Hello my father in law gave us a Belkin F5D8230-4
Hello my father in law gave us a Belkin F5D8230-4 wireless router. My sony laptop pics up the signal just great but always says "no internet access" also the Easy Setup Wizard provided on the Belkin web site stops halfway through the setup is this a Windows 7 issue. Any answer would be very helpfull. my wifes laptop wont pick up the internet either or the PS3.
  • 3,600 Answers
You need to install the serial number in your computer off of the router, clcik on diagnose and when it comes up with enter pass phrase input your serial number ans you should be connected. Hope this helps and thanks for using fix-ya.
Posted on Jul 04, 2010
Sony e services VPCEB26FG model unable to connect wireless wifi to Belkin N+ router
If the Router is Secured (And it should be), You need the SSID. Usually a 26 alpha numeric password. Get a cable and run it from the pc to the router and go to 198.168.0.1 and connect to the router directly. Then sign in and tell the router to recognize the pc. disconnect and it should let you connect. Write down the SSID for future use.
Please realize I skipped the detaled steps and gave you the big view.
Good Luck.
Jul 29, 2011 | Sony VAIO Notebook
I have belkin connect n150 and i have two laptops my one laptop is connect to wireless but the one laptop cant access to wireless it says no wireless network were found in range..
If your message is like this " no wireless network found in range make sure wireless on the computer is On". All you need to do is look for the wireless switch usually located on the side or the back of your laptop. Sometimes its near the F keys or start button. You may check your laptop manual to see where to locate the wireless switch , or you can check the laptop manufacturers website usually they gave information on where to locate or enable the wireless feature of laptop.
KA
Mar 30, 2011 | Belkin Basic Wireless Router
Setup didn't work, "details" section on network
Win7 will connect without any problems, but win vista will not get connected to the network...
You can update the drivers for wireless adapter in vista laptop, it will get connected...
If it still not getting connected then change the security settings on your router to 64bit WEP... (Initially it will be in WPA)
disabled the WPS (wifi protected setup) in the router...
change the ssid in the router...
Now try to connect to the new wireless network...It will work perfectly....
click here to configure the wireless part of your belkin router...
Any issues call 18002235546 ( 24/7 )
Feb 06, 2011 | Belkin Play N600 Wireless Dual Band Router...
Just got a Sony BDP-S570. Have a wireless network with a Belkin N+ router (Windows Vista computer). When I use the Sony on the network for Netflix, or YouTube, radio, etc, I drop the wireless connection...
We have the exact same issue with the BDP-S570 and a Belkin N+ while having no issues with other wireless devices on the network. We have tried different encryption methods and the issues continue. I did read a person recommending that we reset the device to factory defaults after upgrading firmware. I just tried this and will see how long the Sony stays connected.
Jan 05, 2011 | Sony BDPS570 Bluray 3D Player
I have a Belkin G WIreless Router. We have a desktop and laptop and we have had not had any problems until my brother in law moved in and he went online with his compuer...now the desk top is fine and will...
Go to www.belkin.com/support download the latest firmware for your router model number
type 192.168.2.1 in the url box in your browser open the belkin router page
left down colum bottom under utilites you can find firmware upadate->browse and locate your downloaded file and upgrade
and under wireless->channel ssid->change channel to 11
Sep 05, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin 54 Wireless Internet Connection Problems
If wireless adapter on the laptop is fairly old, you may need to update the drivers for the wireless adapter. Some older wireless adapters are not capable of properly communicating with WPA devices. Typically a driver update of the laptop resolves the issue. If not, try another wifi adapter and verify it is not the OS or laptop itself.
Good Luck.
Jun 20, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
My belkon g plus rounter is not connecting to my new laptop dell but it is connecting to all the other laptops and pcs in the house and i asked my mates father and he said there was code does anyone know...
Code? Do you have any network security enabled? like WPA or WPE? If you do, you'll need a network key in order for you to connect, and you can find that by accesing the adminstrative console of your router, usually, at address http://192.169.2.1. and I am sure you meant 'Belkin' right?
Jun 20, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Unable to Access GT704WG Router with Laptop
normally there is a small hole for reset to factory default, just put a pin inside...
Other than that, u can also connect using network cable and access the router configuration, inside, u can edit the wireless security keys
Feb 27, 2009 | Actiontec (GT704WG) Router
Belkin g plus mimo router
the PS3 connects to router via a crossover cable yes?
you may need to manualy set the PS3 as a trusted acception in the routers security system, (using either its MAC address, or its set IP address if u manually gave the PS3 one)
Dec 06, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Secure my network
If you go to www.belkin.com/support then you can search for the manual.
Under "Product Support Browser" choose "Networking Products" --> "Routers" --> and your router type
On the right hand side under "documentation" click on "user manual-english"  Click on the pdf icon..
Sorry if I am writing each step which is too tedious.
This information is in the manual.
Go to 192.168.2.1 IP address.. If your brother has not changed the password then it will be blank.
Under Internet/WAN connection type you can create the password for the router.
You can also update the firmware for the router so that your router has the latest updated software that makes the router run.
Hope this helps.
Oct 23, 2007 | Belkin Wireless Pre-N (F5D8230-4) Router...
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
