Question about Dahle 20090PSe Shredder
Hello I have broken the small gear of my 20090
Hello I have broken the small gear of my 20090 shredder serial no 20436 can you supply and advise me of costs
How can i get a nylon gear for my papershredder
will be difficult to get unless the manufacturer sells spares
the cost of the part (if available ) and labor chargers will exceed a replacement unit cost
Apr 22, 2016 | Shredder Office Equipment & Supplies
Fix paper shredder
The problem is usually shattered plastic gears inside if the motor works but the shredder blades don't. My shredder has two shredded cogs. Getting replacements is not easy. The companies that sell these types of cogs, don't want to sell singly. If they were 10 bucks each, it is cheaper than buying a new shredder. There are YouTube videos on how to repair them with metal strips or epoxy adhesive.
Fellowes is a good make, so contact them direct.
Authorized Service Dealers Fellowes
Feb 20, 2016 | Fellowes Office Equipment & Supplies
Before I recycle the metal from my DS-1 Fellowes shredder (small driven gear stripped) does anyone need any other parts? Two larger gears are good. Norm
I'm desperately looking for the small nylon gear (see attached photo) of the DS-1.
As I live in Brussels, Belgium I'm also curious to know where you have found the gear outside US and at which price.
Thanks,
Dirk.
before-recycle-metal-from-ds-1-fellowes#solution-section-ew2ec1vog3kw5zx5dcajxfma-4-3.jpg
Jan 27, 2015 | Fellowes Office Equipment & Supplies
Source for gear for fellowes 301101 DS-1 paper shredder
Replacement Parts - Paper Shredders Can I get my Fellowes paper shredder repaired or purchase parts for it?
The majority of Fellowes personal shredders (small shredders that can fit under a desk) are repairable and will have parts available. If you would like to check your model shredder to determine if parts are available, please click the "Ask a Question" tab above, and advise the model of shredder, the shredder's serial number and a description of the part needed. The serial number will be located on the bottom side of the shredder head below the bar code.
*** Please note: If your shredder is still within the warranty period, we ask that you do not open your shredder until speaking with a Fellowes Representative, as opening the unit may void your warranty.***
Fellowes office/commercial shredders (large shredders that cannot fit under a desk) are repairable and parts will most likely be available. Please do not try to repair the shredder yourself or you will void your warranty. Models included in the office shredder line are 125i Series, 225i series, 325i series, 380 series, 420 Series, and 480 series.
If you would prefer to have a local servicing dealer provide repair service to your office shredder, and would like to find a dealer in your area, please see the below link to search for a dealer by zip code.
http://www.fellowes.com/Fellowes/site/support/support_authorizeddealers.aspx
To order replacement parts, or if your model shredder is not listed, please click the "Ask a Question" tab above to ask us about your shredder. *** Please be sure to include your serial number from your shredder for the fastest service ***
Our office hours are 7:00 AM to 7:00 PM, Monday through Friday Central Standard time.
Jan 22, 2015 | Fellowes Office Equipment & Supplies
Spare parts for a fellows p45-c shredder
Can I get my Fellowes paper shredder repaired or purchase parts for it? The majority of Fellowes personal shredders (small shredders that can fit under a desk) are repairable and will have parts available. If you would like to check your model shredder to determine if parts are available, please click the "Ask a Question" tab above, and advise the model of shredder, the shredder's serial number and a description of the part needed. The serial number will be located on the bottom side of the shredder head below the bar code.
Go to
http://www.fixya.com/answer/answerpageslideview.aspx?ctg=176&fml=0&brd=mine&thid=24364827
and 'Ask a Question' give personal details, and that will give you details if spares are available
May 08, 2014 | Fellowes PS8C Shredder
The Fellowes P-4sc shredder is not shredding, its just making a granding sound but the blades are not moving
plastic gears are broken. don't think fellows make replacement parts for small personal shredders. get a new one. don't buy a Royal or Aurora brand, they are the worst.
Oct 30, 2009 | Office Equipment & Supplies
The shredder is making a thumping noise like something is out of whack. Tried lubricant and running back and forth. It still thumps.
Common problems.
Jammed paper.
When sherdding paper that has any type of adheasive or glue, such as junk mail advertisments, the glue gets stuck on the blades.
FIX:
1 - UNPLUG
2 - remove top cover
3 - using a small screwdriver or other pointed small object, carefully clean out
the blade paths of jammed paper. Typically there is a cylinder of blades on the underside that does the shredding.
4 - be careful not to damage or PRY the blades, just enough pressure to get the paper out.
5 - dont use oil or lubricants, they can GUM up the blades.
6 - assemble
Give it a try.
Oct 10, 2009 | Fellowes PS60C-2 Shredder
Broken Plastic Gear Wheels
Check out this website if you have an outdated machine without a parts program still in place it may come in handy.
http://www.rushgears.com
Feb 20, 2008 | Intimus 385 se Shredder
Mr.
I found a way to do a fix that should last for awhile. Put the large gear in a vise leaving room to partially knock the small broken gear through. I used a bolt the same size as the hole in the plastic, and tapped it in about 1/4 inch. This pushes some of the small gear through, exposing more of the usable part of it. I then cut (hacksawed) off about 3/8 inch of the broken part, put it back together and it works!..................Good luck, Sparky
Jan 07, 2008 | Office Equipment & Supplies
Altec Lansing In Motion Power Supply
Look on your power supply for the output voltage and amperage. It should say something like "Output: 9V DC 500mA". With this information you only need to get one with the same plug.
When you do please post the answer because I have the MLI699 speakers and don't know what power supply is needed.
Dec 15, 2007 | Audio Players & Recorders
Dahle 20090PSe Shredder Logo
Top Dahle Office Equipment & Supplies Experts
jhnolson
Dennis Key
Dennis Key
Are you a Dahle Office Equipment and Supply Expert? Answer questions, earn points and help others
