Question about Apex Digital GB55HD09W 55" Rear Projection Television
APEX DIGITAL GB55HD09W
The Television wouldn't power up. After reomoving the power supply board I noticed a large burnt hole behind it. I ordered and installed a new power supply board but still cannot power up the televison. Any help would be appreciated
  • valley girl Apr 18, 2008
    Same tv, same problem. I replaced the power supply and got it to work for a couple of weeks. The tv shut down again. The repairman showed me that the power supply works but it is not sufficient to get the tuner to turn on. We are looking for a repair manual for assistance.
4 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: problems after new ic chip install
Did you check for open resistors in the convergence circuits? Often that is what happens when the old ICs wear out it will cause a couple resistors to burn open, and they show no outward sign of being bad. Also double check the IC pins connections for solder bridges thats another common problem, I always use a magnifying glass to double check my solder when ever I do convergence or any IC work where the pins are close. But with the streaks youre describing I would think maybe resistors.
Posted on Jun 16, 2008
SOURCE: apex gb55hd09w
you need two STK392-020 - 3-Channel Convergence Correction Circuits. they run anywhere from $10 to 40, then either you or electronics shop solder them in
Posted on Apr 05, 2009
judojuan
SOURCE: Access Convergence Menu APEX GB55HD09W
Try changing the input to something other than component video, like AV1 or F AV
Posted on Jan 22, 2012
APEX GB55HD09 remote control
Hello
Buy one Atlas DVD/PVR 5-device Universal remote control. It isa Universal Electronics product. It has setup code for Apex tVs. The cldes are:
0767, 0765
Feb 16, 2012 | Apex Digital GB55HD09W 55" Rear Projection...
My 40" apex tv does
dude replace either power supply board or backlight inverter board, get them on shopjimmy for under $100.00 dollars both.
Dec 31, 2010 | Apex Digital AVL3076 30 in. HD-Ready LCD...
did you ever find out why you couldnt get into convergence?
Feb 16, 2010 | Apex Digital GB55HD09W 55" Rear Projection...
Apex out of convergence
I have this TV and have fixed this issue. If you cannot adjust Red or Blue convergence, then your STK ICs are defective. The signal board or Digital convergence board is not able to adjust sig lines on the deflection board so pushing buttons does nothing. The STK's are your amplifiers for vertical and horizontal. This will require dissassembly and soldering. You'll need 2 STK392-020 IC's and 125v/5A pico fuse or buss fuse..
The STK's are mounted on 2 massive heatsinks. Can't miss it. Word of advice, LABEL the 3-4 Pin plugs B,G,R from left to right. These are your Vertical and Horizontal coils for each tube. Don't mix them up. I did and the tv survived luckily. Chances are if your STK's poped, then they took out the -25v line. Take out the power supply that is mounted vertically on the right. Look for a row of axiel lead fuses with "SOC 5000" printed on it. They look like white rectangular blocks with leads. Check them all. Particularly RF817. Sits next to RF814. The service manual lists it as a fuse and NOT a Resistor-Fuse like the label suggests. I found more than one typo like this. I replaced mine with a generic 125v/5A fast blow buss fuse. Soldered in a holder for it. Should work the same.
Took me abit to realize it was a fuse on the power supply. This -25 line traces to W057/W058 next to the first STK chip. Explains the symptoms.
May 12, 2009 | Apex Digital GB55HD09W 55" Rear Projection...
Apex gb55hd09w
Oct 18, 2008 | Apex Digital GB55HD09W 55" Rear Projection...
TV won't come on
unplug it for 10 minutes then turn it on at the console(not the remore) and hold the power button in for 15 seconds. this resets most apex tv's
Oct 06, 2008 | Apex Digital GB55HD09W 55" Rear Projection...
Service manual to fix color convergence
I would like a service manual for this tv as well if anybody has one. However i did call apex and they said there is no service manual for this tv
Jul 01, 2008 | Apex Digital GB55HD09W 55" Rear Projection...
Problems after new ic chip install
Jun 16, 2008 | Apex Digital GB55HD09W 55" Rear Projection...
Converence ic
If you go to the following link you can get new replacement ICs and they provide free instalation instructions as well as free instant messageing tech support so you can do the job yourself and save quite abit of money. Heres the link.
http://servicemanuals.vstore.ca/
May 25, 2008 | Apex Digital GB55HD09W 55" Rear Projection...
Apex Digital GB55HD09W 55" Rear Projection Television Logo
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
