Question about GE WBSR3140DW Top Load Washer
During initial fill process the water does not turn off causing overflow
  • 166 Answers
1. If the only way to shut the water off is to turn the water off at the faucet, then you have a bad water valve. replace it.
2. If you can shut the water off by turning off the machine or unplugging it, then your water level pressure switch is not working properly. . You can take the backspash loose and you will see the pressure switch with a rubber hose attached to it. Remove the hose from the switch and blow down through it. Then remove the front panel of the machine. To do this use a flat blade putty knife to depress a spring clip on each side of the front panel between the top and the front.
You will see the rubber hose connected to a connection on the side of the outer tub. Sometimes this connection and or the end of the hose can become stopped up with crud. you can take a small wire or other such object and clean out the connector and the hose. If cleaning the hose doesn't work then you have a bad pressure switch.
Posted on Jul 04, 2010
    President:
  • 1,430 Answers
The problem is the pressure switch has failed or the hose is plugged up, has a hole in it. These are usually inexpensive and are very easy to replace. There is a video at http://appliancehelponline.com/toppressureswitchvideo.html this will walk you thru the inspection and replacement of this part. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
How to fix lower freezer, the water dispenses too much into ice cube tray so it overflows into ice bin...
There is an adjustment on your icemaker that controls the amount of water that enters the tray during the fill cycle. Find it and turn it counterclockwise to lessen the water in tray so it does not overflow.
Or, check to make sure that the fill solenoid is shutting down properly (could be sticking)- if not excessive water will enter the tray with same result.
Mar 03, 2017 | Refrigerators
Keep the pot from filling too full
even the unit is off does the water still coming in causing overflow ?the causes are the ff :
1.the by quicksharer" in_rurl="http://i.display-trk.com/click?v=U0c6NjU1NjI6MTMwNDpzb2xlbm9pZCB2YWx2ZXM6MTdkOTI0ODBiZDUyZmJkYjA1MzBhMjdiMmNjZWYzNzM6ei0yMTQyLTc4NDM0NDp3d3cuZml4eWEuY29tOjE5ODI0NzpkZmVlMzU5N2UyMDM5ZWMyYjc0MWIzYzExZmVlODQ5NjpmMjEwYjFiMTFjZmU0YmFiOWE2Y2M1MmVmMGU0MWEzMDow&subid=g-784344-e42ee195296e4be18017130db046325f-&data_tagname=DIV" id="_GPLITA_6" href="#">solenoid valve'sarrow-10x10.png plunger maybe stuck in open position
if during the filling of the tank mode water overflows the ff is the problem :
2. ur water level sensor defective or the its surface coated w/scales
3. control board faulty
all of this must call 4 serivce
Sep 28, 2014 | Bunn VPR Coffee Maker
Waterboss 93000 water softener
It most likely is due to a plugged eductor/injector assembly which pulls the salt brine out of the tank to regenerate softener. If it is plugged no brine will be pulled from salt tank during regen but it will keep filling the salt tank and eventually overflow with each cycle. Or there could be a leak in the valve causing the tank to overflow.
Here is the owners manual for your model.
http://www.waterboss.com/media/WB_Softener_V1_Manual.pdf
See page 23
RJ
May 05, 2014 | Water Dispensing & Filtration
Kenmore Washer only leaking from one area
Ive never worked on a Kenmore but it may just be the overflow outlet. All washing machines have an overflow which will dump water out from the top of the tub if it overfills but sometimes on high fill water level, clothes can splash around and cause a "wave" of water to splash out over the overflow outlet. Check to see if the leak only occurs when you have selected high level fill.
Nov 23, 2017 | Kenmore Energy Star 44092 Front Load...
I have a Kenmore 90 series washer that overflows. What is happening is that during the initial fill, it shuts off. However, part way through the agitation cycle, it adds more water and would overflow...
In the old days before electronics took over a small bore tube connected the washtub to a pressure switch. As the water level rose a pressure would be created in the washtub and at a predetermined level the pressure switch would cut off the water supply. A blocked tube or a broken pressure switch (or a leaky washtub) would cause flooding. A leaky washtub would prevent the required pressure build up.
I haven't been inside a modern machine so I don't know the arrangement but I expect it is similar - apart from the switching, which will be performed by the computer, digitally of course...
Oct 23, 2017 | Washing Machines
GE gtwn5050mows water spitting while filling
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Check for tips on the link below to identify parts and removal:
http://www.espares.co.uk/advice/washing-machines/a/7
May 17, 2012 | GE Washing Machines
The water softner is now filling up with water also the is water in the the overflow its sits in
The softener is not drawing brine during the regeneration cycle. The eductor assembly may be plugged or you may have a bad seal internally. It will keep filling the salt tank if the float assembly is not working properly also causing the salt tank to overflow.
RJ
Dec 28, 2010 | Culligan Under Sink Water Filter
Why do the stackable washers always overflow with water. Is it a sensor problem or what?
Overflowing can be caused by a faulty pressure switch or tube from switch to the tub. It is operated by air pressure from water filling in the tub. If this does not activate then the inlet valve will continue to allow water to enter the machine. If it is overflowing during spin only it is most likely something obstructing the pump. If it is filling the tub even when the machine is off the problem is the inlet valve.
Jun 28, 2010 | Maytag LSE7806A Top Load Stacked...
Will not hold water during initial cycle
The drain hose needs to be lifted above the high fill level in washer.The easiest way to fix this is take the drain hose (if your drain hose starts from the bottom of machine and goes up)tie or strap it to the back of the washer so it cant sag or drop down and start syphoning the water.Remember the washer will drain out the water if the drain hose is lower than the amount of water in the tub.Thats why your making sure by tieing the drain hose to the highest point before it makes it way to the drain .
May 21, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
GE WBSR3140DW Top Load Washer Logo
157 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
