete because of these errors. ...
Download and run the LiveUpdate fix tool from Symantec HERE
After you run the fix tool, open Norton 360, click on the "Scans" link at the top of the window, choose "Comprehensive Scan" and then click the "Go" button This will take some time, but will thoroughly inspect your computer for infections
To address your other question regarding the LiveUpdate settings, you can change the configuration to use an HTTP proxy. To do so, please follow these steps.
1. Open the "Symantec LiveUpdate" Control Panel.
2. In the LiveUpdate Configuration window, click on the "HTTP" tab.
3. Click on the radio button that says "I want to customize my HTTP settings for LiveUpdate." Enter the information for your HTTP Proxy server, click the "Apply" button, and then click the "OK" button.
Please let me know if this process resolves the issue you are having with LiveUpdate. Also, if the scan finds any infections, please let me know what is found.
May 04, 2008 | Computers & Internet
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
46 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
