Question about Maytag Neptune MDE5500AY Electric Dryer
I have a Neptune MDE5500ayw dryer. After some time the black wire burns out and disconnects or burns in two. I have it lifted off the ground because I thought moisture was causing the problem but it happened again. What part can I but to fix this problem.
  • Maytag Master
  • 3,053 Answers
Hello, I was trying to help you out here. I wasgoing back to some customers that asked questions in the past and it appearedthat no one answered them, so I thought I would take some of my personal timeto see if I can help. Here is a link to about everything you want to know aboutyour dryer, from repair to trouble shooting it. If you go to this link andclick around, I am sure you will find out so much about your dryer, you willknow more that the company that made it. Here Is the link for you to click onhttp://home.howstuffworks.com/how-to-repair-a-dryer.htmPlease if this helped you at all, if youcan find the time to rate my help and some kind words written would beappreciated for my free help , I would appreciate it. Here is also my direct link to my own pagesof other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike http://beta.fixya.com/users/mc1bean
Posted on Oct 26, 2011
WHY DOES MY NEPTUNE MATAG DRYER MDE5500AYW NOT HEAT ...AND WHERE ARE THE THERMAL SWITCH, HI LIMIT THERMOSTAT, AND HEATING ELEMENT?
All those parts are in the bottom front. TURN off the power! then open the front door and remove the 4 screw's, 2 on the hindges and 2 on the other side. Then you can close the door, and pull from the top edges of the front panel(sometimes you need a thin screw driver to free the front) the front panel will tilt forward and then you can lift it off. You will need a Ohm meter to check those parts for continuity. Make sure you remove the wires from the part you are testing.
Sep 30, 2014 | Maytag Neptune MDE5500AY Electric Dryer
We have a Maytag Neptune mde5500ayw electric dryer, with a three prong cord. Our new house has a four pronged outlet. I purchased the correct 4-prong cord, but need to know the proper way to wire it into...
It seems to get confusing where the wires go in the back where the cord connects to on your brand new,or previously dryer that you have brought to a home thats new to you
4 wires goes as such with oldtech2332.jpgthe red wire going on the right side,the black wire going on the left,the white wire goes on the center terminal. Now what exactly do you do with the green wires is what your asking yourself. It goes onto the cabinet after removing that little link that went from the center terminal that was beweeen the cabinet and and the white wire terminal.Yes remove that link and install the green wire where that link was just attached to a minute ago.
GENE
Oct 12, 2011 | Maytag MDE5500AYW Electric Dryer
I have a maytag neptune dryer #MDE5500AYW and I am trying to convert from a three prong to a four prong connection. the four prong has a red, white, black and green connection. the old three prong, had a...
yes,hook up the black with the black the white with the white and the red where the blue was,now the green is just a ground wire,all you have to do is connect it anywhere to the metal frame of the machine just to ground it,look around there should be a screw somewhere near the other wire connections if not remove any screw and connect it and it will be fine.
Sep 04, 2011 | Dryers
I have a Maytag Electric Dryer model #MDE5500AYW that will not heat up. When I opened the front and looked at the heating element, I noticed that the wire attached to the heating element (a black wire)...
Okay have you replaced the wire with with the correct one? If the wire gauge is wrong it will do every time next you need a volt meter with a buzzer sound maker on it test your thermostat and hi limit thermostat if it makes a noise when testing its working. Only thing that would cause that wire to keep burning are those options and if all checks out okay then its faulty wiring which is grounding out somewhere which is a pain to trace and if you might not find the bad wire had a few of these with these problems and I ended up junking them big fire hazard sorry for the problem.
Jan 06, 2011 | Maytag MDE5500AYW Electric Dryer
We have a dryer model mde5500ayw with 3 wire cord the question is if this dryer can work on 120 V.
there should be a sticker right on the back that provides that information but generally dryers only run on 220 v
Nov 03, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How to remove the front panel of a maytag neptune gas dryer
Removal of the front panel requires the removal of the top cover and the console. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the 2 screws attaching the top cover to the rear of the dryer then slide it rearward to clear the screw head from the top cover flange and lift the cover off the dryer cabinet.
Remove the screws securing the heater PCB board and disconnect the black and white wiring harness connectors from the board.
Remove the four screws attaching the console to the washer cabinet and rotate the console down to remove it from the dryer.
Remove the four screws attaching the top of the front panel to the cabinet and the two screws at the bottom of the door opening.
Pull the front panel forward and disconnect the interior light wiring harness then lift the front panel off the tabs across the bottom and move it away from the dryer.
Reinstall the front panel, the console, and the top cover in reverse of the removal steps.
Apr 21, 2010 | Maytag Neptune MDG5500AW Gas Dryer
How do you open the top of a Maytag Neptune dryer model #MDE5500AYW
unplug the dryer,open the door and you'll see 4 screws,2 holding the door on and 2 opposite them,remove them and the door,now pull the front off you'll see a clip that looks like an L with a screw through it on each side,take the screws out and lift the top up
Feb 10, 2010 | Maytag MDE5500AYW Electric Dryer
My neptune dryer has an interior 'fin' that is loose (mde5500ayw)
There are screws holding the fins on the outside of the drum. To get to them:
  • remove door
  • remove screws on the opposite side of the door screws (which would hold the door if it would open to the opposite side)
  • pull the top of the front panel, which was held by those screws outwards
  • remove the front panel. You'll see brackets holding the top of the dryer in place. Remove screws holding those brackets.
  • lift the top.
Good luck
Oct 20, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My maytag will not run
My neptune dryer electric mde5500ayw will not start the button seemed too be struck, and how can i take the side panel off to check the fuses inside
Nov 20, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Wiring a 3 prong neptune to a 4 prong new outlet
red and black wires go to outside screws ..white goes to middle screw..lift green ground wire from screw in cabinet back and either tape off or connect to middle screw on connector ..green wire on cord goes in it's place
Jul 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
41 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
