Question about Eljer Toilet Onepiece Canterbury 081162047
Tank is not filling to water line
Eljer Windsor one piece. Flush is weak. Water is not filling up to water line. Do I adjust the weights, or turn the adjustment screw ? Which direction do I turn, clockwise or counterclockwise ?
  • 3,600 Answers
Turn clcokwise to rasie water level, don't mess with the weights unless adjusting the screw to get water to proper height does not do the trick.
Posted on Jul 04, 2010
Testimonial: "I think I figured it out before this response. I did the same thing by logic, dumb luck"
  • Bruce Hathcock Jul 14, 2010
    Not dumb luck your smater than you give yourself credit for thaats all.
Eljer Windsor One Piece Toilet help - leaks water into bowl
I would go back with the ballcock kind. However, the flapper will need to be replaced. It is not seating properly. The fluid master is a revised version and a bit more efficient. It should work well also. They both work off buoyancy and shuts off water the same way.
Feb 18, 2013 | Home
Eljer toilet bolts rusted causing massive flooding
Turn off the water at the supply (under the toilet, usually).Flush the tank to remove all water from the tank.Disconnect the supply from the tank.Remove bolt caps or bolt covers from where the toilet bolts to the bathroom floor.Remove bolts from the floor flange. When you lift the toilet up, you'll see a metal or plastic flange. If the toilet has been there for a long time the bolts may not pull out of the flange easily. In this case you may have to use a small hacksaw to cut the bolt below the nut.Put newspaper or an old towel on the floor so you can place the old toilet on it. Lift the toilet off the flange.Take the new bowl (assuming this is a two-piece toilet) and turn it upside down. Position the wax ring on the horn of the outlet. Install new solid brass flange bolts, mount them and position them on the centerline on either side of the outlet.Push the bowl down over the bolts and seal the outlet. The wax will squeeze down and seal.Put the new bolts, washers and bolt caps on. You may have to trim the bolt with a hacksaw.Once the bolts are secure, mount the tank.Make sure the gasket between the tank and toilet is in place. Then position the tank on the bowl. Run bolts through the tank and secure. Don't over tighten (the tank can crack).Hook up the water supply line.Connect the supply to the line on the bottom of the tank.Turn on the water.Let the tank fill.Flush once or twice to make sure the water control is properly adjusted.Put the tank lid on.Enjoy.
ford performance chip.
May 25, 2012 | Eljer Home
This summer I purchased a eljer toilet. it listed as a 10 flush which is the best I guess. now it is continually turning on to level out the tank. is this normal for eljer toilets? and if not what has to...
ok, this sounds like a float or valve issue, should be an easy fix. you can adjust the float or just replace it with the one piece type. you may not be able to adjust it and get it to work, so I think the best thing to do is just replace the whole float assembly. About ten dollars or so at home depot or someplace like that. Turn off the supply valve, flush the toilet,and drain the tank by removing the plastic nut underneath on the left side. Drain the remaining water into a bowl. There is also a nut on the supply line that will need to be removed first. When you remove the nut that is flush with the bottom of the tank that also holds the valve in place inside. Take off the rubber hose inside the tank and remove the entire float and valve. The new one piece will have a adjustment for the tank level by just turning the entire unit. Make sure you put the rubber washer that is supplied with it on the bottom and put it back into the tank and tighten from the bottom with the new plastic nut. Make sure the valve inside is pointed at the plastic tube and re-attach the rubber hose. Then attach the supply line, tight, but not with a tool, just your hand. Turn on the supply valve, re-fill the tank, flush, and check for leaks. Remember, buy the one piece type, should be a gray valve with a black float built right on it. Good luck
Dec 01, 2010 | Eljer & Complete Toilet In A Box
I have to hold the lever of my Eljer one-piece toilet to flush it. How to adjust it?
lift off cover and shorten flapper to handle chain/rubber connection flapper not opening all the way
Apr 11, 2010 | Eljer Toilet Onepiece Canterbury ...
The water wont fill back up after you flush it
MAKE SURE THAT THE HANDLE OR CHAIN IS NOT GETTING HUNG UP ON SOMETHING INSIDE OF THE TANK,WATER WON'T FLOW UNLESS THE FLOAT DROPS DOWN
Apr 05, 2010 | Eljer Walford Two-Piece Pressure-Assist...
My Eljer toilet does not always flush completely. It is approximately 20 years old. I don't believe that it is a venting problem. I have dismounted, inspected and remounted the toilet and found nothing...
Not being a plumber by trade I don't want to bad mouth what your plumber had to say but there may be other things to consider.
If the toilet does not flush directly into the main drain there is the possibilty that the coupling between the main drain and the toilet drain is under-sized which could cause reduced water flow and your toilet not flushing completely.
Feb 26, 2010 | Eljer & Elongated Toilet Bowl
Slow water leak past flapper seal.
Replace flapper, it is worn out.Turn off water valve. Flush toilet, remove flapper. Then replace flapper, adjust chain to same size as old one, then turn water back on.
Aug 19, 2009 | Eljer Toilet Onepiece Canterbury ...
I havve two Eljer non-wateraver toilet (Patriot?)
I've never had a problem with Eljer toilets. Try adjusting the fill valve so that it allows more water to enter the tank (if you're over the flush valve, install a coupler made from PVC around the neck of the flush valve- inside diameter of the coupler needs to be the same as the outside diameter of the flush valve filler neck).
Jul 02, 2009 | Eljer Home
No water at flush
sound like the water shut-off needs to be replaced.
if you turn on/off the shut-off, the tank get enough water to flush, then you get less water every time you use the toilet. that is the shut-off valve problem.
you may able to to just change the rubber seal.
I have not found change the seal will last as long as a new valve. better off, just change one.
Feb 11, 2009 | Eljer Aqua-Saver 12" Two-Piece...
The water continue to run for a long time
You are probably going to have to replace the fill valve.
There is a chance that adjusting it may work, but it has most likely become worn and partially clogged with hard watrer deposits, dirt, etc.
This will cause it to fill slower, and cause the fill level valve to close slower resulting in higher water level. Eventually it would simply overflow the flush valve tube.
Try adjusting the fill level, but plan on the likelyhood of replacing the fill valve.
Jan 21, 2009 | Eljer Aqua-Saver 12" Two-Piece...
Eljer Toilet  Onepiece  Canterbury  081162047 Logo
458 people viewed this question
Top Eljer Home Experts
john h
Mike
Donni Steen
Are you an Eljer Home Expert? Answer questions, earn points and help others
