Question about EdgeStar Portable Air Conditioner
I have a amana air conditioner Model # AP125D. The electronic key pad won't light . Air conditioner beeps when you plug it in but wont run. I think i need a new board for the touch pad cant find one
I have an Amana portable AC, Model # AP125D. When you turn it on, it trips the GFI. Can you help me. Thanks.
This indicates a problem of electrical leakage inside your AC and it should be inspected by an electrician for your safety GFIs trip due to an imbalance of current between the 'hot' and neutral lines which means that current in traveling from the 'hot' line through some path to the ground (safety pin on the plug). If you use any method to fool the GFI (there are some) you should anticipate having nasty shocks from any exposed metal on the AC; not good idea.
If a professional finds no fault, it is quite possible that the GFI itself is failing; I have replaced several which were tripping on insignificant events.
Jun 22, 2011 | Amana AP095R Portable Air Conditioner
Amana AP125D Air Conditioner I need parts for this. I need a hose that runs from the unit to the window and the plastic part to connect the hose to the unit. Where can I find these?
Actually, you can find a suitable, flexible type duct at any home center, in the diameter you need. In addition, they'll have the clamps you'll need and the plastic part. Take a piece of the old one with you (if you still have it) for comparison purposes. You may have to buy more than you need, but you'll always have a back up in the future.
Hope this helpd you. Please let me know. Thanks.
Jun 12, 2011 | Amana Portable Air Conditioner
I need to get an on-line manual/problem w/hoses thru window
www.managemylife.com/mmh/owner_manuals/17647/AMANA-Air-Conditioner-Room-(42)-L0523054
Jun 01, 2010 | Amana AP095R Portable Air Conditioner
Keeps filling with water and shutting off.
Air conditioners remove moisture from the air like a dehumidifier does. With portable units it is captured in a removable container and when full will turn the unit off so it won't overflow onto the floor. There should be option for a hose to attach to the bucket which could be run to a drain so you won't have to keep emptying the bucket. Just remember the a/c unit needs to be higher than the drain.
Aug 21, 2009 | Amana Portable Air Conditioner
I have an amana portable electronic air conditioner wont turn on
try draining the water. Mine did the same thing. Started right back up. There is alot of water be careful.
Jun 30, 2009 | Amana Portable Air Conditioner
EdgeStar  Portable Air Conditioner Logo
115 people viewed this question
Top EdgeStar Heating & Cooling Experts
Donni Steen
John Tripp
John Tripp
James Coghill
Are you an EdgeStar Heating and Cooling Expert? Answer questions, earn points and help others
