Question about HP Pavilion dv2000t Notebook
My laptop hp windows vista startup takes too much time to boot up
    President:
  • 2,047 Answers
If your systems take too much time to booth up it is usually because the programs at startup are too much for the processor of the unit.
If you put on the unit try to check for the startup programs which come on with the unit and remove the ones which are irrelevant.
This should help ease up the system and increase boot speed.
Also to help improve the system performance try getting tune up utilities installed on your device.
Hope this is helpful
Posted on Jul 04, 2010
Automatic repair
hi Andrew.
"Upon the 'Preparing automatic repair' window, press-and-hold Power button 3 times to forcefully shut down the machine. The system will enter boot repair page after 2-3 times of reboot, choose Troubleshoot, then go on to Refresh PC or Reset PC."
Get Rid of Infinite Preparing Automatic Repair Loop - EaseUS
https://www.easeus.com/resource/fix-preparing-automatic-repair-loop.html
How do I bypass startup repair?Fix #1: Boot into Safe ModeInsert the disc and reboot the system.Press any key to boot from the DVD.Choose your keyboard layout.Click Repair your computer at the Install now screen.Click Troubleshoot.Click Advanced options.Click Startup Settings.Click Restart.More items...Startup Repair Infinite Loop: Fix for Windows Vista, 7, 8, 8.1https://neosmart.net/wiki/startup-repair-infinite-loop/Search for: How do I bypass startup repair?
How do I boot my laptop up in Safe Mode?Open Windows in safe mode using Command Prompt.Turn on your computer and repeatedly press the esc key until the Startup Menu opens.Begin a System Recovery by pressing F11. ...The Choose an option screen displays. ...Click Advanced options. ...Select Command Prompt to open the Command Prompt window.More items...HP PCs - Windows Safe Mode (Windows 10, 8) ' HP® Customer Supporthttps://support.hp.com/bg-en/document/c03439317Search for: How do I boot my laptop up in Safe Mode?
or go to this link if you need more help.
laptop preparing automatic repair Google Search
Nov 28, 2017 | Computers & Internet
MY MINI HP LAPTOP WILL NOT BOOT AND SAYS BOOTMGR COMPRESSED IS THERE SOMTHING I CAN DO IM IN IRAQ!
Yes,this is very common on vista.Using your Vista or a friends Vista DVD,boot from it,do a startup up windows vista repair. You up and going again.
Oct 12, 2009 | HP Mini 1000 Netbook
Hp Laptop Wont Boot
Hey dear,
Your operating system got crash. Use backup CD.
Turn on yr lappy. manually open the cd rom from right side of leptop. Put CD in. then wait for few seconds. u will see the screen then follow the instruction and re install the entire windows.
Sep 13, 2009 | HP Pavilion dv6000z Notebook
Boot mgr Is missing on a tobisha laptop
Method 1:
Use the following procedure to repair the file system on the hard drive:
  1. Turn off the computer and wait at least 5 seconds with the computer in a full off state.
  2. Turn on the computer and press the F8 key repeatedly as the computer starts. An "Advanced Boot Options" screen opens.
  3. Select Repair Your Computer and press Enter.
  4. Select a keyboard layout that matches your country/region and click Next.
  5. When the login prompt appears, select the user name with Administrator rights (not Administrator) from the User Name drop down. The user name with Admistrator rights is most likely the first user name that was entered during the initial computer setup.
  6. Type the logon password into the Password field and then click OK.
  7. A System Recovery Options window opens.
  8. Click Startup Repair.
A Startup Repair window opens and automatically scans for startup problems.
  1. Perform the actions suggested by Startup Repair: system restore, correct damaged or missing files, or other action.
  2. After Startup Repair has been used, try to open Windows.
    • If Windows Vista opens, you are done.
    • If Windows Vista does not open, perform the first portion of this section again to open the Startup Recovery Options window and continue.
  3. From the Starup Recovery Options window, click Command Prompt.
  1. Enter the following at the command prompt:
bootrec /fixboot
bootrec /fixmbr
  1. After the bootrec tool has been used, close all open Windows to restart the computer and open Windows.
    • If Windows Vista does not open, continue using these steps.
  2. Perform a full system recovery using recovery discs. For more information refer to the HP support document Performing an HP System Recovery in Windows Vista .
If the recovery cannot be completed from recovery discs, replace the hard drive.
Sep 13, 2009 | IBM ThinkPad T43 Notebook
HP DV4 displays only a blue screen running vista
Shutdown the computer,disconnect external peripherials.
Turn on the computer and hit F8 key as soon as you restart the computer
You will get the windows advance options menu.
Select the Safe mode option and hit enter.
If the computer boots in safe mode, do a system restore to previous date.
If computer restore then issue is resolved.
If still unable to boot in safe mode.
Ran a harddrive diagnostic.If harddrive test passes. If harddrive test fails replace harddrive.
Boot the system using the windows xp or vista operating system disk. Try to repair the OS then reboot the system and check.
If still unable to boot possible issue with corrupt operating system.
Reinstall Operating system. / Recover System . Good Luck.
Aug 27, 2009 | HP Pavilion dv4-1140go Laptop
Booting is delay so much time
Try the following steps:
1. Tap "F8" key while computer is starting
2. Select "Safe Mode" from the startup options menu.
3. If the computer boots in safe mode, restart the computer and check if the problem still exists
This could happen if the BIOS update has created some changes which are not compatible with Windows Vista. Try updating the BIOS again.
Mar 25, 2009 | Microsoft Windows Vista Home Premium with...
Can't 'Launch Startup Repair' when Vista boots on Evesham Laptop
when you restart try to press F11 while booting..check
Jan 05, 2009 | Computers & Internet
Boot Manager
You will want to do a Windows Recovery Environment Startup Repair, follow the instructions below to fix this issue:
To access the WinRE using the Vista install disk:
  1. Boot from the Vista install disk
  2. Choose your language settings and click "Next"
  3. On the bottom of the screen click the link "Repair Your Computer"
  4. Select the Vista installation to repair and click "Next" and it will launch WinRE
The following options are available in WinRE:
  • Startup Repair - It will repair the boot manager files and restore critical files required for booting Windows Vista.
    After attempting to repair the system it will display a Startup Repair diagnosis and repair log with the different Test Performed and the probably root cause.
Dec 16, 2008 | HP Pavilion dv9000z Notebook
HP Pavilion dv2000t Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
