Question about Zanussi TLE1116W Top Load Washer
The machine is failing to drain and therefore not completing the cycle. I've cleaned the waste water pipe and tried again, but no joy. I think that it may be the waste water pump? many thanks, Luke local.roots@hotmail.com
    President:
  • 2,468 Answers
Remove the pump and take off the hoses and make certain all are clear of debris,as any obstruction will make the motor stop to save all components
Posted on Jul 04, 2010
I have a whirlpool duet front load washer. the spin cycle did not complete and their's water still left inside. i've tried to shut off the washer and restart it, it will spin once and then stop...
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
Aug 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F-05 displaying on ultima wt960 what can i do to solve this
I have had this problem before and called out an engineer. It happened again today and luckily I remembered what he did.
Have a bucket handy.
Switch machine off at mains, disconnect washing machine waste pipe, put a cloth/rag in the end of it to stop water leaking out, and bring it down to as low to the floor as you can.
Jiggle it a bit (to make the pipe bend and flex as much as you can).
Put hose in the end of the bucket, take out the rag, start a cycle (to allow water in) and press cancel to stop the cycle, it should now start to drain, but with lots of muck in it.
Once it drains, put the rag back in the waste pipe and empty the bucket.
Now really jiggle and flex the pipe as much as you can..without causing damage..I really shook it about..a bit like when you were younger and made a rope look like a snake!
Tag the rag out and place end of waste pipe back in the bucket.
Complete the process above again by starting a cycle to let some water in - for about 30 seconds - then cancel and allowing to drain..should see a lot more gunk.
If this hasn't worked you may need an engineer.
You can repeat process if you like. Although I stopped here.
Remember to reconnect and tighten your waste pipe.
Oct 21, 2010 | Washing Machines
Hi, I have a 10yr old Neff s5543 built-in dishwasher, it is has been working fine but recently has stopped fully draining. I have removed it from the housing and checked all pipe work is unblocked and...
Hello there and thank you for choosing fixya
Ok there are acouple of things that can be checked on this along with what you have already checked
Drain solenoid Beneath some dishwashers, there's a timer-activated drain solenoid (an electro-magnetic coil) that opens a drain valve, to drain the wash water through a hose and out to the house's plumbing waste system. If this is failing it will not allow the water to drain from the machine fully
Timer Dishwashers have a timer behind the main control panel at the front top of the dishwasher, or behind the lower access panel. It is either a mechanical device like a simple clock, or it's completely electronic with just a digital readout. The timer runs the dishwasher in a pre-determined pattern. It provides the electricity to all of the dishwasher components at the correct time, for the correct length of time.
Oct 16, 2010 | Neff 24 in. S5543X2 Built-in Dishwasher
Standing water in the washer hours after wash cycle completes
YES..I think drain hose @ sink too low Waste water from sink entering machine...Raise pipe....tie up ....
Apr 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Spinner drier slow and does not drains water
sounds like the water is not leaving the machine quick enough therefore it wont go into a full spin, check outlethose, and waste pipe, failing that check pump
Mar 31, 2010 | LG WFT1071TP Top Load Washer
Hi, good evening. I have a zanussi iz12 washing machine that stops during rinse node and gives e20 fault (wont drain). I checked the pump - working fine. I've found that if i blow into the waste pipe the...
Hi there
I have an IZ12 jetsystem which sometimes works and other times it starts and then clicks and stops just before the water starts to run in. I usually turn it off and try it again a few hours later and then it starts to work again. Sometimes it is the next day before it will work again. Would anyone know the problem?
Jan 11, 2010 | Zanussi IZ12 Front Load Washer
Washing machine will not drain
TAKE THE HOSE OFF ON THE BACK {DISCHARGE HOSE} IF THE WATER FLOWS OUT IT IS THE PUMP MOTOR IF IT DOESN'T THERE IS SOMETHING BLOCKING THE OUTLET, SMALL CLOTHING ITEM
May 29, 2009 | Indesit W 123 Front Load Washer
Pump constantly emptying
make sure that the drain line is higher than the water level in the tub. If it isn't the water will just drain
Mar 30, 2009 | Washing Machines
Indesit IDL 50 Dishwasher
Had a similar problem (flashing lights 1 and 2). Drained the machine by diconnecting the outlet hose and using a shallow bowl on the floor. Removed and cleaned filters. Forced clean water through by using a garden hose pipe(you can only do this one way, you cannot force water down the outlet pipe). Removed and cleaned the pump (you have to do this from under the machine but easy enough). Finally ensuring the waste trap under the sink was clear. Bingo!! No parts, no expensive engineer.
Jun 04, 2008 | Indesit 24 in. DE73 Evolution...
Zanussi TLE1116W Top Load Washer Logo
85 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
