Question about Lexmark X5150 All-In-One InkJet Printer
My Lexmark 5150 is saying that I have a Cartridge error 50c and to see the owners manual which I have lost
SOURCE: cartridge error 50c
I removed the color cartridge and left the black one. it worked.
(I have Lexmark X6100 Series)
Posted on Jan 14, 2008
Ajkill
  • 2035 Answers
SOURCE: my Lexmark is X6100 Series - Cartridge Error 50C consult user guide
Cartridge Error 50C
Your print cartridge has shorted.
1. Power off your All-in-One and unplug it.
2. Plug in your All-in-One again and turn it on.
3. Uninstall and then reinstall your cartridges.
4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
1. Power off your All-in-One.
2. Use both hands to lift up the scanner unit until the scanner support holds it open.
3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
4. Remove the color print cartridge.
5. Lower the scanner unit until it is completely closed.
6. If the error message reappears, replace the black print cartridge with a new print cartridge.
If it does not repeat steps 1-3 and then go to step 7.
7. Reinstall the color cartridge and remove the black print cartridge.
8. Lower the scanner unit until it is completely closed.
9. If the error message occurs again, replace the color cartridge.
10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
11. Lower the scanner unit until it is completely closed.
12. If you receive the error message again, replace both cartridges.
Posted on Mar 15, 2008
SOURCE: Lexmark 5150
I went to the Lexmark site and downloaded the manual. Looked for my problem 'Cartridge Error 50c' and found that my color ink was empty. It took some playing around, but that was it.
Posted on Aug 12, 2008
bschilz
  • 2049 Answers
SOURCE: my printer is lexmark 5150 and when i try to print
Your printer cartridge has shorted. Follow this link to read what you can do to fix it...
http://support.lexmark.com/perl/support/support.cgi
Posted on Aug 13, 2009
pineworks
  • 4041 Answers
SOURCE: cartridge error 50C
Resetting purge counter:
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Posted on Jan 30, 2010
Says erorr 50c on my lexmark x5150
The 50c error indicates a problem with your cartridge. This article will help you determine and resolve the issue: Cartridge Error 50C and Other Errors on the Lexmark X5100/X6100 Series LCD Screen.
Apr 20, 2011 | Lexmark X5150 All-In-One InkJet Printer
Cartridge error 50c
The Cartridge error 50c indicates that the printhead(s)/cartridge(s) has shorted. Follow troubleshooting steps available at http://bit.ly/8Zf7ef. If error continues even with brand new genuine Lexmark cartridges, contact Lexmark technical support for assistance. Thank you for choosing Lexmark.
Sep 20, 2010 | Lexmark X6170 All-In-One InkJet Printer
Cartridge error 50c
Here's an article in the Lexmark website on "Cartridge Error 50C" and Other Errors on the Lexmark X5100/X6100 Series LCD Screen. Just click on this link: http://bit.ly/cBu4mW. Follow the instructions carefully. Hope this helps.
Jul 05, 2010 | Lexmark X6150 All-In-One InkJet Printer
50c error lexmark 5150
Hello !
Just turn off your printer.
Unplug the power cable.
Remove both cartridges
Put a baby wipe under the cartridges for about 10 seconds.
Wipe the front piece
Dab the heads in the printer
Let dry for about 10 seconds
Move your cartridge tray and put cartridges back in
Run a cleaning test
Run an align test
Print a test page
Hope this helps.
Sep 01, 2009 | Lexmark X5150 All-In-One InkJet Printer
Lexmark 6100 cartridge error 50c
Are you using a factory "New" Lexmark cartridge?
Lexmark does not support the use of refilled cartridges or third party cartridges in their products.
Lexmark considers this to be Product Tampering and will void the printer' warranty.
Don
May 11, 2009 | Lexmark X6100 Flatbed Scanner
Error 50
Is that an error code "Cartridge Error 50C" ? If so, see below....
Cartridge Error 50C: Your print cartridge has shorted.
Error: Black Cartridge Missing - The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing - The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error: Complete the following instructions:
Nov 22, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark 5150
Aug 11, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X5150 All-In-One InkJet Printer Logo
87 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
