Question about Samsung 57" Tft-LCD Monitor TV
Ihavea 40"Samsung ldc Model # LN840510 It will
Ihavea 40"Samsung ldc Model # LN840510 It will not turn on. The right light flashes with clicking sounds but does not power up. I heard that was a common problem with the capicitors. Can you help. Will samsung give me the parts? linda
SOURCE: Samsung LE40R73BD Will not switch on
I found a fix for this problem on another forum, It's caused by some blown capacitors on the main power board. I have a link to the original post, with step by step pictures for replacing the blown capacitors but don't know if it's ok to post it here. The repair cost me £7.49 for 5 capacitors RS part number 526-1109 and about £4.50 of that was for next day postage. I did the job myself in about 15 minutes and I have no experience with a soldering iron (i even had to borrow one). I replaced 3 capacitors, 2 of which looked blown and one which just looked swollen.
Remove the back off your tv, and just take a look at the small array of capacitors near the top right corner of the centrally situated power board. there are 4 identical capacitors rated at 1000uf 10v 105 degrees C. I think the silver capacitor lids should be flat or even slightly concave. The ones I replaced were all slightly convex and 2 of them had a tiny amount of what looked like brown corrosion right in the centre of the caps.
For a few quid I'm sure you could get someone else to do the soldering if you lack confidence.
The original post also linked to a supplier of the main power board for £130. I didn't mind having a go myself because I figured if I fouled up I could always just buy the board.
Posted on Apr 15, 2009
SOURCE: Samsung LN-T4032H
This is the capicator $1.50. You have to take off the back, sauter off the capicator (you'll see it because it is poking out) and sauter on the new one. I found the fix on this web-site.
Posted on Oct 04, 2009
petraman7
  • 1175 Answers
HI...
Do you have an extended warranty?
It will need service.
Do a web search around your area for service people
Posted on Mar 24, 2009
lightnbaby
  • 36 Answers
SOURCE: hi my samsung lcd tv model le40s8, it won't switch on
if you can do soldering work, replace two 1000uF10v bulging capacitor with 1000uF 16v or 25v in powersupply board. you will save $200.
Posted on Nov 12, 2009
budmrtn
  • 11361 Answers
SOURCE: samsung 40" tv not coming on
I would check out the power supply module for bad caps with bulging tops. Check DC voltages at the output connectors, you should have 5, 12, 24V.
Posted on Jan 08, 2010
Testimonial: "This seems to be a common fault on these tv's. I probably wont attempt to fix myself even though the warranty has ran out. Thanx "
Won't turn. on red standby light changes to on but then goes right back red
TV won't turn on - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have the Samsung FP-T5084 50" Plasma tv. I went to turn it on the other day, and it wouldn't turn on. No clicking. No red power indicator light. Nothing. Samsung TV LN52A650A1FXZA won't turn on, keeps clicking
Jun 11, 2015
Samsung TV won't turn on
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
More results from www.cnet.com
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old. ... I have an old type sony tv with the big back and the red power light keeps flashing and ...
How do you fix a television that won't turn on? - Ask.com
www.ask.com > Technology > Television & Video
Jan 03, 2016 | Televison & Video
Would my 1 and a half year old samsung 40" smart tv model (# UN40D6000SF ) be covered under the class action lawsuit ? and where can i get a manual for this set ? thanks
you can open the back cover of the tv using with a phillip screw driver. to check weather their are bulging electrolytic capacitors at the power supply board.
Jan 03, 2013 | Samsung LN40B530 40 in. LCD HDTV
Model code HLR4667WX/XAA won't turn on just clicks
Sounds like you have defective capacitors in the power supply board, cheap and easy fix for those with electronics repair skills
Jul 23, 2012 | Samsung LN-S4041D 40 in. LCD HDTV
Samsung LN-S4051D 40 in. LCD Television will not turn on
Are the red lights still flashing after replacing the caps? Bulging caps usually means the caps are at the end of their life span, but shorted caps may look just fine. Check any caps that you did not replace to see if they are shorted. I bet you still have a bad cap somewhere on the power supply that is shorted.
Mar 05, 2010 | Televison & Video
Televison wont turn on but red light flashing and
You can't fix it yourself, it needs professional.
Jan 14, 2010 | Televison & Video
Samsung 57" Tft-LCD Monitor TV Logo
255 people viewed this question
Jerry Greenberg
Jerry Greenberg
